I have the 1513-tdxb polaroid tv dvd combo. the dvd wont load. ive changed the batteries in the remote, but it still wont work.
  • 813 Answers
Hi frined
i think your dvd lanse is week so change it & your dvd will be okey for change a lanse u shoud go with a good tecnision of dvd repairer it the new lanse come around $50 to 200$
Posted on Apr 15, 2008
  • 2,326 Answers
If the DVD is not loading, that means that it could have a defective loading mechanism. I would suggest to unplug the device and plug it back in, just to reset the circuitry inside.
  • Jaime Hernandez Apr 15, 2008
    It you mean, it won't play; follow bestdarngood instructions to clean the lens.
    If that does not work, the lens could be defective.
  • 3,037 Answers
1. Purchase or borrow a lens cleaner disc and try it first. You can find these things really cheap at any large department store. They usually get the job done well. However, you may need to clean the lens manually if the store-bought cleaner fails.
2. Remove the outer casing of the DVD player. Remove the screws that mount the top casing onto the bottom of the DVD player and slide the top casing off. This will expose the DVD deck, which houses the laser pickup lens.
3. Find the lens. The lens will be glass and under the DVD clamp. The lens will probably have a blue tint to it. If you are having trouble finding the lens, you could shine a light on the components and watch for the reflection.
4. Use a cotton swab and some isopropyl alcohol to gently wipe the lens. Just a quick scrub will do. Dry the laser pickup lens with the other end of the swab.
5. Give the lens a few seconds to dry and replace the covering of the DVD player. Test the efficiency of the player. If necessary, repeat the process.
Let me know if this doesn't work and we can try other options to get it working.
Thank you for using Fixya and Good luck.
Pretty much my 19 inch polaroid turns on then goes blank
Might be your backlight inverter...do you have sound? If so, hold a flashlight up to the screen when it's turned on and if you see images...that is probably the culprit. Try these guys for parts, they have been great to me in the past....ShopJimmy.com.
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/catalogsearch/result/?q=1913-TDXB
Aug 25, 2011 | Polaroid 1913TDXB 19 in. LCD TV/DVD Combo
We have a Polaroid 15 inch LCD television with a built-in dvd player. It also allows for jumpdrive connection. I must be missing something but we cannot figure out how to play a dvd. I put a dvd...
Do you have the Polaroid 1513-TDXB? I assume you have tried the eject button on the side of the TV (the lowest button next to the DVD slot). There are a few things that can cause a DVD to jam and not be recognized by the drive: put in the disc label side to the back of the TV, home disc with a glued on label (if the label comes loose), two discs in the slot or non-standard optical discs.
Some slot optical drives have a manual eject hole on one side of the slot; it should be near the top of the slot on this unit. Straighten a paperclip and try pushing on the release mechanism inside that hole. (A small paperclip is the correct size.) Sometimes pushing the optical disc with a second optical disc will bump it loose (be careful you do not want the disc to be dragged into the drive). Another possible solution is to pry the disc up off the spindle with a credit card. (Note: trying this could damage the disc and the drive.) A similar card with double sided sticky tape can sometimes lift the disc off the spindle. Stick the tape on the card, then peel the paper off the other side of the tape. Insert the card to be on the top of the disc (sticky side towards the back of the TV) and press it down on the disc. Lift up slightly and pull the card and optical disc out.
If the disc has partially ejected, two credit cards (one above and one below) can grab it. Turning the TV on its side so that the optical drive is pointing to the ground can also work.
There are a few things to check once you get the disc out. Were there scratches or other problems that would keep the drive from seeing the disc? Other optical drive issues are dirt on the lens and the tracking unit failing on the drive. Blowing the dirt out of the drive may help. Otherwise, it needs to be fixed or replaced which means getting it out of the TV.
The manual for the TV is available at this review site: http://www.hdtvreview.com/Polaroid-1513-TDXB-hdtv.html . The direct link to the manual is http://www.hdtvreview.com/pdf/polaroid-1513-tdxb-manual.pdf .
I hope this helps.
Jun 09, 2011 | Televison & Video
Video display will stop after the TV is running for a few minutes. Audio is fine, video goes black. Model 1913-tdxb, June 2007
The tv Long LCD inverter board it is dead.This long LCD inverter provide a backlight for the tv LCD screen panel to have a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a reburbish a long LCD inverter board for the replacement.
Jun 09, 2011 | Polaroid 1913TDXB 19 in. LCD TV/DVD Combo
Need a power supply for my polaroid lcd tv model 1913-TDXB
Hello
You need to contact nearest Polaroid Service Center to replace the power supply or contact the Product Support Here
http://store.polaroid.com/support_detail?p=4116
Good Luck
Jan 03, 2011 | Polaroid 1913TDXB 19 in. LCD TV/DVD Combo
I have a Polaroid 1913 TDXB with the original remote just a few days ago it stopped working it has fresh batteries. I assume the remote has reset it's self is there a code for it?
Take the remote aparts,clean it with a Q tip with some rubbing alcahol.Clean the rubbers films and the circuits board.Clean IR in the tv and the remote.After this still don't work ur remote it dead,by the main CPU,it junk know.Here a website to buy a new one 1-800-Remotes Factory original.Never have need codes for oiginal remotes.
Nov 03, 2009 | Polaroid 1913TDXB 19 in. LCD TV/DVD Combo
Can't get universal remote to work for polaroid tv/dvd combo
read here
http://www.fixya.com/support/t225581-code_polaroid_tv
May 19, 2017 | Polaroid TDA-03211C 32 in. LCD HDTV
Remote codes
what you need to do is call direct tv support they should have a code for you
May 15, 2009 | Polaroid 1913TDXB 19 in. LCD TV/DVD Combo
Polaroid 1913-TDXB 19" LCD HDTV/DVD Player Combo no longer recognizes dvds
I have the same TV and the same thing happenned. Then after a month or so after DVD stopped working I get not picture at all. TV is shot.
Oct 14, 2008 | Televison & Video
Sir: I have a Polaroid TV Model 1513-TDXB. The included instructions are too sketchy. I am unable to operate the remote to be able to control the DVD player. Page 3 Press input has no reaction. When...
Sir,
I reread and reactivated the inadequately written instructions and was able to overcome
the deficiency.
I am not stupid. I operate other electronic devices the have adequate instructions included.
S. Wessling
Apr 19, 2008 | Polaroid Televison & Video
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
Electro Med Services...
