Question about HP PSC 2210 All-In-One InkJet Printer
Re: Printer HP 2210
I have a problem with the HP 2210 printer which is also a scanner, fax, and copier. The printer only works directly from the computer. When I try to copy there is a message on the printer that states that the cartridge needs to be aligned. I did a test for the cartridge alignment and I try to copy and the message repeats and still can't copy. What should I do? Any advice is welcomed. Thanks. Darlene Same problem as described--can print from computer but when I copy all I get is 2 black bars and notice re allignment.
Well darlene maybe you should change the cartriges they might be too old the second option clean the top glass beneath and above so that the scunner might read clearly thomas
Posted on Apr 16, 2008
Send to print que then get window saying,"welcome to SEND FAX WIZARD" hp 2210 all-in-one
I swapped ports and deleted fax printer, which I never had. Now works OK
Thanks,
CARL MCKINNEY
Jan 13, 2010 | HP PSC 2210 All-In-One InkJet Printer
Hp 2210 all-in-one printer fax copier scanner-keeps saying remove door and remove paper jam and there is no paper jam. How do i clear this?
You can't I have the same printer and it is the stubbornest thing in the world. Just hit enter and keep printing.
Nov 18, 2009 | HP PSC 2210 All-In-One InkJet Printer
Will not fax out, or receive faxes
Check the FAX cable and make sure it is a FAX cable. There should be only 2 gold
contacts when you look at the cable jack. Phones use a 4 contact cable.
May 27, 2009 | HP Printer/Scanner/Copier 2210 Ink-jet...
How do I receive a fax from my hp psc 2210 multifunctional printer?
Here is a HP fax setup link:linkhttp://h10025.www1.hp.com/ewfrf/wc/document?docname=c00036516&lc=en&dlc=en&cc=ie&lang=en&rule=29818&product=79499
Here is the link for the user guide:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=79499&lc=en&cc=ie&dlc=en&lang=en&cc=ie
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 14, 2009 | HP Printer/Scanner/Copier 2210 Ink-jet...
Wejust bought a psc 2210 and we dont know where ink jet are at in
The are under the scanne, you reach them fron the front
Here is the full user guide, check on page 72 Full User Guide
And here is basic guide
Basics Guide
And here is the setup guide
Setup Guide
And here is the complete supoorter site
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3571753&lc=en&cc=us&dlc=en&submit.y=9&submit.x=7&lang=en&cc=us
Good luck
Nic
Mar 04, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP Printer will no longer scan
Hi Keithcarrol
Please do the following
1. Go to Control Pannel then sellect Add/Remove Programs and uninstall all HP Software.
2. Disconnect all Prinetrs
3. Go to Control Pannel then sellect Printers and Faxes make sure there is no Printers in there if there is delete them
4. Install Psc 2210 software and follow instructions on when to connect printer.
Dec 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP psc 2210 All in One Fax stopped working w/Vista program
Iam affraid HP has full feature printer driver for the PSC 2210 All-In-One on Vista operating Systems,
But you can try the following link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808543&lc=en&dlc=en&cc=us&lang=en&os=2093&product=79499
And Also for the Press Enter to Align Cartridge issue try the bellow link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00042820&dlc=en&product=79499
Good Luck
Jan 15, 2008 | HP PSC 2210 All-In-One InkJet Printer
PSC 2210 Scanner Doesn't Work
I'm not sure about this specific model, but I've had similar problems with other HP all-in-ones and usually what fixes it is uninstalling and reinstalling the software (make sure to follow their directions properly and not plug the printer in until they tell you to). You should also make sure you're using the most updated software from the HP website rather than the one that came on the CD with the printer which may be outdated.
Jan 05, 2008 | HP PSC 2210 All-In-One InkJet Printer
Re: Printer HP 2210
Apart from being a hardware fault, if it's working through pc and if I understand it it happens when you copy, i think it still works from the installed driver on the pc. If it doesn't apologies as i'm not familiar with this printer, but if it is the case try disconnecting from pc and uninstall drivers. Re-install drivers and re-connect all-in-one when prompted, see if it goes away.
Dec 21, 2006 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
67 people viewed this question
Ben Johnson
