Hello sir i have panasonic fax kx-fl 612 error code is call service 3 pls help us how i can run my fax plz
Call service 3 es que el abanico no funciona por que se sobre calento la unidada fusora
Ihave a problem call service 3 panasonic fax machine kxmb2025
Manojjaiswal I have one panasonic KX-MB1900 all in one printer problum showing call service
I repeatedly done what you said but nothing happens, it does not print. what can i do?
When i press the set replied gcz1cs :c154
SOURCE: i have Call service 3
(NOTE: This procedure will erase all previous memory. So print out your lists etc before beginning.)
Press the MENU button. Enter #9000 from keypad. Then enter *550 from keypad. Then press the START button. Then press the MENU button again.
Now unplug the power cord for at least 10 seconds.
Replug in power and now a page will print out saying "Thank you for purchasing this Panasonic Fax Machine".
God luck!
SOURCE: problems Panasonic kx-fl612 call service 4
it's means the fan is not working check the fan or connectioc if all are ok then reset it bu menu#9000*550 set
hello,i have a Panasonic fax KX-FL243 error code is call service 3,please kindly help us.how can i run my fax.thank you,
Panasonic fax KX-FL423 ruther..
saya punya fak rusak call service 3
