Question about Frigidaire ATF6000ES Front Load Washer
Lights come on and it beeps
I have a frigdaire model LTF2140ES3 and the start,doorlock, rinse and spin lights come and beep 9 times. The washer will not start and the only way I can get it to stop is to unplug it. Any suggestions.
  • Steph12 Sep 18, 2008
    I have the same problem. . .based on something I read online at another site, I think it is an error code. I have searched everything and I am not finding an operator manual - just a "quick start" guide of sorts. Does anyone own the same model and have the operator manual describing how to interpret this error code?
  • 101 Answers
The timer may be stuck, you may have to change the timer.
Posted on May 12, 2008
Why are frigdaire front loader all leg ligts on right side blinks and beeps all the time
Thanks for your inquiry, Barbara Williams!
I understand that the lights on your Frigidaire washer are blinking and beeping. It sounds like your washer is providing a set of error codes. Your control panel may need to be replaced. I would recommend contacting a professional technician for proper diagnosis to be completed to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Nov 29, 2014 | Frigidaire FRFW3700LW Laundry : Front Load...
Code in digital display does not have a E in front of it
Please let me know if you can get a number after this - if so what number shows up?
Model differences:
• Better models have a digital readout display
• Good models do not have a digital readout display
In the Better Models line, the failure codes will appear in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, Final Spin and Control indicator lights will flash.
Example: E14. To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains
stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something
that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is
started.
In the Good Models line, the control signals the failure code by flashing the five indicator lights of Door Lock, Wash, Rinse,
Final Spin and Control for the first number or letter after the E and the Start indicator light for the second number or letter
after the E. When a failure occurs, the washer stops or pauses and the control beeps and flashes the five indicator lights to tell
the customer that a failure has occurred. To stop the flashing and beeping, the customer may touch the Pause Cancel button.
The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer.
If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate
normally the next time it is started.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking
LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Please Note the following...... on a small number of washers with serial number prefix XC4,
if the previous procedure does not perform as specified, follow the option below:
• Follow all previous steps but instead of pressing Start and Pause Cancel buttons,
press and hold Options and Pause Cancel buttons.
If the washer is a Better Model, the error code will appear in the display. Troubleshoot problem by using charts on the
following pages.
If the washer is a Good Model, the five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the
number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit.
Take
separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice
indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START
indicator light start flashing at the same time.
The control will pause for 2 seconds, then repeat the code as long as the two buttons are pressed and held.
Note: A letter appearing in the code stands for a number higher than nine:
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code F1: the first digit would be 15 and the second digit would be 1. If this code would appear on a washer in the
Good model line, the five indicator lights would blink fifteen times and the START indicator light would blink once.
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
Haier HLP21E Top Load washer keeps beeping & blinking after water intake. It will rinse out the water when 'rinse' pressed. However it does not 'spin' but instead all three orange lights start blinking &...
No spin with alarm means the unit is out of balance.
The troubleshooting manual reads:
"The safety switch acts. The
spinning cannot work (The
WASH, RINSE and SPIN
indicator flash and alarm goes
off every 10 seconds). If
trouble cannot be solved after
alarming, it will alarm again
every few minutes."
To solve this the load must be balanced:
Make sure to level the machine on a solid floor. Also you may have to redistribute the clothing in the tub for even weight distribution.
Sep 28, 2013 | Haier HLP21E Top Load Washer
Model Gw709AU
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Feb 20, 2013 | Fisher and Paykel Washing Machines
MODEL WASHER # FTF214OFS2 BLINKING AND BEEPING LIGHTS WONT STOP
Hello Jennifer Brookman - Unfortunately from what you are describing it sounds like the washer is either experiencing a communication error from the control board or wiring failure. Since you have already tried the basic troubleshooting by flipping the household circuit breaker off, do you notice if the door is securely latching? If it is not, then the issue can also lie with a faulty door latch assembly. I suggest contacting a professional for a proper diagnosis and to move forward accurately.
Feb 10, 2013 | Frigidaire FTF2140F Front Load Washer
Won't drain out water, three lights on, first wash, first rinse, and spin. Beep every one second
Hi just read your posting.Could you confirm the lights that are on when the machine is beeping.Starting from the left to right which lights are lit when the machine is beeping,Is it the 1st and 3rd or the 4th and 7th ---etc---?Please reply with this information and I am sure I can help you.Looking forward to your reply.
Sep 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher/Paykel WA37TG1 washer. goes through the wash cycle and the rinse cycle. stops at spin cycle and beeps. lots of suds left on clothes. have unplugged and let sit and start again. this got me through a...
Hi just read your posting.Now when the cycle beeps a series of lights will light up indicating an error code.The lights will be in a row of 8 lights.Starting from the left to the right which lights are lit?Is it the 2nd and 5th or the 3rd and 7th ---etc----?Or do you have the display model and an error code is on the screen?Please reply with the additional information on the questions and I can help you further.
Jul 20, 2010 | Fisher and Paykel WA37TG1 Top Load Stacked...
We are using model #gwl15 fisher and paykel top load washer. When it gets to the rinse cycle it justs beeps. It won't go any further. It is not unbalanced. I've taken all of the clothes out of the...
Hi just read your posting.Now when it beeps and stops do any lights flash or come on?If they do they will be on a row of 8 lights.Starting from the far left which lights are on or flashing?Are they the 1st and 4th light or 3rd and 6th --etc--?Please look underneath the machine and look to the front right of the machine You should see your pump which should have a red or black fan on it.Turn this fan a few times and hopefully this will loosen your pump if it is jammed.If you have the pump without the fan please reply and I can guide you throe unjamming it.I think with your symptoms you have described, you might have a jammed pump.Please reply for further help.Hope this helps.
Jun 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Ecosmart will Wash but not Rinse/Spin
You have too many clothes in the washer. Take some out and try again
Sep 09, 2009 | Fisher Paykel EcoSmart GWL15
Frigidaire ATF6000ES Front Load Washer Logo
525 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
