HITACHI MX-W50 NEEDS REPAIR/SERVICE. VOLUME CONTROL MALFUNCTIONING. ENTIRE UNIT NEEDS SERVICING.
How about selling it to me ,if you still have it
Posted on Sep 29, 2011
How do I get clear copies without streaks or partial printing?
Here is a video on how to remove lines on your machine. If you do these steps and the lines persist you probably need a drum and drum blade replaced.
Jan 23, 2015 | Sharp Mx-B401 mx-B401
Hitachi 55vf820 problem
Most likely the buttons on the tv are stuck or malfunctioning, replacment of the button pannel will solve the issue
Mar 17, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Removing a screen protector on a Hitachi 57F10A
You might try Hitachi for the service manual with full breakdown.
Basically the entire front screen unit comes off from the front in one piece, then inner two screens come out--carefully! and then frame needs to be partly pulled apart to get out screen from rear as it is in a slot all around the frame.
Apr 10, 2012 | Hitachi Televison & Video
Hitachi mx-w50
This is not a camera, it is an integrated 'hi-fi' system - try posting this query in a forum dealing with music centres
Jun 16, 2017 | Cameras
Location of fuel pump for mazda mx5 2000
Removal & Installation
Through the trunk servicing panel...
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Properly relieve the fuel pressure.
  3. Remove or disconnect the following:
    • Negative battery cable
    • Rear package trim
    • Service hole cover
    • Fuel pump cover
    • Fuel pump connector
    • Fuel hoses
    • Fuel pump and gauge sender unit as an assembly
    • Fuel pump from the sender bracket
To install:
  • New O-ring set
  • Fuel pump to the sender bracket
NOTE
Pull the fuel pump down so that it is tight against the bracket.
  • Fuel hoses
  • Fuel pump cover
  • Rear package trim
Oct 14, 2010 | 2000 Mazda MX-5 Miata
Whirlpool double oven rbd306pdb15 displaying code e6 f2. What does this mean?
HI. This code is in reference to the keys that initiate actions on your unit, The cancel key is malfunctioning at this time. Follow the procedure below to correct the issue.
1. Disassemble the control panel and check the keypad connector for firm connection (keypad connects to the control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate the keypad in to the control board as one unit. In this case, replace the entire control board (also called ERC or clock).
Aug 23, 2010 | Whirlpool Ovens
Volume Control Unit has gone bad
The volume control is nothing more than small complicated rheostat.
If you don't know electronics take it to a radio repair shop. Just tell the repair guy to build you a new one using the old cord. That is if the cord is not what is bad! Take the entire unit with you. For a trained repair man it should be a easy thing to rebuild. I own a P7800 and if the control unit should break that is just what I would do.
Mar 28, 2010 | Creative Labs Inspire P7800 Computer...
Sony cyber shot camera lense stuck halfway.
    According to the symptom your camra needs replacement Lens block, It is due to malfunctioning of zoom motor. The part No along with description is given below:
1-788-363-11     OPTICAL UNIT
  Replace the unit with new one and it works fine again.
  Thanks for using fixya.
Oct 31, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Protection circuit trips a low audio output level MX-W50
When you unplug one speaker (from the back of the receiver) and the rec. works good, then the speaker that you unplugged is the bad one, or the wire that is hooked up to that speaker is bad. Repair the speaker or the wire.
Nov 18, 2008 | Audio Players & Recorders
Nad c372 Remote Control
Hello Robert,
If the standby/protection indicator on the amplifier blinks when you specifically press the volume +/- key, it obviously indicates that the unit is receiving the remote's command.
Try the following while pressing the volume key on the remote:
1.- Put your ear as close as possible to the volume control knob and listen for the sound
of a motor spinning, if you hear it, the volume control assembly needs repair. If you
hear no sound, proceed to next step.
2.- Gently rotate the volume control knob on the amplifier unit (it might be stuck and
needs a "little help").
If none of the above applies, the unit needs to be opened and troubleshooted. I've seen many instances where the volume control motor was not properly connected to the board or the assembly was put back incorrectly (specially in units that have been opened to be refurbished). I've heard NAD has a limited warranty for refurbished items. It might be wise for you to check before sending the unit for repair at your expense or trying to tackle the problem yourself. Hope this helps.
cancerags
I
Dec 26, 2007 | NAD C372 Amplifier
505 people viewed this question
 Grubhead
Grubhead
