I have a Hayward Max Flo 2 hp pool pump. Was working find and then one day we turned it on and the motor just stopped. This is our 2n motor in 4 yrs. How can we make sure its not something else before we go spend money on another motor?
More than the motor it is probally a bad seal causing the problem with the motor. All you can do is be sure it is installed right when you put the new one in and if you see water under the pump take it apart and install a new one. I live in AZ and the water will evaporate before it gets to the ground under the pump so here this can be a real annoying problem. We quite often will have to look for calcium left behind when something leaks.
