This only happens when I am trying to print a web page. I do a print preview and I see about 10 pages of text that have no relation with web page that I am viewing on the screen. When I print , the same thing happens, 10 pages of strange text instead of page that is on the screen.
  • 832 Answers
Software issue of the browser, no printer prob. You didnt tell us what printer you run. Search printers manufacturer webside for a update if the print preview belongs to printer software, else your browser needs an upadte.
Posted on Apr 15, 2008
I am a teacher. We have Dell computers with windows 7 on them. Recently our school district downloaded Microsoft Office 10. Since the new microsoft office, my xerox phaser 8500 is printing strange. ...
Hi fsaltzman,
You need to check the margin settings in the print preview option, make sure you decrease the margins that are set by default and try printing a test page , this should work fine.
On the File menu, you need to click Page Setup, and then click the Margins tab.
Here you can adjust the margins as per your convenience.
To View page margins :-
  1. You need to go on the Tools menu, select Options, and then select the View tab.
  2. Under Print and Web Layout options, select the Text boundaries check box.
The page margins appear in your document as dotted lines.
You can use these dotted lines to correct your margins so that your student's assignments are not cut off and there is no large margin as you have mentioned in your question.
You can view page margins in either Print Layout or Web Layout view only, and they do not appear on the printed page.
Hope this helps
May 11, 2011 | Office Equipment & Supplies
My printer -X1185 prints the page with a 3 inch blank area on the left side and some of the right side printing is off the page. This is typical in my e mail page, and even if I center the letter on...
Web site designers create Web pages for display on a monitor, not for users to print on 8.5- x 11-inch pieces of paper. This becomes obvious the first time you try to print a Web page. Content you need may get chopped off by the right printer margin, whereas content you don’t need, such as the site’s copyright information, will print on its own sheet of paper. Fortunately, you can avoid such problems with a little foresight.
Before printing any Web page, open Internet Explorer’s File menu and select Print Preview. The current Web page will appear on-screen exactly as it will print on paper. Scan the preview carefully. If it appears that some content is chopped off by the right margin, click the Page Setup button located directly to the right of the Print button in the upper-left corner of the Print Preview window. In the resulting Page Setup dialog box, adjust the left and right margins so that each is set to 0.25 inches. The extra inch of space you gain by resetting the margins should provide just enough room to accommodate all of the content on most sites. Click OK to save the changes and return to the Print Preview window.
Next, scan the preview to determine which pages contain the content you want to print. Take note of those pages and click the Print button in the upper-left corner of the Print Preview window. Locate the Print Range heading and select the Pages option. Type the number of the first page you want to print in the From field and type the number of the last page you want to print in the To field. For instance, if you want to print just the first three pages of a Web page’s content, type 1 in the From field and type 3 in the To field. If your browser doesn’t have To and From fields, type the range of pages (such as 1-3) in the corresponding field. Make sure your printer has paper and click Print.
May 04, 2008 | Office Equipment & Supplies
Tip
How can I print what appears on the screen completely?
Many web designers are conscious of the fact that some people will want hard copies of their web pages. For these sites, you can just print in regular "portrait" mode. At other sites, however, part of the text gets chopped off in regular page orientation. Before you print anything it is a good idea to preview the page first. Just go to File / Print Preview .
There you can make sure that everything will print correctly. If you see that part of the page will be cut off, just click the " Page Setup " button (it looks like a page with a gear on it) or use the keyboard shortcut Alt+U.
You can then change your page layout to landscape. Your browser is, after all, in landscape format, so why not go with the flow. Go down to where it says "Orientation" and click the radio button next to "Landscape".
Print Preview will change to show the new layout. Is everything there now
on Dec 14, 2009 | Office Equipment & Supplies
How to print a page from a website
Please follow the steps to Print a web page using the Internet Explorer or Mozilla web browser.
>Please click on File, Print or press Ctrl+P key and then select the Printer( HP Officejet 5610), select the page range and click OK to print the web page contents.
>You can also preview the web page you're trying to print and then print it (File-->Print Preview).
Good Luck!!!
Jul 02, 2010 | HP Officejet 5610 All-In-One InkJet...
I have a print problem with it. It prints correctly from my LIDE copier but does not print text from email or the web.
when in e-mails or web - highlight text , RGT click and selsect print frame this should then print page - also for your own benifit in printer lay out select print preview on this will help you in knowning what its printing.
Aug 12, 2009 | Computers & Internet
Why won't my HP Photosmart C4400 printer print the full emails.
I would like you use HP Smart Web Printing utility which will resolve this issue. With this fast, free download, this enhancement to Microsoft Internet Explorer and Mozilla Firefox improves upon IE and Firefox ability to print what you see on the web page. HP Smart Web Printing allows users to:
  • Select text and graphics easily from any web site and save a handy list of clips
  • Save paper by combining portions of numerous web pages
  • Preview and modify clips before printing
  • In addition, HP Smart Web Printing automatically fixes right-edge clipping, eliminating wasteful prints containing clipped pages or sparse lines of useless text (IE 6.0 only).
  • Please click on the link below to download it.
    http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?os=2093&softwareitem=dj-56929-5&lc=en&dlc=en&cc=us&product=3551212
    keep rocking!
    May 14, 2009 | HP Photosmart C3180 All-In-One InkJet...
    Web preview doesn't match design view
    Try the steps given below MS website :
    http://office.microsoft.com/en-us/publisher/HP010210181033.aspx
    Mar 03, 2009 | Microsoft Office Publisher 2007 for PC
    HP Deskjet 5150 print is too small
    Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
    In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
    Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
    Officejet 5610
    look at the print preview by clicking on file , print preview then see if you see the web page or sometimes one page on the web will be two ,three or more pages and if your printer is only set to print one page then thats all you will get , what happens when you try to print a web page?
    Oct 09, 2008 | HP Officejet 5610 All-In-One InkJet...
    Change font size
    Two things you can try!
    1.From your Browser you can change text size in the browser.
    I am using Internet Explorer for this example
    Click on View from the top tool bar, Select Text Size.. you can increase and decrease the text size of a web page.
    2.Before you print check Print Preview and Increse the page size.
    My Browser defualt to Shrink to Fit,
    I can change that to 120% and it will print the page very large.
    Most programs in Windows will offer a Print Preivew
    there you can make adjustments, and this can also be accomplished with Page Set Up..
    Hope this Helps
    Jul 03, 2008 | HP LaserJet 4 plus Printer
    50 people viewed this question
    jasbo
    jasbo
