Question about Philips Televison & Video
Product: MCD702/37 DVD Micro Theater disk does not spin fast enough to play
I had this problem with my unit. After disassembling it and finding no problems it dawned on me.
The drive motor is very small and not very powerful. So I assumed that any resistance to the motor (like a sticky bearing) may cause it a problem.
So by taking 2 small screwdrivers and gently taking off the disk attachement (just open the lid and gently pop it off) I then put very light oil on the motor shaft.
It has fixed the problem. It took about 5-10 minutes for the oil to work its way into the bearing but works fine now. You might want to give it a try....only takes a couple of minutes.
Posted on Sep 03, 2008
See shoie33's solution. GENIOUS!!! The only thing I would add is that the screwdrivers are only for popping the disc spindle off - NOT for removing the two small phillips screws found under the spindle. THANK YOU shoie33 !!!
Posted on Jun 05, 2009
  • Skipster62 Jun 05, 2009
    Of course I know how to spell GENIUS
When a DVD is placed in the player to play, the reading on the screen is "No Disc" and nothing plays.
Check the motor if its spinning or not.If it isn't spinning fast enough that you need to lubricate the motor from the underside so that the lubricant doesnt go on the lens.But if its spinnig fast enough that maybe the lens isnt picking and needs cleaning or replacing..Good Luck
G..
Aug 10, 2011 | Mintek MDP-1760 Portable DVD Player
SAMSUNG HT-P10 DIGITAL HOME THEATER SYSTEM wont play DVDs
You could try cleaning the drive with a dvd cleaner disk and also a can of compressed air to blow into the drawer. It may just be dirty. Good luck! I hope this helps you.
Aug 27, 2009 | Samsung HT-P10 Theater System
Place DVD in any slot and it says "reading disc" then "no disc"
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
May 04, 2009 | JVC THC5 Home Theater System with 5-Disc...
DVD's won't play
I have a somewhat similar problem, but wasn't after a cleaning disk use. Most of the time when I try to use this system now, after I put a DVD in, I start getting a loud buzzing noise (almost as if gears are meshing)
Nov 17, 2008 | LGDVT418 System
Wont play disk has error code
It is a lens problem, the laser lens is either dirty or the lens pickup is faulty.
Oct 01, 2008 | Sony DAV-DX250 System
Panasonic home theater sound system SC-HT720 won't read or play dvds or cds
mine does the same.the display flashes "prog" and --:-- on cd's,dvd's and even the cleaning disk it almost sounds like it isn't getting enough power to spin the disk.
Jun 23, 2008 | Panasonic Home Theater System System
DVD PLAYER PROBLEM
Sounds like a common problem with this trutech brand. There are some possibilities. 1. Laser could be worn out, 2 it could be a bad cable coming from the laser. 3 The home switch for the laser to come all the way back to its "HOME" position could be bad. But usually if this is the case, the disc won't spin at all. And 4th, the spindle motor that spins the disc could be worn out. Causing the disc not to spin fast enough and thus causing an error. Let me know if you want to send me one of these anyone so as i can trouble shoot the problem further. Keep me posted and i hope this helps you out some. Thank you Jay
Oct 10, 2007 | TruTech PVS2119 19 in. LCD Television
Dwm-3900 wont play dvd's
Because you have limited knowledge of your products history, first ensure that your Country Code is set correctly. Using your remote, access your User Menu/Setup > Country Code > U S > Memory > Setup. I am assuming that you are in the US, and are trying to view Region 1 DVD's. Please update for further instructions if the above doesn't solve your problem....good luck.
Aug 01, 2007 | Dual DWM-3900 System
Mcd288 problem
Try not to use any rental dvd discs or dvd burner discs. Go get a brand new dvd movie(again,do not burn a DVD disc and play in this unit.) and put it in see if it works? Should have at least 2-3 movies for testing.
If you have tried to put in some BRAND NEW DVD movies and still doesn't work,you have a problem with the unit.
Jul 23, 2007 | Philips DVD Micro Theater Shelf System...
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
