Question about Panasonic PT-52LCX65 44" HDTV
Panasonic 52lcx65 52in projection tv
Go to turn on tv and temp light flashes 3 times every 5 seconds
  • Ronnie O Apr 15, 2008
    go to turn on tv and temp light flashes 3 times every 5 seconds
I have the same TV had the same problem while under Warranty Panasonic tech replaced the lamp
Posted on Apr 29, 2008
I have a pt43lc14 unit and the power light comes on but i do not have a picture. the temp light flashes 2 times every 5 seconds. can you please tell me what the problem is?
The "LAMP" LED light indication flashes or stay on too?Yes,than the tv projection lamp on the tv life are over.Tv require a replacement of new projection lamp.
Nov 23, 2010 | Panasonic PT-43LC14 43" Rear Projection...
I have a Panasonic Model PT-50LC13 flat TV. Was working when got it brought it home, it is used and now when I go to turn it on --- we get a green light then a flash of 5 yellows blinks then no light for...
This tv has 3 indicator lights on front, Power, Lamp and Temp
I assume Temp light is blinking 5 times after every 5 seconds, if that is correct then it is problem of clogged air filter located in light engine that need to be cleaned.
Below is an image of light engine and air filters locations are marked with red circle, it is job of professional to fix this issue because complete light engine need to be take out from tv cabinet.
Hope these info will help you, let me know if you have additional question or need service manual copy if you want to repair tv by yourself.
Thanks.
Nov 10, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I have a Panasonic 52lcx35. I contacted Panasonic, and they sent a repairman to "repair" the green spots we were seeing (this was the only problem). He did something, and afterwards, the tv only turns on...
amber weaver,
It sounds like the repairman forgot to reconnect one or more of the fan motors. There are several in these units and if not connected you will get the error you mentioned. Unplug the unit and remove the back. Locate all the fans (this may take some time to make sure you have them all).
There could be 3 or 4. Check each one's wire to make sure they are all connected to wires or an appropriate board. If this is your problem this should solve it.
Thanks for using FixYa and for the great rating!!
hardrocko
Aug 23, 2010 | Panasonic PT-52DL10 52" Rear Projection...
Panasonic 56" HDTV Projection TV. Model PT-51HX42 TV power button flashes 3 times and then turns off
You have a defective temperature sensor
3 blinks flashes oncenevery 5 seconds
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Panasonic PT-51HX42 51" Rear Projection...
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
My tv does not come on and the red light inthe front flashes 3 ti
The 3 blink error code is indicating that the Convergence ICs have failed. You can get the repair kit for your model which contains both convergence IC and the six feed resistors and it also has step by step instructions with pictures that show how to do the repair. Heres a link to the repair kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
May 30, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-52LCX65 44" HDTV Logo
265 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
