Question about Vizio VU37L 37 in. LCD TV
42 in lcd vizio "no signal"
Just last night my vizio "broke". When I turn it on, it says "no signal" on a blue screen and then 5 seconds later the tv turns off.
I saw where you mentioned that it is the main board.
When can I get a new one and what is the price range? Is it easy to install?
Can there be any other diagnosis for my TV? Like a cable or something?
Thank you.
  • jhawk80 Sep 10, 2008
  • Anonymous Jan 18, 2009
    no signal
Had the same problem. My TV must have been puht onto RGB input. So I plugged my computer in to the RGB on back and turned on the TV. It stayed on. Then switch it back to input of choice
Posted on Dec 26, 2008
Vizio 37 hdtv problem, blue screen w/ no signal displayed then shuts down in about 20 seconds
The problem is the main digital board. It does not have a reset button.
Oct 25, 2017 | Vizio VX37L Television
Why does my LCD HDTV go to a blue screen when changing channels
if using a box it may be normal but not nice, I would suspect the set is a bit slow reacting to signal change. I remember some nasty JVC sets that when going up or down a channel the screen would blank for about two seconds and come on, normal since all those had that feature(no channel surfing)>
Sep 03, 2012 | Vizio 42 in. LCD TV
I turn on the tv and i get a blue screen for 5 seconds and the tv shuts off. Any ideas?
It does not have any input connected. Without any input, the TV switches off.
Jul 03, 2012 | Vizio GV42L 42 in. LCD Television
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Apr 18, 2012 | Vizio L32 32 in. LCD HDTV
Hey bbendure, I have a similar/same same problem! My model is a GV42L.
It has a blue screen that says no signal t, then it turns itself off in about 20 seconds.
Is this the same problem you see?
Oct 09, 2010 | Vizio GV42L 42 in. LCD Television
The tv had blue screen briefly showing "no signal" then turns off. ... and I am getting the same blue screen-no signal.
If your television is displaying a blue screen or no signal message and then turning off, your TV may be at an inactive input. Here's how you can get back to watching your TV:
1. Powering on your TV and press the INPUT button on the VIZIO remote control repeatedly until a picture re-appears.
2. If this does not work, try again but press the button slower this time.
I got this off the vizio website.
Feb 21, 2010 | Vizio GV42L 42 in. LCD Television
TV says lost signal and turns itself off
Unplug the TV from Wall, wait a bit and plug back in. Should be reset.
Feb 09, 2010 | Vizio L42HDTV 42 in. LCD Television
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
Why does it say no signal with a blue screen
Assumtions, but you should check:
Make sure the cable/antenna is attached properly
If you have a cable service, make sure it's active.
On initial power up, use the menu to navigate to the input selection screen, and choose the correct option for your application. Also worth noting is that there is a second menu page where you select cable or antenna. Check that too.
Please post your findings.
Thanks.
Joe
Dec 12, 2009 | Vizio L32 32 in. LCD HDTV
Vizio VU37L 37 in. LCD TV Logo
1,116 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
