Royal Shredder 1200mx series shredder just makes noise, does not shredde
We r using 'xerox fax center7242a' fax machine. In this we r facing aproblem that is no dial tone in hand set. but dial tone camein speaker. hand set and spiral card ok. pls give solution for the above problem.
Posted on Apr 15, 2008
I have royal px110mx and it won't shredd my papers. When turned on and put a paper, it will be making noise and not shredd the paper. Can someone bail me out.
Your Royal shredder probably hasn't been cleaned since the day it was first used. Take a look at the shredding mechanism and you will find bits and pieces of everything. A thorough cleaning should get your shredder working again. Be prepared to spend considerable time on maintenance.
Jul 20, 2016 | Royal Office Equipment & Supplies
Makes grinding noise and does not pull the paper in or shred. I have pulled out all bits of paper stuck between the teeth. I'm afraid this thing is toast
This type of shredder can get clogged so badly, the material has to be removed with a utility knife. This is especially true if someone has tried to shred coated stock or, worse yet, credit cards. The noise you are hearing is the mechanism bouncing over clumps of residue jammed in-between the grinding "teeth".
Apr 18, 2015 | Royal 1200MX 12 Sheet Strip Cut Paper...
I have a Royal Mp220 paper shredder the motor hums when you put the paper to the blades it doesn't shredd the blades do not turn .
To begin with I'll explain that I'm not familiar with your shredder at all, but what you describe might be the same thing I've seen on other shredders. Many actually have a second hidden switch which serves as an interlock to make sure the unit is properly seated in the catch basket. In most cases its located a corner and the catch basket actually has a small shelf to press the micro switch in that location. I'd suggest you examine the bottom side of the shredder to see if you can see a small switch that also needs to be pressed.
Apr 24, 2014 | Royal Office Equipment & Supplies
POWER LIGHT ON BUT WILL NOT SHREDD
POWER LIGHT ON BUT WILL NOT SHREDDER
Aug 25, 2013 | Royal VF1000MX Shredder
Royal Shredder 1200MX model Motor is running but not rotating blades to engage cutting fed paper
If the motor is running but the cutting blades are not turning then you have likely lost a gear/ or the teeth off a gear inside. You will have to open it up to find out which gear/gears are broken then you can contact Royal at 1-800-524-0799 for parts pricing and assistance.
Dec 29, 2010 | Office Equipment & Supplies
My shredder work on reverse but not on auto mode the ready led is on but when i try to shredd,.. nothing happends . inside everithing is clean and i see no brken parts or wires detach
Try cleaning the "eyes" in the middle of the slot where you put the paper in, they can get dusty and not detect the paper being put in.
Sep 18, 2010 | Royal VF1000MX Shredder
Royal 1200mx confetti cut shredder : wont turn on plug is in perfectly
If its dead...no lights, nothing, then the pcb inside has probably gone. Give Royal a call at 1-800-524-0799 for parts and prices.
Sep 07, 2010 | Royal Office Equipment & Supplies
Royal 150MX bumping noise when paper is inserted
Sounds like you may have a gear problem; unplug unit open the top to see whats broken/stripped then call Royal at 1-800-524-0799 for parts and prices.
Apr 20, 2009 | Royal 150MX Cross-Cut Shredder
My shredder requires about an hour of cool down every time it shreds a load.
do spry lub down in the cutter shoot like WD40. If not do it. If you do there may be a billed up of paper dust in the machine it is a catch 20,22
Oct 24, 2008 | Royal VF-1200MX Shredder
79 people viewed this question
jasbo
jasbo
