This problem should be removed because:
Problem with Sony PlayStation Portable (PSP) Console
i cant access my internet on my psp
i really need the internet so if yu can help i would be greatfulÂ
Suggested Solution (3)
To connect to the internet on your PSP, you need a Wireless Router or Wireless Access Point. Once you have a wireless one, you should know the name of your router. That's what an SSID (Service Set Identifier) is.
Once you know this information you should be able to find your router on your PSP. Once you do you should have a password on your router so no one you don't know can use your internet. When adding a connection on your PSP you will also need to enter the password for your router. You can use WEP, WPA-PSK (TKIP) or WPA-PSK (AES). WPA-PSK (TKIP) or WPA-PSK (AES) have very high security and WEP has a lower security.
Once you have added your connection, just type an address and surf! Not all websites will load because some require too much memory.
Assuming you have Official SONY PSP Firmware, Update to the latest version by going to Settings>Network Update. Locate your router and use it as the network connection.
Download the needed files and update by going to Game>Memory Stick>PSP Update.
Once you finish Update, go to Network>Internet Radio>About Internet radio. It will take you to a website to download the files needed and will install to your Memory Stick.
To put music on your Memory Stick, the Music must be MP3, AAC, M4A or WMA format.
Open your memory stick on your computer by pluggin in a USB cable to your PSP and going to Network>USB Connection or you can put the memory stick in a card reader.
Once in the root of your memory stick, there should be a folder called "Music". Put your music in there or in one more folder inside that. Two folders inside of each other will not be playable.
Place videos in the "Video" folder on the root of your memory stick.
Videos need to be MP4 format. 368X208 Highest MPEG4 Codec, or 480X272 x264 or AVC codec.
Need a converter?
http://www.formatoz.com/
Its a free and very good converter. Try it
Reply if you need anything else.
Source: internet connection of psp
That's problem occurs when there is some problem with the firmware, and any some process under psp has running. you'll need pandora battery to solved the problem. when using pandora, you can go into service mode of your psp, then downgrading your psp back to default setting. what type of your psp? Slim or phat?
Please let i know if you experience any problems in the future. I hope i can make the appropriate adjustments, so do not hesitate to contact me. visit myBlog here.
The Pandora's battery (ultimate magic stick=Slim & lite psp) can be used to downgrade any PSP of
any version or to recover from a brick (such as blank screen, Bsod=blue screen of death, & any err on firmware).
To convert the Memory Stick and
battery another PSP which is able to run 1.50 homebrew is needed. After
the downgrade/unbrick service has been completed, the Memory Stick and
battery can be restored for normal usage.This software is free, &The whole process is simple enough, the good developers got all bases covered, even instructions on installation. you can get it from here: http://www.psp-hacks.com/file/1282
Comment by Albert T, its are the same as above. for old style psp (fat) get a guide : http://e-arena.blogspot.com/2007/09/pand...
Source: PSP wont turn on
You can replace the switch else you just have to open ur psp and in the left corner you will be able to see a switch u just have to push it up.Now the wlan switch will allways be on and u could use it whenever u want... The best thing is to give it for a service...
Warning:Opening ur psp will cut ur garuntee....
Source: i broke my wlan switch
PSP wont turn on
I put Yu-Gi-Oh! GX Tag Force in my psp, pressed on home and then clicked on the box saying Yu-Gi-Oh! and a msg appeared saying "...
ps2 stops at the "play station" logo
If yu try a DVD move it says disc error. If yu try a game it stops at the "play station" logo? Help!
My xbox 360 says i need an IP adress
Well i have an xbox360 and I tryed to connect the cable the Xbox 360 has with it to my laptop, which has wireless Internet, but it says i...
psp letters keep flickering when i try to connect...
well heres the problem someone modded my psp and it is very great but theres one problem, everything goes great until i have to type in my...
how do yu hook up xbox live on internet
Tips for Helping bryanfelix95 With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
when i download game and put it in PSP and i open...
when i download game and put it in PSP and i open psp it doesn't show any game no games
how put a them on psp?
i put a them om memory card psp i name it them and when i open the psp when i see the them it is not there what should i...
I haven't used my PSP for about a year so...
I haven't used my PSP for about a year so it's really dead. Now that I plug it in the orange light...
new psp wnt turn on after over 6 hours of charge
its a used psp i bought few days ago and its been charging for like 24 hours now.was tried after 6 hrs and wuldnt turn...
Related Topics
Fix-O-Meter
16
16 people viewed this problem
- 0 people are following this problem. Be the first!
Top Sony Video Game Console Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
Assuming you have a DLINK wireless router; go to your internet browser and type in: "10.1.1.1" without inverted commas and if it asks for username and password, the default is "admin" and "admin"
Once your in.
Click HOME and click Wireless
Select Enable AP (Access Point) Tick
The SSID is the name of your router. You should change it to be able to determin which router is yours.
Leave Channel on 6
Leave SSID Broadcasting On Enabled
Use WPA or WPA-PSK whioch is supported on PSP
WEP should be on Enable
Leave Key Type on default
Key length can be chosen
Enter a key in Key 1 textbox
Click Apply and Reboot your router.
If this is not the the router you use, reply and ill give you instructions.
