Question about Zebra LP 2844 Thermal Printer
Zebra LP 2844 parallel communication problem
My printer doesn't communicate with PC by parallel port, USB and serial communic. is ok. What's the issue? Of course everything is connected, the LPT port is ok, the printer is ON.
If anyone had a solution, I would be glad for a contact.
  • 57 Answers
The printer is installed on the PC using a specific port. If it's installed on the USB port, it won't work on the parallel port. Do you have this printer installed 3 different times? Need more details such as how was it installed the first time? And if it's working on the other 2 ports, why does it have to work on the parallel?
Posted on Apr 24, 2008
Want to use zebra 2844 for kitchen printer.
The software might need to have the port set for the correct com port/
Feb 22, 2014 | Zebra LP 2844 Thermal Printer
I'm not getting communication from the RS-232. Is there a setup I need to do or something?
To setup connection first find serial settings by:
Hold feed button whilst switching on label, will then print configuration and do a calibrate.
from the configuration print find settings for serial port format is something like " Serial port : 9600, N, 8, 1 "
set your PC to the same settings. This should work just fine.
Jun 18, 2011 | Zebra TLP 2844-Z Thermal Label Printer
I need to add network to 2844 printer currently USB/Serial
You need to buy the zebranet PS2 print server
P/N G46692 External PrintServer II. It will plug into the parallel port. they just stoped making them but they are still for sale at zebra resellers. here is one at random from google
resize?sq=80&uid=1127727233 ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II
more at ZDTronic.com
ZDTronic.com $160.50
  • product
ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II $160.50 at ZDTronic.com
May 12, 2010 | Zebra TLP 2844-Z Thermal Label Printer
How do I restore factory settings to a zebra barcode printer LP-2844-Z
The ^default command has been added to the EPL2 commands, starting in firmware version 4.39. This command will set the printer back to factory settings as long as the printer is in page mode. The command is not supported in line mode at this time. The command is case sensitive.
Syntax: ^default.
You can send the command to the printer via the parallel or serial port.
Parallel:
Open command prompt (DOS prompt) See windows instructions for details.
At the prompt type:
ECHO ^default>LPT1 <enter>
Serial:
Assuming standard communications on the printer of Baud 9600, No parity, 8 bits, 1 stop bit and use of COM 1:
At the prompt type:
Mode Com1:9600,n,8,1 <enter>
ECHO ^default>COM1 <enter>
Feb 02, 2010 | Zebra LP 2844 Thermal Printer
I have a cash management system Royal alpha
I find that a lot of serial to usb or parallel to usb converters do not work due to the fact you can't get bidirectional communication. In every case I have dealt with, the resolution was a dedicated port card to physically install a parallel or serial port in the system.
Dec 07, 2009 | Computers & Internet
Lp 2844 will not work with my new laptop
You need a piece of software to create a Virtual com port, make sure you have the comms set correctly 9600, n, 8, 1 and print to that port, you will find it clearly marked in Device Manager. You can get a parallel to USB cable then you can use your driver set to LPT1
Nov 05, 2009 | Zebra LP 2844 Thermal Printer
My printer and computer are not communicating at
If the software is installed for the printer, there is only two things you can do.
Plug a USB device that's already working into that port. If it's working, It'll install the driver.
If it's not working, try another port. Change your USB cable to another one. Also, in the BIOS, set the USB port to high speed.
Aug 09, 2009 | Zebra LP 2844 Thermal Printer
Am having problem communication with the printer through the USB port.
There should have been some software that came with the cable. This is a utility that has to run on the system to enable the printer to communicate across the USB to paralell jump.
May 25, 2009 | Zebra Eltron LP 2824 Thermal Printer
Printer doesn't work when use usb parallel converter.
Forget about using parallel converter. Just use the USB cable it works best anyway.
Easiest way is this.
1: Turn printer on. (Green light. ready to print)
2: DISCONNECT the usb cable from the PC.
3 DELETE the Zebra LP2844 & Zdesigner drivers from the printers & Faxes folder. Just highlight them and hit the delet key. Don't worry Iknow what I'm doing.
4: Plug in your USB cable back into PC.
Just sit back and wait, your PC will automatically detect your printer and re-load your driver software.
Send me the cheque now!!
May 12, 2009 | Zebra LP 2844 Thermal Printer
LP 2844 not working with Create-A-Label v3.04
If you are using CAL (Create A Label) you must have a device called a "Dongle" plugged into your parallel (or USB) port. This acts as the activation key for CAL. If there is no dongle then CAL only works in demo mode. That's why printer Icon stays grayed out. The "Dongle" normally plugs directly into the parallel port and one end of the parallel lead plugs into the "Dongle" while the other plugs into your printer.
I would suggest that you download "Zebra Designer" software from the Zebra Website..This will work without any activation.
If you use ZD you must use the correct ZDesigner driver. (Install automatically as part of ZD setup) This driver only works with ZD.
If you need to link to a database then you will have to BUY label software. Zebra Designer Pro, or Nicelabel, or Bartender....etc.
Oct 07, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
451 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
