Question about Canon CLC 1120 Color Copier
E071 0003 error code is e071 0003 can anyone help for this thx in advance
  • Anonymous Apr 27, 2008
    clc 1120 error code E803
  • 47 Answers
E-071 0003: There is an error in the rising edge timing of the signal plate detected by the C sensor.
The transfer drum isnt rotating or the machine "thinks" the drum isnt rotating. Check for mechanical interferance and check the drawer connectors for paper and debris
As for the guest with the E-803 error, thats not really the same thing at all. I guess both error codes have a "3" in it but thats about all.
E-803: During operation the CPU does not detect a 24V output for 5 sec while the transfer unit, the left door, and the delivery door are closed.
Check the aformentioned doors and switches but most likely it is the power cut relay that is faulty. The relay is located on the lower left hand side beside the main power supply. The relay contacts become pitted and burnt over time.
Posted on May 07, 2008
Canon CLC 1180 Copier Error Code: E071 0007
E071 / E072 / E073
Transfer Frame Connector
Poor Contact due to toner scattering around Transfer Connector
Replace Connector FG6 0948
TD Cleaner assy
Motor M8 being overloaded. Drive shaft from motor goes through long plastic bearings these were getting clogged with toner and oil
clean drive shafts
Transfer driver PCB
Static discharge onto transfer driver from peeling off old TD sheet too fast
Replace Transfer Driver PCB (FG6 - 2579) Remove old TD sheet SLOWLY to prevent problem.
Oct 21, 2011 | Canon CLC 1180 Copier
SC-810 ERROR E071
hi there
concern ERROR ( E071 ) means Disconnection o motor output connector.
please check the motor output connector for loose connection and disconnection. otherways means IPM module is defective.
if you need more help please contact me.
BEST REGARDS
ASHRAF ABOZID
aabozid@hotmail.com
Dec 24, 2010 | Juki DDL-8700
I replaced the drum and an error comes up that sayssystem error E071.
type worldoffax.com/errorcodes, a page will come up then click on world of faxes error codes and trouble shooting. everything should be right hear on this page.
Aug 30, 2010 | Canon Office Equipment & Supplies
I got an error code on my canon clc 1100:
E071 0007
Aug 19, 2010 | Canon CLC 1110 Copier
I get error code e071 and there is no paper pickup can you help me ??
plz check inside the paper try there will be sheet like xerox sheet check it if it goes out put it back in correct position
Nov 17, 2009 | Canon LASER SHOT LBP-5200 Printer
How to fix canon code E071
Here is an answer from DZJOLLA:
"hi there
well ive had years of experience on these machines and seen this error loads so ure in lucksmile.gif
1st off are u a tech? if not do not read any further as this post will only make sense to a tech.
i can only imagine this machine is old now. most of the time its the connectors that cause the e071 error. how many prints has copier done? have the connectors on the carraige frame and on frame of machine ever been changed? if not thats more than like causing your issue.
is your TD unit spinning ok? or is there resistence somewhere, if so this might also cause this error. the manual points to the 3 timing sensors in the TD unit IE. timing plates arent arriving on time for those sensors, but again everything relates back to the connectors as this is where it gets its voltage from. blow the sensors out as well.
change the connectors mate would be my 1st conclusion for that errorsmile.gif let me know how u go please...
the other errors arent even coming up in the manual which points even more to the connectors.:
Apr 28, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Canon color imageclass mf8180c, Iam getting '' SYSTEM ERROR E071
I had the same error message E071. Had to call out an engineer who diagnose the Drum 701 was leaking toner - this got on the electrical contacts at the bottom of the drum. He cleaned the contacts on the drum and in the machine - put my old Drum in there and all is OK. The drum was 9 months old and not had much use so I am trying to get a replacement from Canon under warantee.
Apr 06, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Canon ImageClass MF 8180c Error Code E071
i had the same problem, had to replace the drum unit
Mar 10, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
Canon MF8180c
E071 error stands for ITB position sensor fault,so you may try to check if the ITB belt is ok, if there is no paper left overs or similar, but this error can occure when the main board ( dc controller ) is defective.
Nov 01, 2008 | Canon imageRUNNER C3200 Color Printer
Canon CLC 1120 Color Copier Logo
261 people viewed this question
old marine
old marine
