I am trying to set up second computer I have installed the wireless pci card on second computer and it still is not working. What else can I do to correct this problem.
  • 1,183 Answers
Check in device manager to see if your wirless card is getting detected.
Also check if your are putting the correct name of your network and putting the correct network key(ie encryption key)
Posted on Apr 15, 2008
I bought a DELL optiplex 745-small form in Japan a couple of years back (Service Tag is HXXR8BX)and always used the pc with a LAN cable. Now I was tranferred to the netherlands and the house I live has a...
Below you will find 2 options to add wireless connectivity to your desktop.
A. USB Wireless LAN
http://accessories.us.dell.com/sna/category.aspx?c=us&l=en&s=dhs&cs=19&category_id=6638&nf=44907%7e0%7e598274&sort=-ratingaverage&~ck=anav
This is the easiest solution to add a wireless connection. Simply connect the USB adapter, install the software it comes with and connect to the wifi signal, once configured.
B. PCI/PCI-e Hardware Wireless LAN
http://accessories.us.dell.com/sna/category.aspx?c=us&l=en&s=dhs&cs=19&category_id=5821&nf=44907~0~598274&sort=price&~ck=anav
Adding a PCi/PCI-e expansion card requires opening your computer and manually installing the card, then installing the driver/software and configuring the wireless access. These cards typically offer faster speeds and stronger radios to communicate with wifi signals better.
NOTE: There are 2 types of wireless cards in the second link: PCI/PCI-e and Half-Card/Mini-Card. Half/Mini-Card adapters are for laptops only - they will not work on desktop computers!
Both USB or PCI/PCI-e offer excellent solutions to getting wireless access from your desktop. Furthermore, since it can be purchased through Dell.com, they can ship anywhere worldwide, so delivery to the Netherlands should not be a problem.
If you have any questions, you can always contact Dell's Customer Support by telephone and be sure to give them your service tag number, that will ensure that you get only the parts that match your desktop.
Aug 14, 2010 | Dell OPTIPLEX 745 PC Desktop
I have tried to add PCI wireless cards, and a dual VGA card to my 753n. Each time I install the card the computer will power up, but not even get to the BIOS screen. I have removed and reinstalled the CMOS...
One possiblilty is the VGA card may be bad. Try installing just the wireless card and booting your system, if it works install the VGA card. The other option, if you have not done so is to first install the software that came with each card and then install the hardware and reboot.
Good Luck
C2Solutions
Feb 04, 2010 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
Computer Will not start with my new pci device
Remove the card and install again making sure it goes all the way in..( and/or installing on another slot.. Make sure theres no hair or dust goes in the slot.. If problem persist, 1. You probably need to access bios n configure/enable the pci ports.. 2. The power supply is insufficient.
Nov 13, 2009 | Xterasys Wireless PCI Card Ethernet...
Driver installer doesn't install drivers. :S Gigabyte GN-WPKG
The problem could be caused,as you are also missing the chip-set drivers for the motherboard. You need to download and install the chip-set drivers for the motherboard first. Then install the wireless card driver and it would solve the problem.
Sometimes the conflict is also caused, due to faulty installation of the os.
1. Remove the entries of the PCI, from the device manager. 2.Remove the wireless card from the computer.
3.Restart the computer. 4.Shut down again, 5.Put the card back in and then install it one more time.
Thanks
Proton
Thanks
Proton
Apr 11, 2009 | Gigabyte GN-WPKG 802.11g/b Wireless...
Addding second computer
1)install a good internal wireless pci card(best is linksys in my opinion)
2)you could also use a usb wireless adapter.
3)hardwire the pc to the back of the transmitter.
Dec 23, 2008 | Linksys Wireless-G Broadband Router
My Wireless-G WMP54G card keeps Installing Dell Drivers
I hate to say this, but on Dec. 26, 2008, I called Linksys and they said that they don't make a PCI wireless adapter that works with sp3. Mine just rebooted the computer incessantly.
Nov 09, 2008 | Linksys Wireless-G WMP54G 802.11g/b
System do not reconize the PCI card
Does it ask for a driver to be installed? Or have you got the wireless version of the mobo that needs an ASUS WiFi-b add-on card with an omni-directional antenna?
Like on the previous version of the mainboard, the PCB contains five PCI slots and an exclusive WiFi slot, in its left part. By the way, when you install the original WLAN card from ASUS into this slot, the last PCI becomes unavailable. Now let’s examine the card, too.
The card supports the wireless networking protocol IEEE 802.11b, describing data-transfer rates up to 11Mb/s. Using the software that accompanies the card, you can use it in the Ad Hoc as well as in the Infrastructure mode, and the card can perform the functions of a programmable access point, providing connections to 31 clients. Thus, the owner of the WiFi-b kit can easily deploy wireless networks and connect to existing ones.
Jul 11, 2008 | ASUS 802.11G WIFI-G 54MBPS WIRELESS LAN...
WIRELESS PCI 54M G NETWORK LAN ADAPTER CARD 802.11 b/g INSTALLATION
try to unplug it all modem roughter then modem roughter computer on see if its working do repair also thx nick
Feb 05, 2008 | Computers & Internet
Error code 10 Device cannot restart
Generally a code 10 refers to a dead component unfortunately.Although the card will be recognised.
Aug 29, 2006 | U.S. Robotics MAXg USR5417 802.11g/b...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
