Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Right side of faxes (or copies) have 1-1/2" black line
Have changed drum and toner, wiped glass inside...nothing has helped.
  • Khillman Apr 18, 2008
    I have the exact same problem but i do get 4 pages printed first --- clearly.
    Genius:
  • 2,120 Answers
Try changing the Drum Unit again....it cannot be anything else besides a worn out drum cleaning blade.
Posted on Oct 26, 2008
Right side of printed page is faded
pull out your drum unit and look inside machine above where the drum would be. you should see a black assembly that runs left to right with a "****" glass. may need a flashlight. clean that glass off with a clean rag. sometimes toner "scatter" will get on glass and cause this.
let us know,
razors
Mar 26, 2009 | Brother IntelliFAX 4100 Laser Fax
Black vertical lines issues on Samsung multifunction fax SF
Black lines are usually a sign that you have toner on the laser slip glass which is usually situated above the drum unit, its just a little bit of glass if u give this a wipe and get toner on ur finger or rag then thats probably what wrong. If you don't I would look at your drum unit as it might not be cleaning correctly, which would mean getting a new one.
Hope you find this info helpful. Cheers
Dec 13, 2008 | Samsung SF-830 Plain Paper Laser Fax
Clear vertical lines when printing that do not clear up by shaking toner
does it do it on copies and internal test as well???
1- check the thin strip of glass inside the machine and make sure it is clean, look at the toner are there any line on there that corresponds?? yes then replace.it could be coming from the drum or toner. I beleive the drum is a seperate piece from the toner
Aug 27, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Black line on faxes
Check carefully the glass, a very small point of ink or anything else can cause the black stripe. usually  it is that the problem. use windex to clean it.
Apr 15, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Black line need help
where you insert the drum, look in the machine on top there is a glass wipe it
Jan 22, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Inch and a half black line down page
not sure what model fax you have, did not specify.
1-check to see if there is a white metal plate opposite the glass.
is there any toner or dark marks on it ? clean or use white out to cover make sure it is dry before using.
2-check the black spongy roller inside the machine
3-it maybe that you have a two unit cartridge, one for toner one for the drum ( which is what it sounds like) pull out and check.
It should be a shiny cylinder, does it have a black ring around it?
4- the last thing to check is the fuser, on its way out of the fax it passes two rollers on on top of the other, it may be a little difficult to see, may have to remove a cover, how do they look?
Dec 13, 2007 | Office Equipment & Supplies
Copies here and recipients faxes: dark, lined
How long has the drum been in there?
try this:
1-take out toner, look and see if it is ok. do you see stripes on it?
2- look at the drum are there any black rings on it? ( you did not specify white or black lines)
3- where the glass is on the opposite side ( the part you lifted to clean the glass, look at it standing from the back. you will see a white metal plate with some springs in it if you touch it. this is the reference that the fax has if there is/are a black dot on it it will give you a black line clean carefully. if it is scratched use white out to cover and make white again.
For the darkness try making a copy in photo mode if it is still too dark change drum.
Dec 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
Copies and outgoing fax quality
your machine most likely has toner spills in it.
if you send faxes face side down follow these instructions ;
1- take out toner
2- look for thin glass strip on bottom inside the machine
3-wipe clean
if you make copies side up then do the same except look for glass strip on the upper side of machine
Nov 27, 2007 | Brother IntelliFAX 4100 Laser Fax
BLACK INK LINES ON INCOMING FAXES KX-FL511
It's time to change NEW DRUM UNIT..and that's why your Toner will Not Last Longer because unnecessary toner (the black lines) will be on the copy every time the fax comes or you make a copy.
Oct 01, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
124 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
