Question about InFocus LP640 Projector Multimedia Projector
Color not correct on project
I have reset the projector to factory defaults and I still have a green hue. Even if I am not showing an image it has a green shade to it and my blue is not really blue. IThis was a unit with heavy usage and my have a burnt lens. How can I get it repaired?
  • 563 Answers
Hi there
You will have to find your nearest InFocus repair centre.
But that said , it is the most expensive part on a Projector to have repaired , because they will have to replace it.
My advice would be to rather purchase a new unit.
Posted on Apr 16, 2008
Discoloration
the Lcd panels are defective, you need replace the Lcd panels (3 pieces, red, blue,green)
the model of the panel is LCX085A, (unit price is USD300)
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,motherboard ,powersupply,ballast... with high quality and competitive price.
Hope to cooperate with you.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 20, 2014 | Sanyo PLC-XP200L Projector
Sharp XR1S It projects the image on screen, use to show the correct color. last time the image was projected but in pink hues. is this an adjustment issue or is the lamp going or gone?
hi,
first of all check the tint setting on your projectors picture menu.
if not get the correct color then, your projector is a dlp projector that means it have a color wheel in side. if the synchronization of color wheel is not correct this problem can occur. there is a sensor for couting the rpm of color wheel. also have a black mark on the color wheels rotating portion. the sensor scene this black mark for making count. if there is any dust in that portion it will make difficult to the sensor making the counts. you have to remove the color wheel to clean the same.
i have added a video how to clean the color wheel . not the same projector.
ok
Feb 02, 2011 | Sharp XR-1S Multimedia Projector
Green verticle line on right side of image
Your color convergence is out of adjustment. You can adjust yourself with a service manual telling you how, or take it to service shop and pay about $400.
Jan 17, 2010 | Sanyo PLV 60HT Multimedia Projector
Yellow green display
you may have a bad cable. if it was an internal problem, the menu wouldn't be the correct color. you may also want to reset the settings to factory default, just to cover the resolution issue.
Jan 13, 2010 | InFocus LP70+ Multimedia Projector
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Nec projector vt 660
could be bad bulb is it setting in right is coler wheel freeley moving
Oct 06, 2008 | NEC VT47 Multimedia Projector
Mitsubishi XL8U Projector
Hi terry2421
No this is not the bulb. You will have to get the Mainboard repaired at a service provider. Losing signal and a discolouration showing up is a clear indication of a faulty Mainboard.
Get a quote first , because some service providers overcharge on these sort of repairs. The most you should pay is $150.
May 20, 2008 | Mitsubishi XL8U Multimedia Projector
Colour problems with projector
In short If the reds show as red, The greens show as green & Blue shows as blue. I would say thats as good as it can project. It's hard to judge color without seeing it for ones self but usually DLP projectors that use a colorwheel do not have perfect color.
Feb 13, 2008 | Office Equipment & Supplies
Hitachi cp-x430?
My projector is not Hitachi but I had a similar problem. My manual suggested checking under "signal" to make sure that "auto" was "on". The thing is, there were two places where "signal" came up on the menu. I had to go under "set-up" to "signal" and then I was able to correct it by setting "auto" to "on". I hope this helps.
Nov 01, 2007 | Hitachi CP-S210 Multimedia Projector
InFocus LP640 Projector Multimedia Projector Logo
208 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
