Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Bad ice taste/smell
Ice has a smell/taste sorta like bleach, what causes that?
  • 1 more comment
  • Anonymous Jun 03, 2008
    Water from door tastes bad, probably ice too. Recently changed filter, but noticed before change.
  • renderma Nov 30, 2008
    Is there a reservoir in the refrigerator that needs to be cleaned? My son's is older and the taste is worse. My refrig is 4 years old and the taste is getting worse.
  • Anonymous Dec 12, 2008
    Bad taste and oder from water dispenser in door. replaced filter and STILL has same problem
It's not town water. It's something in the refrigerator. My unfiltered tap water tastes better than the Whirlpool channeled ice and water. Moreover, a Brita faucet filter does a wonderful job in removing all tastes from my unfiltered water. I change my Whirlpool filters as often as required.
Posted on Aug 16, 2008
    Genius:
  • 1,073 Answers
Town water
Posted on Apr 17, 2008
Why does the ice in my freezer taste and smell bad even though I changed the filter?
OLD PIPES NEED REPLACING,OR DID HOUSE WATER LINES SET A WHILE ,HOW LONG DID ICE MAKER NOT BE USED .CAN YOU REMOVE ICE MAKER AND CLEAN?. MOLD MAY OF ESTABLISHED OR RUST.TAKE WATER LINE OFF BACK THIS IS EASIEST. AND RUN 5 GALLONS OF WATER IN A BUCKET.TEST WITH A CLEAR GLASS WITH SOME FROM THE FLUSHING OUT WATER.IF IT DOES NOT CLEAR UP,HAS THE WATER COMPANY RAN TEST ON THEIR PRODUCT.THEIR MIXTURE OF FLUORIDE AND SUCH MAYBE FUNKY.DOES WATER LOOK CLEAN.GET CLEAR GLASS,FILL WITH ICE AFTER IT MELTS SEE IF THINGS AT ALL ARE FLOATING.DO SAME TEST AFTER YOU RUN 5 GALLONS OF WATER OUT OF THE LINE.ICE,MELT LOOK.HOW DOES WATER TASTE OUT OF DOOR IF THAT TYPE.IT CONFIRMS WATER LINE OR OUT OF FLUSHING WATER.IF IT TASTE OK FROM FLUSHING WATER THE SOURCE IS AS DESCRIBED IN THE FIX...
Jul 25, 2014 | Whirlpool Refrigerators
KitchenAid fridge ice cubes taste and smell bad
Permanently place a black coal in your fridge to avoid bad smells.
Apr 12, 2012 | KitchenAid Superba Architect KSCS25INSS...
Freezer area smells and ice cubes and butter taste off?
It sounds like the ice maker if equiped. Remove Ice bin and clean out,and try a lite spray of bleach or vinegar (don't mix) If the smell is still happening and comming from ice you may want to install a inline filter.
Jul 26, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Our model number is the GSS25JEPA and the ice in the ice machine leaves a after taste seems like it is a chemical taste and strange smell on the ice that the machine makes. I am not sure what to do.
I would suspect the water supply to the refrigerator. After it has sat without use over night at least, turn the water off and open the fill line at the refrigerator and place it in a clean container. Turn the water on gently for a very short time then check what you have in the container. More then likely it will contain what you are saying is in the ice. If not then you need to thoroughly clean the freezer and ice maker, my preference is to use a mild soap and bleach solution. The bleach would kill any mold that may be present.
Good Luck,
Gilshultz
Dec 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker has bad taste and smell
Add a cap of Miltons or a couple of granules of pool chlorine. Allow it to stand for a couple of hours and then drain.
Mar 08, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Bad tasting water and ice from refridgerator.
i agree with rpbuice but in addition to flushing the water line you may need to replace the line then using the water dispencer run out about a gallon of water thru the door. this will clear the reservoir of bad tasting water. for the i/m throw out all of your ice then let it make a couple of batches and throw out that ice as well be sure to clean your ice bucket very good to remove any lingering tastes from the old ice.
fyi bad tasting water is generally from bad water supplies. good luck..
Jan 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
ADMIRAL FRIDGE MODEL AS22N8DE WATER AND ICE TASTE BAD
change water line into refrigerator Alge will start to grow, also flush line into refrigeratorwith a little bleach to kill any alge in the line. It will take a while to get bleach
Sep 26, 2008 | Refrigerators
Ice maker problem
let it run its caused by stagment water in the system it will clear over time.
Feb 09, 2008 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
605 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
