Question about GE PSW23PSRSS Side by Side Refrigerator
Defrost controle How do you get the controle into a manul defrost to check out the board.
    Genius:
  • 1,073 Answers
Caint do it you can read the defrost circuit easyier by going into the freezer and ohming out the heater, btw the stat that is on the evaperator coil will read contunity up to 145 f it is not a bi-metal it is a over temp sensor
if you have a defrost issue check the heater of ok then go to the sensor also located on the evap coil
if it reads contunity then mother board located on the back of the ref
Posted on Apr 17, 2008
Fixya manuals
It doesn't defrost
  1. Defrost control board
If the defrost function is not working on your refrigerator it could be an issue with the defrost control board. This control board oversees several internal conditions and regulates the activation of the defrost cycle. A faulty board can be the primary reason your refrigeration unit is not transitioning to the defrost cycle. Over time, the buildup of ice on the evaporator coil will prevent the refrigerator and freezer from maintaining proper internal temperature. It is advisable to first check the defrost heater and the defrost thermostat for continuity prior to replacing the defrost control board.
  1. Main control board
A possible cause for a refrigerator not defrosting, especially on more modern units, is the main control board. The main control board acts as a "brain" for the unit controlling the defrost cycle, compressor, and run time, and essentially acts in place of the defrost timer. The control board can be tested using an ohm meter for functionality and will need to be replaced if bad.
  1. Defrost timer
If the refrigerator is not defrosting the timer could be malfunctioning. Numerous times throughout the day the defrost timer should cycle the defrost heater on as a means to melt frost buildup on the evaporator coils in the freezer. If this timer does not cycle on, then it may be faulty and require replacement.
  1. Defrost heater assembly
If your refrigerator is not defrosting accurately this could be an indication that your defrost heater assembly has failed. This could cause the frost to accrue on the evaporator coils, eventually blocking the airflow resulting in the unit not cooling properly. The defrost heater assembly can be monitored for continuity using an ohm meter and will need to replaced if there is none present.
  1. Defrost thermostat
Another cause of your refrigerator not defrosting is a faulty defrost thermostat. A requirement for the defrost heater to activate to melt away frost on the evaporator coils is a functional defrost thermostat. The defrost thermostat senses the temperature of the evaporator coils and initiates the thawing process by activating the defrost heater. If the thermostat is faulty, it will not sense the lowering temperature of the coils and will not turn on the heater, resulting in an advanced frost build-up. The defrost thermostat can be checked for continuity by using an ohm meter; if there is no continuity the damaged part will need to be replaced.
  1. Defrost sensor with fuse
Another possible cause of a refrigerator that does not defrost properly is a defrost sensor with a fuse. If the defrost sensor fails, the fuse acts as a one-time-only fail safe for the sensor -- if the sensor does not shut off the defrost heater, the fuse will blow when the set temperature is reached. This safety precaution is to keep excessive harm from your unit by the heater and is a one-time use, resulting in the replacement of the entire defrost sensor.
Defrost drain problems
  1. Clogged or freezing defrost drain
If you are experiencing defrost drain issues, it is possibly due to a clogged or freezing drain that is blocking water flow to the bottom of the freezer. This will cause the defrost water to drain and drip down to the bottom of the freezer section. To correct this issue, thaw any ice or remove debris that could be causing the clogged drain or replace the drain heater.
  1. Drain heater
If you are experiencing defrost drain problems, inspect the defrost drain heater. A dislocated or burnt out drain heater will result in the drain tube freezing over. Attempt to return the part to the designated position or replace the damaged part to correct the issue. Search Over 2 1 Million Appliance Parts
Sep 06, 2014 | GE Monogram ZIRS36NM 36'' Stainless All...
Why mu refrigerator rrtg21pabb ia working but not freeze
If the refrigerator is not defrosting, the defrost control board might be defective. The defrost control board monitors several conditions and determines how often to run the defrost cycle. If the board fails, the refrigerator will not go into the defrost cycle. Eventually, ice will build up on the evaporator coil and then the refrigerator and or freezer will not stay cold enough. This will depend on where the evaporator is located. It's prudent to check the defrost heater and defrost thermostat for continuity before replacing the defrost control board.
Aug 27, 2014 | Haier RRTG21PABB 20.7 cu ft Two Door...
Afb910 freezer not freezing
If the refrigerator is not defrosting, the defrost control board might be defective. The defrost control board monitors several conditions and determines how often to run the defrost cycle. If the board fails, the refrigerator will not go into the defrost cycle. Eventually, ice will build up on the evaporator coil and then the refrigerator and or freezer will not stay cold enough. This will depend on where the evaporator is located. It's prudent to check the defrost heater and defrost thermostat for continuity before replacing the defrost control board. If that is not the problem then the coil might have a hole in it and needs repair and coolent rechrge.
Aug 26, 2014 | Freezers
Samsung refrigerator defrost problem
Check the defrost drain hose. If it is plugged, the water from defrosting has no place to go, so defrosting doesn't do much.
Also, make sure you have power to the defrosting circuit (you may have a problem with the wiring). The simplest and safest means is to do a continuity check of the wires between the control board and heater with the refrigerator unplugged, or unplug the heater connection to the control board and measure the resistance of the heater through the connector(s). If it is open or very high, examine the wire terminals for corrosion. If the defrost control board is separate from the rest of the refrigerator control system, check for power coming into the board.
May 12, 2014 | Refrigerators
Lg lfx25960sb
The main control behind fridge would most likely control defrost
Nov 12, 2017 | Refrigerators
Neff integrated fridge freezer
test this steps and fix it, use the VOM. God bless you
  1. Defrost control boardIf the defrost function is not working on your refrigerator it could be an issue with the defrost control board. This control board oversees several internal conditions and regulates the activation of the defrost cycle. A faulty board can be the primary reason your refrigeration unit is not transitioning to the defrost cycle. Over time, the buildup of ice on the evaporator coil will prevent the refrigerator and freezer from maintaining proper internal temperature. It is advisable to first check the defrost heater and the defrost thermostat for continuity prior to replacing the defrost control board.
  2. Main control boardA possible cause for a refrigerator not defrosting, especially on more modern units, is the main control board. The main control board acts as a "brain" for the unit controlling the defrost cycle, compressor, and run time, and essentially acts in place of the defrost timer. The control board can be tested using an ohm meter for functionality and will need to be replaced if bad.
  3. Defrost timerIf the refrigerator is not defrosting the timer could be malfunctioning. Numerous times throughout the day the defrost timer should cycle the defrost heater on as a means to melt frost buildup on the evaporator coils in the freezer. If this timer does not cycle on, then it may be faulty and require replacement.
  4. Defrost heater assemblyIf your refrigerator is not defrosting accurately this could be an indication that your defrost heater assembly has failed. This could cause the frost to accrue on the evaporator coils, eventually blocking the airflow resulting in the unit not cooling properly. The defrost heater assembly can be monitored for continuity using an ohm meter and will need to replaced if there is none present.
  5. Defrost thermostatAnother cause of your refrigerator not defrosting is a faulty defrost thermostat. A requirement for the defrost heater to activate to melt away frost on the evaporator coils is a functional defrost thermostat. The defrost thermostat senses the temperature of the evaporator coils and initiates the thawing process by activating the defrost heater. If the thermostat is faulty, it will not sense the lowering temperature of the coils and will not turn on the heater, resulting in an advanced frost build-up. The defrost thermostat can be checked for continuity by using an ohm meter; if there is no continuity the damaged part will need to be replaced.
  6. Defrost sensor with fuseAnother possible cause of a refrigerator that does not defrost properly is a defrost sensor with a fuse. If the defrost sensor fails, the fuse acts as a one-time-only fail safe for the sensor -- if the sensor does not shut off the defrost heater, the fuse will blow when the set temperature is reached. This safety precaution is to keep excessive harm from your unit by the heater and is a one-time use, resulting in the replacement of the entire defrost sensor.
Read more: http://www.appliancepartspros.com/repair-help/refrigerator-repair-help.html#9#ixzz2aX5nUL00
Jul 30, 2013 | Refrigerators
I cant locate the defrost timer on my amana AFD2535FES. my freezer is cold but the fridge isn't
That model refrig. does not use older style parts sorry their is no defrost timer. What is uses is a control board to turn on the defrost cycle. Before replacing the defrost control board check the defrost heater and thermostat first. Check both defrost heater and defrost thermostat first using a meter to check continuty on both of them. If either the defrost heater or t-stat dont hav econtinuty they will be the problem. If both check good the control should be replaced. These pictures show where the defrost heater and thermostat are while or model will look different the location of them will be very similar RMOSTAT IT MUST BE COLD SO CHECK IT WHILE FROST IS BUILT UP AROUND IT.oldtech2332_11.jpgoldtech2332_12.jpg
Aug 16, 2011 | Refrigerators
Maytag PTB21BBGRB problem with refrigerator being too warm (58 degrees). Freezer is working. We have vacuumed the condenser fan & the fan is moving.
First look into rear of freezer on backwall for a layer of frost. If you find frost then the next step is to check the defrost timer found inside fresh food section Click here=> PTB21BBGRB Control Panel part #12 in large view is the defrost timer. There maybe a plastic plug below the control panel that you may pry away for you to manulally turn slowly clockwise until it clicks and the defrost will take place. If that works the the defrost timer part number is Click Here=> 68233-3 or here=> www.pcappliancerepair.com
that also offers solutions to their customers. On some service manuals contact Appliance911seabreeze.com If that does not work fo you then please let me know so we move to the next step. Thanks Sea Breeze
Aug 09, 2010 | Maytag MSD2734GE Side by Side Refrigerator
No cooling or compressor operation
Compressor and evap fan cycling are controlled by a circuit board as well as the defrost. It is all in serie - once your defrost kicks in contact is cut from the evap fan and compressor - once defrost is finished the switch reverts back to normal operation and your evap fan & compressor turns on.
Most common causes of this issue is either a defrost timer fault or control board (burnt resistor or bad board).
Inspecting and changing the control board will usually fix the issue - if your evap fan comes on after changing the board but not the compressor then you have a bad compressor.
If you have one of those units like some whirlpool/Kenmore/Inglis that have electronic controls in the refrigerator section, this is the board that controls the thermostat and compressor on/off cycling. The board behind your freezer is also connected to the board in your fridge, this one controls the defrost.
Sep 27, 2009 | Amana Refrigerators
MAYTAG MSD2656DEB DEFROST CONTROL
There is no forced defrost entry for your refrig. Yours has a ADC board in the upper right corner of the control area in the refrig section. The only way to initate defrost is jump the terminals on the board. Look at the wiring diagram closely before making the jump. The board energizes the heater thru the neutral side so make sure you dont jump line to this. I believe you jump L2 to Def
Dec 02, 2007 | Refrigerators
GE PSW23PSRSS Side by Side Refrigerator Logo
90 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
