Question about Sony Cyber-shot DSC-T50 Digital Camera
Shaking, whirring noise, E:62:10
When I turn on the camera, the screen just shakes, there's a whirring noise, the camera vibrates like mad, can't take decent pictures at all
  • 2 more comments
  • Anonymous Sep 16, 2008
    I have the same probelm the camera either shakes or flashes the E:62:10 error. Anyone know what can be done?
  • crozbing Sep 16, 2008
    I have the same problem the camera either shakes violently or flashes the E:62:10 error. Anyone know a fix? Please help.
  • wayne914 Oct 30, 2008
    Sometimes the camera vibrates like a message ******** and pictures come out blurred. What the?
  • tanjplas Nov 22, 2008
    shaking, whirring noise, E:62:10 problem,
  • 87 Answers
If you alsow get vibrationOn Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
Posted on May 26, 2010
  • MATORLIM Apr 12, 2011
    @AdiIngel
    Thank you sir for expert advice and i was able to repair my DSC-T50 after following your instruction.
    Indeed the magnet that was factory glued to the plastic mount came loose.
    Now my camera is as good as new. Keep up the good work and more power ti you sir!
  • ddemoo
    ddemoo Jan 02, 2013
    This was the most thorough guide I found. When I figured where every part is it actually was very simple to fix the issue. The magnet was loose but not anymore (*superglue). Thank you!
    Sergeant:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Sony Expert
  • 74 Answers
E:62:10 is a problem many users are experiencing using Sony camera's. Take a look at http://sony-e-62-10.tk/. A temporary solution is available at Sony 62 10 English
Posted on Nov 25, 2018
My Sony DSC T70 shakes & vibrates
i have a document with pictures explaining the process
Aug 25, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Sony Alpha A100 shakes when I turn it on
It's actually, believe it or not, an anti-dust mechanism. All Sony Alpha A100's (mine included) do a little shake/vibration to help keep the dust off. It's nothing to worry about unless it lasts for more than a second.
May 14, 2009 | Sony Alpha DSLR-A100 Digital Camera
Screen vibrates intermittantly. Also buzzing noise.
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
May 14, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Vibration of camera
02 Lancer ES help with diagnosing left side of Engine Vibration noise.
sounds more like a wheel bearing,jack the car up and support with axle stands,then grab the front left wheel at both sides and shake it hard.then grab it at the top and bottom and shake it hard.if a knocking can be felt through the wheel then its most likely a wheel bearing.repeat the test for the rear wheel.also with the vehicle jacked up,spin the wheel and put your ear next to it,if it makes a dry whirring or grinding sound as it spins,this is a symptom of a worn wheel bearing
Oct 11, 2008 | 2002 Mitsubishi Lancer
Camera Shake Warning
The camera shake icon is not 'smart' in that it doesn't actually measure camera shake, simply when shutter speeds drop below a certain level it will start to give you the warning. If the camera is on a tripod (and the subject is also stationary) you should use the absolute lowest ISO (ISO80 on the A650) to get the best results. Also, use the 2-second self-timer mode so that your pressing-the-shutter-button doesn't introduce shake to the photo (the camera will wait 2 seconds before taking the picture - long enough for all vibrations to stop). If the room is very dark (needing exposures longer than 1second), I recommend you use Tv mode to unlock the even-slower shutter speeds.
Aug 15, 2008 | Canon PowerShot A650 IS Digital Camera
Konica Minolta Dimage Damage
I had the same problem with mine, a minor fall cracked this, I disassembled the unit and one of the springs that hold the main sensor was broken, thus the sensor vibrates instead of "floating" when the camera is turned on. There are two possible solutions: The first is to get a faulty Z6 from eBay and get the parts (the main sensor assembly) and have it replaced. (If you are not comfortable working with 1mm screws, you'd better go with the parts to a camera repair shop and explain them the problem. The second solution is un-elegant but useful: If you disconnect the anti-shake circuit from the main board you won't have the annoying vibration at start, and the focus will work properly. I've done this and I am happy with the result (I rarely used the anti-shake feature, so I don't miss it). For reference, the anti-shake circuit ribbon is the one entering the mainboard just under the left side of the screen.
Ejoy.....
PS. if you have dark spots, chech that the sensor assembly is not too out of place or that a piece of the broken assembly is on the way. Realign it in place (and please don't touch it). and asseble tha camera back
Apr 05, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Sony Cyber-shot  DSC-T50 Digital Camera Logo
556 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Syzys
Are you a Sony Camera Expert? Answer questions, earn points and help others
