Question about Refrigerators
Top freezer/refrigerator model still under warranty. Water dripping constantly from top compartment thru channel that seems to be for cold air. Now all food - even commercial packing seems to be turning white from freezer burn
    Genius:
  • 1,073 Answers
No model number to look up
Posted on Apr 17, 2008
What a mess. The instruction manual (really lacking in detail) does not have part numbers or model description. Excess moisture dripping in refirgeration portion of unit (top freezer; bottom...
Yes it could, you will have to check your defrost water drain, if its plugged defrost water won't go to condensate pan under unit, instead will make its way down to refrigerator section
Jun 29, 2011 | Maytag Refrigerators
Have a GE Model #GSL22JFPHBS side-by-side refrigerator that the freezer is staying cold but the refrigerator part is not get cold.
its either the defrost heater or defrost thermostat or the defrost timer has gone bad and the evaporator is iced over,HINT: (you will see the inside rear panel in the freezer has frost on it) and the evaporator fan cannot blow cold air over the iced up coils in which case soon the freezer will start to seem warm too,if this isnt the case then its the damper vent door located between the freezer and fridge compartment that opens and closes to throttle cold air into the fridge from the freezer,sometimes they freeze shut from condensation or the door hinge breaks and it can jam shut,also if theres excessive water dripping into the fridge from the top it can be a plugged drain hole and water blocks cold air flow,also make sure the evaporator fan beneath the evaporator coil in the freezer is operating when the units running or cold air wont be pushed into the fridge either
Jun 27, 2011 | Refrigerators
JDC2389GES side by side fridge Water is leaking inside the freezer and pooling at the bottom.
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit....(it is located at the back wall or underneath the freezer compartment). Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator/freezer unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator/freezer compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Aug 25, 2010 | Jenn-Air Refrigerators
Water driping from freezer to refrigerator
If this is a side by side refrigerator, water dripping from the cold air return indicates a warm air leak, or some source of constant heat presence. Check to make sure doors close completely, that you have a tight seal along the entire edge of all four sides of both doors, that a light is not staying on when door is closed, that your ice maker is not stuck in the harvest cycle which turns a heater on underneath the ice maker, some other cause not determined without personal inspection.
Jun 28, 2010 | Whirlpool GD2SHGX Refrigerator
Water dripping in the refrigerator and freezes on the top shelf. It seems to be coming from the freezer compartment. There is a square piece of metal missing from the top of the main compartment. One can...
Removed everything from the freezes. Removed a false bottom from the freezer floor, 2 screws. There was an ice build up under this plastic bottom. I let the ice melt with the de-frost cycle (or frost free cycle). No more water dripping into the refrigerator compartment.
Dec 15, 2009 | Whirlpool Refrigerators
My Whirlpool Refrigerator Model ER8MHMXML02 isn't as cold. Help!
Freezer drain plugged and froze up also froze the air returns to frig
Aug 22, 2009 | Whirlpool Refrigerators
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Amana ARB1917CSR ? Refrigerator freezing food, (bottom) freezer working OK
I picked up on something you wrote within your problem description. "got the thermostat replaced under warranty" & "that worked for a while ". back in Aug of 2002. It's August of 2008 and your thermostat may have failed again. 6 years later... not so unusual. Anyway, since your fridge has a bottom freezer, there must be a pass thru between the freezer and the fridge compartment in an area you haven't examined yet. The fridge gets cold air delivered from the freezer to keep it cold thru this pass thru and many fridges have an adjustable flap that allows you to limit that cold air flow. Time permitting, can you do a more thorough examination of the fridge area ( side walls near crisper drawers perhaps?) or better than that, remove the drawers and look for that air duct pass thru. Once located, if it does not have an adjustable damper, try a little duct tape to limit the amount of cold air from migrating into the fridge compartment. Other options: Can you contact Amana customer support directly and get their support? That particular model has been discontinued by Amana but they should be able to support it. Not sure I added anything to what you already know. Gave it a shot thou...
Aug 06, 2008 | Amana ARB1917CSR Bottom Freezer...
Cold freezer/warm refrigerator
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Nov 12, 2007 | Frigidaire Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
