Question about Dryers
The motor on the Maytag Neptune MDE7550 Dryer is very hard to spin by hand. Is this normal.
  • ian1 Apr 15, 2008
    No I have removed the belt
    Master:
  • 788 Answers
Are you turning the motor directly or are you trying to turn it by rotating the drum? If you are trying to turn the drum it should be hard do turn due to the pulley and belt ratio.
Posted on Apr 15, 2008
    Genius:
  • 3,422 Answers
HI,
Please CLICK HERE.I hope this info. will help you.
Goodluck,
Please don't forget to rate the solution.
  • Priya darshan Apr 15, 2008
    Please scroll down and read all of the questions form the link which i gave you.
  • 2,322 Answers
You should not need to spin the motor by hand. Check if the belt is not to tight or the motor itself could be defective.
Maytag neptune dryer heats but wont tumble
When you spin it by hand, is there resistance? Can you hear the motor turning? In fact, when you switch it on and it starts to heat, can you hear the motor turning, or is it silent?
Sounds like the belt is broken, in which case there will be little resistance.
If there is resistance, it may be the motor or circuitry controlling the motor.
Aug 24, 2015 | Maytag Dryers
The voltage in my country is 230volts 50HZ I have a 120/240 volts maytag dryer what can i do to get it working
Normally the 240 volts rating is nominal and the device will run at 230 volts. The question is will the dryer run at 50 HZ? Check on the electrical rating tag on the machine. It may work. The motor may just spin at 50/60, 5/6 of the 60 HZ speed.
Gary
Aug 31, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Motor seems to be stuck drum wont turn when i cut it on
does it hum when u turn it on can u spin the drum by hand can u hear the motor running u may just have a broke belt
Jan 27, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Gas Dryer will not spin when turned on. Drum spins by hand. Makes a buzzing noise and elecrtical (burning) smell. Dryer is unplugged now and vent is clear.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 20, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Washer starts/ stops
recycle power. if problem persists, timer problem
Mar 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
Dryer wants to turn on but acts as if it has a brake stopping the drum
if you cannot spin the drum by hand then the motor is locked up
Jan 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer says 8.8. on display
Put a heating pad over the display panel. After 5 - 10 minutes, the display panel will return to normal and the dryer will work,
Jan 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer stopped spinning,timer still ticking,cannot get to restart.
Can you still hear the motor turning? If the motor is running but the drum is not then it is probably a broken belt or there may be something blocking the drum from spinning. The first thing to check is if the drum will turn by hand. If so, the next thing to check is if the belt has broken or slipped off. Although it is a bit cumbersome to replace, it is easy to diagnose. Unscrew the screws holding the back of the dryer on and pull the cover off. Look at the pulleys on the motor and see if the belt is intact. If those solutions don't do the trick, let me know and I will try to give you other options.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My Mother's Maytag Neptune front load washer has water left under the drum after the final spin cycle. I am not sure that this is normal. Please advise.
This is normal to hear water sloshing under the drum when machine is done washing and you spin the drum. This is part of their water balance method to help spinning procedure. I called a Maytag repair shop and they helped with my question.
Jul 23, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune on/off button wont stay on
You have to investigate where the burning smell came from. Start at the timer and then check the main board. Also check the drain pump.
Oct 23, 2007 | Maytag MAH6500 Neptune Front Loading...
Dryers Logo
75 people viewed this question
Top Dryers Experts
