Can not get the DVD player to record to our new LCD TV. Worked fine with the older CRT model. It will play OK. Do I need an upconcertter to make this work?
  • 652 Answers
If you will provide the manufacturer's name and model number of your TV and DVD, then we can help better..
Posted on Apr 15, 2008
  • 4,102 Answers
Hi what are you using to connect to the telly from the dvd recorder do you mean your trying to record what your watching and also is it cable tv or sky you want to recodr also what make and model of dvd is it
  • paul proctor Apr 15, 2008
    Depending on what you want to record you need to change the channel or input on the dvd recorder to the correct one if your recording from sky or cable then you need to have the sky or cable wired into the dvd recorder then a cable from the dvd recorder going iinto the telly so this lets you watch the sky or cable.
    Ok so the sky or cable needs to be in the input in back of dvd recorder then output from dvd into input on telly.
    Let me know ok
    Master:
  • 788 Answers
What kind of connection (wire) are you using to connect the DVD player to the TV? Is it composite (RCA, yellow), component (3X RCA, blue, red, green), S-video (Mini-DIN, like a computer keyboard or mouse connector), DVI (Like a wider computer monitor connector), HDMI (Wider and thinner but like a USB connector)?
I am trying to connect a new Toshiba SDK 1000 dvd player to replace an older GoVideo that worked fine as a player but lost its ability to communicate with remote (bad sensor, I think). I get picture and...
Is the TV PAL or NTSC? The symptom you are experiencing is what would happen if you are trying to play back a NTSC signal on a PAL TV or vica versa. If you have a scart connection on theTV then use a scart lead to connect from the DVD player to the TV. Set the DVD player for RGB output which is independent of PAL & NTSC.
Feb 20, 2011 | Televison & Video
YOUR TV DOES NOT ALLOW DISPLAY OF THIS PROGRAM THROUGH THE DVI IN
I solved the same problem by disabling SIMPLINK from OPTIONS menu. I own the LG TV myself. The LG TV comes SIMPLINK "ON" as default setting from the factory. Go to MEMU -> OPTIONS -> Turn SIMPLINK to "OFF". This should work....
Sep 18, 2009 | Toshiba D-R5 DVD Recorder
VHS to DVD-R dubbs fine: but won't play on SONY DVD player.
Please finalize burned DVD to play in another dvd player.
Apr 16, 2009 | Panasonic DMR-E75V DVD Player/VCR
Records fine want play on any other dvd player
it's the format it was recorded in,your other dvd's can't read it.see if you can go into your recording menu and see what format it's recording in.it should be ntsc.also is your other dvd players older models?
Dec 06, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Cannot view tv program while recording on VCR
Hi and welcome to FixYa,
Initially, pls set the Samsung LCD TV to the Source selection as if watching a playback evgen if you are going to do a recording.
If that does not work, pls postback manner of connection (cabling) from Cox digital cable system to Philips DVD/VCR to Samsung LCD TV LN-T3253HX/XAA .
Good luck and Thank you for using FixYa. Happy Holidays.
Nov 15, 2008 | Philips DVP3345V/17 DVD Player/VCR
Samsung DVD-SH855 DVD Recorder 250GB HDD playback freezes
Samsung dvd sh-855 i have the same problem wiht freezes when recording on timer mode.Recording in timermode with TV on is OK. But only connected whit HDMI cable, Component is OK in all modes!!!
My recorder is a XXE model = scandinavian.
Do anyone have a solution Please
Apr 20, 2008 | Samsung DVD-HR720 DVD Recorder
Getting a dvd player to record vhs to dvd
The RF converter takes the Red/White/Yellow as INPUTS and converts them to either channel 3 or 4. You need to go the other way. You need a tuner or another VCR to convert from RF (channel 3 or 4) to a standard AV signal (Red/White/Yel).
Dan
Mar 19, 2008 | Sanyo VHR-5431 VHS VCR
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
SONY TV FROM FLORIDA
We hooked it up with another DVD player, no difference, We used another TV, worked good. We changed all the cable cords, and made no difference. It comes right down to that TV. yes from aboe it is 100% sure that trouble is in tv. every channel is blury and has a trail. it is due to focus of your tv is not ok 1 adjust focus control 2 focur wire going to crt base might be loose due to some foreign material deposited on crt base. 3 defective crt base. 4 if tv is old there might be possibility of crt getting weak. hope this will help.
Oct 07, 2007 | Sony KV-32XBR450 32" TV
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
