Televison & Video Logo
Posted on Apr 15, 2008
Program a ge universal remote to an emerson 12" tv
I have a ge universal remote with a set up button and enter button-no code search button and a 12" emerson tv. i want to "hook them up".
  • William M Bruce Smith Sep 02, 2008
    I just want to use my ge remote control on my emerson tv but lost the
    oode book.
  • Anonymous Dec 03, 2008
    no code search button on ge universal remote
A
Anonymous
I have a ge RM24911 universal remote but i need the codes
2answers
Ge universal remote model um3-lr06
please reach out to general electric via twitter and ask them to post the product manual for you sos that you can download it and get the codes that you're looking for. Their id on twitter is @generalelectric.
Thank you.
Need code list for Emerson TV
Kathlene, Check the attached links,instruction and guides Emerson TV codes, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://codesforuniversalremotes.com/universal-remote-control-codes-emerson-tvs
https://www.remotecodelist.com/remotes/emerson/emerson.html
What is the remote code for an Emerson TV
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
1helpful
2answers
I have a GE JC024 tv remote and need code for an Emerson tv
These are the setup codes for Emerson TV, with GE remote control.
0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
Need code for emerson tv
Hello
Three digit universal remote codes for Emerson TV are:
004/ 009/ 014/ 023/ 024/ 025/ 026/ 027/ 030/ 032/ 033/ 034/ 035/ 036/ 037/ 038/ 039/ 040/ 041/ 042/ 043/ 045/ 046/ 049/ 053/ 116/ 135/ 147/ 177/ 179
Four digit codes are:
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
2answers
Ok i have a rca remote trying tp program it to a emerson tv do not have any codes
Here are some codes for your Emerson TV.
065,067,075,076,079
011,026,027,028,029,030
031,032,037,042,053,064
Here are some instructions as well for your RCA Remote:
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Hope that helps.
3helpful
I have a GE 24914 Universal Remote. I would like to program it to work with my Emerson Television. How do I do that?
Hi! These are the steps on how to program your Ge Universal Remote Control to your Emerson TV.
2. Press and release the desired TV button. The red indicator blinks, then stays lit.
3. Enter the 4 digit code indicated below.
4. With your TV on, press ON•OFF. If the TV turns off, no further programming is required. Note: If some buttons do not operate your TV, try one of the other
codes.
Codes for Emerson TV are 1172 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0210 0227 0233 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
7helpful
3answers
RCA Universal Remote set to my Emerson TV
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
9helpful
9answers
Codes for universal remote
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
20helpful
4answers
Need code for Emerson TV,DVD,VCR Combo
I don't know if you guys even need this advice anymore, as it's 1-2 years late, but if your universal remote has a VCR setting, the Emerson 13" CRT TV/VCR combo I have operates under that mode.
The code I used was 002. These may also work: 278, 184, 479, 000, 121, 211, 037, 043, 061, 208
Remember, program your remote as if you were setting up a VCR (and NOT a TV). For instance, on my GE universal, I hold the "code search" button down until I get a steady light. I hit VCR, and then I entered 002. Works like a charm.
Top GE Televison & Video Experts
ExpressFiX
ExpressFiX
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
