Question about Vanguard International Blue Flame - Medium Open Flame Patio Heater
Yellow pilot on heater
I have a Vanguard natural gas blue flame heater and only the pilot is yellow, not the flame. I was told it was dirt. Can I take the tube off the pilot and air blast it to make it blue again?
  • 1 more comment
  • Anonymous Mar 20, 2014
    natural gas fireplace
  • Anonymous Mar 22, 2014
    pilot flame cuts off
  • Anonymous Mar 23, 2014
    my pilot is blue and has always been but now it has orange around it does it need adjment
    Scholar:
  • 41 Answers
soleman13au
Rank:master_s.gif Master
Rating: 90%, 19 votes
Hi mitalee1
All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this. If you can get to the top of the pilot light it may help to give that a blow out too.
To clean it out internally you only need to remove the front panelling. Just follow the screw configurations *** you go. I asm not familiar with that type of heater so thats about the best I can do. Regards Bryan
Posted on May 07, 2008
Adjust pilot light
check your gas pressure meter might be too small call gas company they will assist you
Nov 13, 2013 | Dyna Glo "" Natural Gas Heater Mn200tba
I have a model VN3000D Infra-Red heater and it WOULD burn on the #1 setting but now won't stay lit at all. The pilot is a blue flame with small yellow tip and is on natural gas. Is this a thermocouple...
Any time you see yellow tip on pilot it a sign that pilot needs cleaned. Use air to clean it then relight, look to see that the tip of thermcouple is in the pilot flame. your pilot light would out as soon as you release the pilot starter button if it was thermcouple. You can go on line and find all like of heater parts. My shop has nine instock.
Feb 07, 2011 | Vanguard International VN30TB Infra-Red...
Pilot light too big, how do we adjust pilot light on a Vanguard KV1800?
There is no adjustment for a Pilot Flame's Length on a Vent-free Gas Appliance. However, if you're using Natural Gas and it's a Natural Gas Heater, the normal length of the pilot flame is 2 to 2 1/2".
If it's a Propane Gas Heater and the pilot flame is as long as previously stated, you probably have a pressure problem from your tank. Contact your Propane provider to have them check the pressure on their tank regulator.
Jan 31, 2011 | Vanguard Heating & Cooling
My gas logs will not come on. the pilot is lit
You can try cleaning the thermocouple and repositioning it directly over the pilot flame, if this does nothing the replace the thermocouple. The job of a thermocouple is to sense heat from the pilot and upon demand from a thermostat turn on the gas valve and ignite the gas burners.
Dec 20, 2010 | Vanguard International Blue Flame - Medium...
Change from natural gas to propane
You could do it but it would be very expensive. You would need to change the ODS pilot and the gas valve itself. I am not sure even then it would work correctly. These are not conversion ready.
Jul 26, 2010 | Vanguard International Blue Flame - Large...
Pilot light flame is mostly yellow. LP gas
Thr thing you need to do is take the pilot assembly all apart and blow the dust and dirt out of it.
After burning for many, many hours the air that is move up through the pilot assembly leaves dust and dirt which plugs off a bit of the air and makes the flame run rich. Meaning that it does not get enough air mixed in for complete combustion.
When you clean it you will see the dirt and dust com out of it.
Reassemble carefully just as you took it apart and it will be back to working great again!!
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 23, 2009 | Blue Flame Charmglow 30K BTU NG Vent Free ...
Natural gas to lp gas
It would be costly.They are not shipped to be interchangable like a range. They come in a Nat gas version or a LP version. Your best bet would be to get a veriable pressure knob like they use on a turkey frying rig and tweak down the pressure, I am not sure that would even work. It could be done but it would be expensive. You would need to swap out the pilots and the orifices.
Jan 11, 2009 | Vanguard International Blue Flame - Large...
Vanguard heater model vp2800btb
soleman13au
Hi slowjam I am assuming it is a Natural Gas Heater. All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this. If you can get to the pilot light may pay you to hit it with some compressed air as well. Hope this helps. Regards Bryan
Apr 14, 2008 | Vanguard International Blue Flame - Medium...
Vanguard International Blue Flame - Medium Open Flame Patio Heater Logo
408 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
