Question about Dell Dimension 8400 PC Desktop
Dell Dimension 8400 IP Address Problem
Just relocated and changed internet service. Our Dell will note accept the new IP address from Comcast for internet service. I've run all the repair functions and still nothing. Besides restoring to the original factory settings, do I have any other options?
    Problem Solver:
  • 16 Answers
I think you give wrong IP address to your system. use correct IP which provided by the Internet connection company. otherwise reinstall your OS.
Posted on Apr 15, 2008
I have two user on my computer but on one i can get on the internet and on the other i cant it says change the proxy setting
every user created on the OS will have to have different settings.....
before making changes...get the foll info from your internet service provider
IP Address, Subnet mask, Default Gateway, DNS server address both primary and secondary
once that's available.....
you can use different settings in in WinXP as below....
Control panel / Network Connection /Local Area Conn /Right click / properties/ Internet Protocol TCP IP / Check Box / Propertis / in IP address use the IP address that's been assigned by your internet service provider
log in to first user accunt and make the settings....for....
use the info obtained from the service provider.....
....then
in the IP address filed use some thing similar like this..(check your internet service provider for that info).....the foll is only an example from my PC
say....192.168.1.2 for user ONE
log out....
shut down and restart PC
log in to second user accunt and make the settings....for all the above fileds....then
in the IP address filed use 192.168.1.4 for user TWO....(note the difference of the last filed of the IP address....2 vs 4)...every new user a/c the last field of IP address keeps changing
1st user ....say 192.168.1.2
2nd user .........192.168.1.4
3rd user ..........192.168.1.6
etc...
http://windows.microsoft.com/en-IN/windows-vista/Change-proxy-settings-in-Internet-Explorer
hope this helps
reg
Suresh
Apr 28, 2011 | Google Chrome
Netgear wireless router
Most likely the router is not configured for dhcp or is not renewing to pull an address from your new provider. You will need to login to the router and check the WAN ip address settings. Choose dynamic ip address (it may be currently set for for static or another option based on your previous provider). Once you choose and save the settings, click to renew the WAN ip. If you were already set for DHCP and the address is correct, you may still have an issue with DNS,.. the DNS addresses may be incorrect or non existent. If you have doubts about DNS addresses,.. you may change them to 208.67.220.220 and 208.67.222.222 (opendns) and they will work with most providers (including comcast)
I hope this helps,.. if you need details,.. please leave a comment and I can supply more.
Feb 07, 2010 | NetGear WGR614 54Mbps Wireless Router...
I have cable internet through Time Warner and their modem connects directly to my Dell Dimension 8200 PC. I cannot connect to the internet and I am told it is because my computer will not read the ip...
you need to flush your dns
unplug modem (min of 10 sec)
turn off pc
restart in this order
modem (wait until most of the lights are solid) then pc
if your still having trouble
--------------------------XP Only -----------------------------------------------------------------
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
---------------------------------Vista or higher----------------------------------------------
1) Go to Start and click Run.
2) Run window will appear. Type cmd and click OK.
3) Command prompt
window will appear. Type ipconfig. You then will see the IP address and other network information of your network card
4) Type ipconfig /release to release the IP address.
5) Finally type ipconfig /renew to get new IP address.
then if this dont wont restart the computer.
if its still not working you will need a local tech to see if the ip address is hardcoded into the NIC
Jan 06, 2010 | Dell Dimension 8200 PC Desktop
Dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
Jul 16, 2009 | Dell 5100cn Laser Printer
169 IP address just happened and now have limited to no connectivity use comcast as a provider It's a dell 2300 dimension help
This is a common networking occurrence. This is called APIPA. See this link: http://www.webopedia.com/TERM/A/APIPA.html APIPA is an IP address which is assigned when no other address is available. Whatever Windows version you have, this will work if it's above Windows 95. Click on the Start menu, choose "Run", type in "cmd.exe" once you get a command prompt, type in "ipconfig /release", then "ipconfig /renew". This will release the APIPA address and attempt to get a valid address. Hope this helps.
Jun 08, 2009 | Dell Inspiron 6400 Notebook
Dell Dimension DE051:Wireless Internet Problem (Can't Load Sites)
contact Comcast and have them reset your IP address. also have them ping your modem after they reset IP.
Also, see Linksys website for LELA (easylink advisor) to add devices to network. Uses a good bit of memory so don't allow to run automatically at start up.
Dec 30, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Changing a Dell 3010cn IP address and Storecenter
Print a settings page from the printer. If you are not sure on how to get the settings page, download the user manual from support.dell.com, there should be instructions in there on how to get this. Once you have the settings page locate the IP address on the print out. Take this IP address (which may be different then the one you want to use) and open internet explorer, put the IP address in where you would normally type a web address, hit enter. This will take you to the embedded web server of the printer. Once you are there, you can look for printer settings, ip address or TCP/IP address. Once you have found this, you can set a static (meaning it will not change, unless you change it) IP address (the IP address your tech person gave you) and submit the information to the printer. The printer must be on and in the ready state for this to take hold. If you are prompted for a username and password for the embedded web server, dell default username in small case is admin, leave password blank or username admin, password is password. To confirm that the address has taken, print another settings page from the printer.
Nov 14, 2008 | Dell 5100cn Laser Printer
Dell Dimesion Serial adator fuse
there is irq address poblem i think they get same irq address so that they stop to work.so you have to change these irq address. Hope this solution woks.
Sep 02, 2008 | Dell Dimension 8400 power supply ** FREE...
IP Address
you can just check it
click on start menu, click on run , type cmd , then type ipconfig
check out the ip address it should be anything other that 169.xx.xx . if you get anything say ipconfiguration . then you may click on start , click on run , type devmgmt.msc . check whether there is any yellow question or exclamation symbols . if there is any try to install the network drivers
Apr 21, 2008 | Dell Dimension 8400 PC Desktop
Ethernet Problem
If it is telling you there is a conflict the drivers are working it is the properties of the network card that are incorrect. Click Start>Run, then type ipconfig /flushdns then press enter.(note the gap between ipconfig and the /). Go to the properties of your network card and on the TCP/IP line click properties and tick 'Obtain ip address automatically'
Mar 06, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 8400 PC Desktop Logo
139 people viewed this question
Alun Cox
