When tv was turned on it went black, unplugged and replugged in the light came on for an instant like it was turned on and then it went out
  • lohanlonpa Apr 22, 2008
    Thank you, it was 10 years old went out and got a new one.
    Genius:
  • 3,422 Answers
HI,
You will need to get it repaired.Its a power supply issue.If TV is still under warranty i suggest you to get it replaced.The repair may cost anything between $200-$300.
Goodluck..
Posted on Apr 15, 2008
  • 3,037 Answers
Do you still get audio? If not, there is usually a catastrophic power supply failure, often a failed electrolytic capacitor. It's also not uncommon for the high-voltage flyback transformer to fail because of a fault in the power supply.
Power supply failure is generally the only TV failure that is worth paying for, since the boards are premade and easily replaced. If something else has failed then it is probably not worth fixing. It will cost as much for a comparable new rear-projection CRT TV.
Find a repair shop that does free estimates or if you want to fix it yourself let me know.
thank you for using fixya and good luck
  • Benjamin Patri
    Benjamin Patri Apr 22, 2008
    Were you able to get this working, if not please let me know otherwise
    I would appreciate it very much if you could rate this solution
    Thank you
  • Benjamin Patri
    sounds good, have a great day
  • 652 Answers
Yaa its sounds the power card and power supply is ok, but there is a short-cuirkit in you board, thats why its goes off. I thinks its time to get it serivced by technitian.
Thaks
Iqbal
  • 4,889 Answers
Looks like the SMPS is a toast... can you provide me the make and model of your tv so that we can zero in on the problem?
  • eagle338
    eagle338 Apr 16, 2008
    did you figure it out?
  • eagle338
    eagle338 Apr 21, 2008
    Did you get a new SMPS or you want to help me find it..?
  • 113 Answers
What is the make and model?
I went to fast forward my tv show an the screen went black what causes it to do that
Unplug the TV from AC mains wall socket, and replug it back after 20 minutes or so. Check it after.
Electro help
Jul 26, 2014 | Samsung Televison & Video
Sharp flat screen - TV went black- now just blinking light - when pressing on/off button blinking light won't stop
fault condition light ,
unplug replug power
if still then its detecting a circuit fault you cant fix easy.
Jul 25, 2014 | Televison & Video
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney (sidneysites@yahoo.com)
Feb 17, 2013 | Vizio E371vl 37 Inch Class Lcd Hdtv
Screen is going blank but blue power light stays on
most likely a capacutor has blown or it just lost the signal. try unplugging all connections while powered off the replug the power on. hopes this works. if it dsoes please rate with a comment
Feb 07, 2013 | Sceptre "32"" Class 720p 60 Hz Lcd Hdtv...
Hey, i bought a DLP Toshiba HDTV off a guy on graigslist, when i went to go pick it up he turned it on by remote and everything worked fine as it should. When i got back to my place I tried turning it on...
These DLP tvs sometime u unplug suddenly and replug it back wright away,tv will go into protective mode and will not work wright away.Tries tv unplug,replug it back about an hour later,now the tv will reset itself back to the factory setting.The tv should work now.
Nov 17, 2010 | Toshiba 65H93 65" Rear Projection...
LG 32L4DS this is my TV... my wife was watching and the screen went black no picture no sound any suggestions or is it a recyclable?????
Tv now turn on,tv have power LED light indicator flashes?Tries tv unplug,replug it back like an hour later,the tv now,should resetting itself back to the factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | LG 32LC2R 32 in. HD-Ready LCD Television
My flat screen tv dont turn on
Hey,
My TV had the same problem. From my experience try when turning the TV on changing the TV channel on the TV not the remote.
Jul 26, 2009 | Proscan PS27500 27" TV
Help With My Protron Flat Screen TV
I rebooted the television. Turned it off, unplugged it and disconnected the cabletelevision. I left it that way for about 10 minutes and replugged it all back in and turned it on. It works great now!
Jun 10, 2008 | Protron PLTV-32 Television
My screen is black with no sound--the timer light is flashing. i can unplug the tv and replug it, then get sound for about five seconds. HELP
I had a problem with my Sony Projection TV recently where it went black. I had a burnt out projection bulb which had to be replaced.
Maybe you can check owners manual , it will tell you how to relace it. Hope it helps you out.
pryby
Feb 24, 2008 | Televison & Video
Panasonic Projection HDTV Made 9/2003
Your lamp has most likely blown out. that is what happened to mine and once I replaced the bulb it worked just fine. this is one of the cheaper stores to find a replacement bulb, www.bluestar-online.com
Aug 29, 2007 | Panasonic PT-40LC12 40 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
