Power jack on Acer Aspire 5610 loose - how can I replace it?
  • Anonymous Mar 16, 2014
    have engine mount loose and engine jacked up as far as it will go. have the fan and fan shroud off. I have the throttle body and throttle body throat off, I also have the transmission mount loose. I have the oil dipstick off also. I can move the mount all around but it hits the exhaust manifold. im am trying to replace the left mount , but I do have the right one loose just so I could jack the engine up as far as it would go
  • 589 Answers
The power jack on that model is soldered to the mainboard.
Unless you're comfortable with taking the notebook apart, and good with a soldering iron, it is best to take it to a shop.
If you choose to do this yourself, the power jacks can be bought from several sources for around $10 including shipping.
Repair shops charge $100-$150 to perform this repair.
Posted on Apr 15, 2008
Acer 5610 charging difficulty
Yes! the DC jack will probably need to be resolded, and I would recommend replacing the power adapter because it may fix your problem, I find the universal supplies don't fit as tight as the original ones. www.ebay.com is a good place to start for power supply replacement.
Mar 30, 2012 | Acer Aspire 5600 Series 5610-2013 Notebook
I have an Acer aspire 5610 z laptop for 4 years, it has been faulty as while I am using it shut down by itself for few minutes until the battery comes on and I have to swicth it on again.
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Aug 04, 2011 | Acer Aspire 5570-2067 Notebook
No power at all, tried a new charger still no power and replaced the battery.
Hi
After the battery and AC cord replacement and still not getting power there's only once culprit there and that is the motherboard of the laptop. I recommend you call Acer and have them replace it for you. Thanks
Feb 21, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
No power
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Sep 08, 2010 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610Z dead battery & malfunctioning power adapter
But before you buy a new battery, You need to again repair the power plug where your adaptor's plug is inserted so that it will not create any problem later. There might be loose connection or sort wiring.. Good luck..
Apr 29, 2010 | Acer Aspire 5610 Notebook
Acer 5610 DC jack problem - need to dismantle laptop
The solider tends to loseen up on the power connection.Make sure all screws are removed some are under the covers on bottom of laptop slightly pry the top up where ever it seems to be holding look for a screw underneath where its holding.if all screws are out it should come off fairly easy.
Oct 05, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 4520, power jack
You may be able to buy the whole assembly on Ebay. I bought one for my averatec laptop and it just popped into place, no soldering. It was about $20
Sep 06, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
