I have a pioneer double tapedeck with one of the doors missing.the stereo is at least 10-15 years old & living in dundee i have tried to find somewhere to rememedy this problem to no avail. could anyone suggest anywhere
  • 4,234 Answers
Sorry to be the bearer of bad news, but manufacturers typically don't stock cosmetic parts that long. Put the word out to some local shops that may be able to salvage one for you from a scrap unit.
Dan
Posted on Apr 15, 2008
How do I safely remove a Grundig 3100 stereo from my dashboard - 1995 model with a tapedeck
Using the forks provided to release the whole stereo from the holder. Unplug the radio and fit a new one. Don't forget to record the code!
Oct 23, 2014 | Televison & Video
How do i hook up a pioneer deh 1700 to my car wire colors do not match
You are going to need a multimeter to find a permanent live wire the switched live and the negative for starters if you are removing an older stereo it might be easier as the switched live is normally to the red wire the yellow is permanent live and black earth from your pioneer you will have a blue that is sealed off that is the electric ariel or signal to an amp the rest of the wires ar plus and negative speaker wires.
Sep 16, 2014 | Pioneer Car Audio & Video
Why pioneer stereo works part of the time?
Loose connection on either speaker in pass door earthing out or broken wire from door to stereo connection
Aug 25, 2014 | Pioneer Car Audio & Video
Trying to set up just the amp & tapedeck of the Sony TA-AX335 integrated stereo system, but can't get the ribbon power cord to work.
Does the deck light-up at all, or is it completely dead? I've found that in aging tape decks, the belts will deteriorate, and change into tar. I've repaired several of the TA series Sony systems, and that's usually the case. If the deck is just 'dead,' I would recommend retrofitting standard RCA jacks on the back of the amplifier. The pins on the ribbon cable are clearly marked on the PC board inside the amp. Then, you could use any deck you want, or even a CD recorder. Hope this helps. :)
Apr 13, 2013 | Audio Players & Recorders
Forgot how to record (dual) tape to tape (been a while)......can not remember sequence of buttons to press or if i need to press buttons at the same time (i.e. Trying to record 1 cassette tape to another...
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
Jul 09, 2010 | Audio Players & Recorders
Radio Blowing Tail Light Fuse
by the way you tell me that the radio illumination is the gray wire and all of the rest you are wrong. try the correct way red is key positive,yellow is constant power,black is ground,orange is illumination,blue is remote,gray is right front positive and gray black is negative,white is left front positive and white black is negative,green is left rear positive and green black is negative,violet is Right rear positive and violet black is negative,
Nov 23, 2008 | 1993 Oldsmobile Cutlass Ciera
Fitting a pioneer stereo
you need a ford to pioneer wiring adapter. available at any stereo shop.
Aug 30, 2007 | Pioneer DVH-P5000MP - Car Audio DVD/CD/MP3...
19 people viewed this question
 Grubhead
Grubhead
