Question about Nokia N76 Cellular Phone
Forgot my lock code
I have changed my lock code recently and i forgot it . so pls help me
    Novelist:
    Scholar:
  • 110 Answers
hxn1
  • 78 Answers
SOURCE: Hi the keypad get locked
If you've forgot Security code of your Nokia mobile phone, you can use Security Master-code instead.
Just follow the following steps.
  • Dial *#06# on your dial-screen for IMEI number
  • Open this site http://nfader.su/
  • Type that IMEI number in the box and check " I'm the legal owner "
  • Press Generate
You'll see the master-code for your phone.
That master-code will help you to set a new security code.
Try this.
Good-luck :)
Posted on Apr 28, 2011
Testimonial: "I have to try it"
kram26
  • 544 Answers
SOURCE: forgot lock code
hi there,
how are you..
here i write some instruction that you can follow to unlock your phone....
hope it will help you to deal this matter.
any further question that you want to know you can log on this site for additional information.
http://gleez.com/articles/did-you-know/nokia-secret-codes
On the main screen type in:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.) Press and hold "0" on the main screen to open wap browser.
Posted on Feb 17, 2009
  • 16 Answers
SOURCE: I forgot my lock code!!! Pls do someting
try these:
You need 1 mobile phones and a memory card reader.
1) Do _not_ turn off the mobile phone!
2) Remove the Memory Card from the locked phone and put it into a
memory card reader. Create
the directory E:\System\Recogs and copy thc-nokia-unlock.mdl into
this directory.
3) Remove the Memory Card and place it into the locked phone.
The THC-NOKIA-UNLOCK program should start after 120 seconds.
4) Remove the battery. Remove the MMC. Put the battery back and restart.
The Phone Lock has been reset to 12345
Posted on Feb 10, 2009
operas
  • 123 Answers
SOURCE: forgot my lock code for nokia 6275i
Nokia *#7328748263373738# Resets the security code to default(ie,12345)
other solution r
software flashed and reloaded
device replace
check out here
http://www.scribd.com/doc/299040/Nokia-Universal-codes-
Posted on Jun 07, 2009
SOURCE: i forgot my(N70) phone lock code. pls help!
i donot remember the lock code
Posted on Sep 26, 2009
I forgot my nokia E72 lock code.plz help
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 19, 2012 | Nokia E72 Smartphone
I forgot my(N70) phone lock code. pls help!
If you do no change your unlock code then the default of the is 1234 or 12345. Try it.
Thanks
Aug 17, 2009 | Nokia N70 Cellular Phone
My security code and i want to unlock it
Enter the lock code instead of the security code. After then to change the security code.
  1. Go to menu and there open settings.
  2. There open security settings.
  3. There will options such as change lock code or change security code etc.
  4. If you have forgot security code then you can't change it, better change lock code as your desired password.
  5. To change first get into change lock code and enter old lock code and after that input new password and its all done.
Aug 14, 2009 | Lands Phones
To change lock code of N95 - old lock code forgot
Visit http://www.unlockme.co.uk/master.php
Input your phone imei number to generate a Master reset code for your handset.
That fixes it.
Rate this fixya.
Jun 02, 2009 | Nokia N95 Cellular Phone
Unlocking code for sony ericson t290i
The sony ericsson default lock/unlock code is 0000, if you changed it and forgot it you will have to call your service provider to see if they can reset it for you.
Mar 15, 2009 | Cell Phones
Phone Lock Code Forgotten (SE W200i)
u have to unlock the code using software xs++
Jan 17, 2009 | Sony Ericsson W200i Cellular Phone
Sectrity code for nokia 1100
hi
i forgot the security code my nokia1100.now icant lock the phone.pls help me by giving a solution.my serial no is 355384001969442
imei 355384001969442 what is the security code
in my hand set sound is not coming
Jul 18, 2008 | Radio Communications
Master reset
if u never change the security code of your phone, pls try using the default security code 00000
May 27, 2008 | Sony Ericsson M600i Cellular Phone
Can't remember my phone lock code
i dont remember my phone lock code sonyerickson w800i thanks
May 19, 2008 | Sony Ericsson W800i Cellular Phone
Nokia N73 Lock Code
THE NORMAL WAY TO RESET THE SETTINGS IS GO TO SETTINGS THEN GO TO PHONE THEN GO TO RESTORE FACTORY SETTINGS AND IT WILL ASK YOU A CODE PUT 12345 AND PRESS OK IT WILL RESET YOUR SETTINGS PLEASE DO NOT FORGET TO BACKUP YOUR DATA NORMALLY IT DOES NOT GO AWAY BUT JUST TO BE ON SAFE SIDE.HOPE IT WORKS FOR YOU
Sep 17, 2007 | Nokia N73 Cellular Phone
Nokia N76 Cellular Phone Logo
105 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
