Question about Intel BLKD915GAVL (BLKD915GAVLX10U) Motherboard
OS does not boot
Turn computer on, freezes at blue intel screen. CPU is Pentium 4 LGA775 (3GHZ) Windows XP Media Center, I upgraded memory to 3 GB, but problem returned 3 weeks later... Computer is 3 years old. Any ideas as to where this problem is? Can it be fixed or is the computer just old?
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
Most likely the new stick(s) of memory is causing problems in your system. To verify this i would remove the newly added ram and see if the problem goes away.
Also you can download and run a memory test called 'memtest86+' from here. This can be burned to a cd and booted from the computer, to run a diagnostic on the new memory.
Hope this helps.
Posted on Apr 15, 2008
Can I increase my processor in a dell laptop 1520 xp so I can download windows 7?
no processor upgradation this model upgradation means change MB also this is not possible
Oct 24, 2012 | Intel D845GVSR Motherboard
I have a compaq pasario 5716 with pentium III Desktop computer. Has only 384.0MB RAM. HD space is11GB. The OS is W98. with Internet Exployer version 6. To update this computer I think I need to replace...
Don't bother upgrading that old thing.
You can pick up a much better second hand Pentium 4 for $60 or so, and even Windows XP can only handle about 4 Gigs of RAM.
Very few Pentium 3s will support a 2Gig module in each slot. Just because they sell 2 Gig sticks does not mean they will work in your computer.
If you want to know how much memory your old machine will hold and support, just go to:
WWW.CRUCIAL.COM
When you get there, run their SCAN MY COMPUTER utility.
This will tell you exactly how much memory and what type you currently have installed, how many memory slots are available on the motherboard, how much each slot will support individually, as well as the maximum total amount of RAM that the motherboard will support.
Good luck.
Mar 17, 2011 | Compaq Computers & Internet
Computer Information Manufacturer: JETWAY Model: System Information Chipset: Intel 945G/GZ/P/PL Express Memory Controller Hub PCI standard host CPU bridge Motherboard: LakePort CPU: Intel(R)...
U may always refer to it motherboard to get to know the supported hardware that plug to it. Since u are mention about Intel 945G/GZ/P/PL family motherboard, each type of the motherboard (type G, GZ, P, PL) have their own specification, but the same thing is their are design to support Intel Core 2 Duo. Pentium D or Pentium 4 processor. And all can support DDR2 memory. Here you can refer to the manual of the motherboard for more details e.g. pg17 (availability 2009Nov16): http://www.intel.com/design/chipsets/datashts/307502.htm
YBC (/)
Nov 14, 2009 | Intel Computers & Internet
Gateway E3600 (Intel D845PT MB) won't boot after MS Update
This error comes when your motherbord not read properly harddrive.
for that first reconnect both connection to harddisk.Power cable and ide or sata cable.
Change SATA or IDE cable then check.
Pull cmos cell from motherbord for 10 minutes so all settings are factory defaults.
Then when you power up the computer press F1 or F2 or "del" key then you can see bios screen.
Make sure hardddrive detect in bios.
Set first boot device as harddrive.
Then check.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | Intel Desktop Board D845PT Motherboard
What causes your video to freeze?
sounds like a hardware fault, do you get an error msg and blue screen? ide say motherboard and video card not running correctly, swap the vid card first, see if this helps,
Jun 07, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Cpu usage nearly 100%
check in your task manager whats the service which is using your cpu usage and let me know
Mar 24, 2009 | Intel DG31PR Motherboard
SYSTEM FREEZES WHEN CONNECTED TO INTERNET
You should try to test your memory (before windows boots.See download) to make sure the sticks are good. Download this. Next try using a program called Process Explorer to locate hanging modules of your computer. This will help you narrow it down.
Mar 05, 2008 | Computers & Internet
Occasional BOOT hang
Try using the event viewer and see if it comes up with anything
How To Use the Event Viewer Applet
http://www.bleepingcomputer.com/forums/topic40108.html
Jan 02, 2008 | ASUS P4S800D-X Motherboard
Intel ASUS P4 845 GL Motherboard
Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Intel BLKD915GAVL (BLKD915GAVLX10U) Motherboard Logo
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
