Question about Canon PIXMA iP4200 InkJet Photo Printer
Printing delay When I first try to print,there is a delay of about 30 seconds or more.Subsequent printing is ok.Canon suggested printing direct to printer.I have downloaded latest driver but still have this problem.
    Genius:
  • 1,673 Answers
Go in to the printer properties set-up, and change the attribute to print direct to the printer as like they advised. The re-installation of their software will still not change the property settings.
It seems that the computer is first loading an alocated cache or buffer before it will start printing. This is the reason for the delay. By printing direct, you will bypass this buffer. There are some dissadvantages of going direct. One of them is that the computer will take more time to work in programs during a print session. It will share its real time functions with the printer. My preference would be to have the delay and let the printer work by default.
Jerry G.
Posted on Apr 19, 2008
How to reset inkje even with new refilled cartridge
Regarding your recent inquiry about the Canon 240 (black) or 241 (color) ink cartridge ink alert/error condition and the inability to print to your Canon MX452 printer, to reset the cartridge ink low/empty alert message condition, depending on your printer model, we suggest you follow the documented procedures below and/or provided on Inkjet411 at the following link. http://inkjet411.com/?page_id=1765
Essentially, in most cases, all you need to do is press the 'Stop/Reset' button (triangle symbol inside of a circle) for 5-8 seconds and the ink error ("ink has run out", etc.) indicators should extinguish; two common reset procedures are provided below (please refer to both videos): http://inkjet411.com/?page_id=1765
Canon 30/31/40/41 - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2709
Canon 50/51 - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2719
Canon 210/210XL/211/211XL - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2728
Canon 240/240XL/240XXL/241/241XL - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2733
Canon 245/245XL/246/246XL - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2740
If you have already attempted the 5-8 second printer reset without success, then refer to WORST CASE SCENARIO section below.
ADDITIONAL NOTES:
NOTE 1: Providing you can still print, you will need to wait until the "ink has run out" message appears on your computer, before activating the 'Stop/Resume' button for 5-8 seconds. However, if printing is not permissible, then please keep reading....
NOTE 2: If you are able to print the internal self test print, this will demonstrate that the ink cartridge is 'at least' partially functioning. If this is the case, then we suggest you continue printing until the software prompts you to press the 'Stop/Reset' button for >5 seconds. For poor print quality performance issues (as you indicated in your inquiry), we suggest you run a nozzle/cartridge clean test from your Canon software, followed by printing our 'Ink Recovery Test' print: http://inkjet411.com/wp-content/uploads/2013/02/Test-Print_CMYK.pdf
NOTE: To rule out connectivity issues, please ensure BOTH carriage/flex cables (point where the cartridge connects to carriage inside the printer) and BOTH ink cartridge rear electrical contact surfaces are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
      WORST CASE SCENARIO - INTERNAL ELECTRICAL FAILURE OF INK CARTRIDGE:
      If, after performing the suggested 'reset' procedures above, you still have an error condition which prohibits computer/host based printing (or permit copy/scan functions), then the ink cartridge probably has internal electrical damage (micro-electronics failure); such a failure is unrelated to the ink cartridge refilling process. Typically, when the cartridge fails the problem is 'masked' by the ink out/empty condition so it can be difficult to distinguish between the two. Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process (i.e. typically ~2 years from original manufacturing date). Refer to picture at bottom of this page: http://inkjet411.com/?page_id=1533
      If, following a reset of the printer via the 'Stop/Resume' button, printing is permitted but the 'Ink Low' indicator continues to be lit then one of the inks cartridges may be suffering from marginal internal electrical performance - a potential failure of the cartridge may eventually occur which will prevent printing.
      CAUTION: Be advised, the use of Canon compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD failures (due to incompatible ink formulations which may contain volatile organic compounds, or VOCs). We do NOT suggest refilling these types of ink cartridges.....refilling of Canon original/genuine ink cartridges is only suggested!
      Canon 30/31 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=3khyqBHMPVc
      Canon 240/241 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=HyEhCOxvdsA
      If you do need to purchase a new ink cartridge (to save on ink costs), we suggest you try a USA remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating and come with a 1-year warranty.
      Alternatively, if you are interested in the top 'refill friendly inkjet printer models', our suggested list is posted on-line and our internal labs have verified there are no issues (in ink compatibility or color output) with all of these models: http://inkjet411.com/?page_id=3585
      Please let us know if you have any questions regarding the technical information provided above by sending an e-mail to us directly: Inkjet411help@gmail.com
      -Thank you
Jul 20, 2014 | Canon Pixma MX452 Wlse All-In-One Printer...
Hi, I have a canon BJC-80 printer& I am using vista. The printer will not print. It has printed twice. But a time delay of about 30 minutes. My laptop is toshiba & I have a usb cable plugged into...
try to remove the cartridge and print it again. Try also to unplug/replug the USB and restart your printer to check if it prints. You may also use another pc to connect the printer and print. Otherwise call Canon to check it for a possible repair...
Jun 05, 2011 | Canon BJC 80 InkJet Printer
Canon MP480 printer problem
uninstall the printer driver and reinstall it . it will work...
Oct 23, 2009 | Canon Pixma MP480 All-In-One InkJet...
Canon ImageClass MF 6550 prints light text
I mean can you scan a text document with the "photo" option and see if you are still encountering problem. And check this out, he tells how to reset to factory and test scanner. http://www.fixya.com/support/t342579-just_started_printing_blank_pages
Apr 27, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
The printed pages with black is light and spotty.
Try to run the "Clean Print Heads" utility. Sometimes it is called something else, but whenever your print quality degrades, this is a good program to run. If that doesn't work, then I would suggest replacing the print cartridge. Sometimes they go bad if they have not been used for a long time. Hope this helps!
Mar 13, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Delay on printing
Power the printer on then unplug the power lead. PLug the power kead back in while pressing OK and Cancel. Hold the buttons down until the printer turns off. Unplug the power lead for 30 seconds. Plug the lead back in and run through the set up process and try again
This should clear your problem
Nov 09, 2008 | HP Photosmart 2575 All-In-One InkJet...
Canon SmartBase MP360S printer
You have Vista this is the problem- there may be a driver issue here
take a look at
http://www.google.co.uk/url?sa=t&ct=res&cd=3&url=http%3A%2F%2Fwww.opendrivers.com%2Fcategorycompany%2F1405%2F129%2Fmultifunction-canon-free-driver-download.html&ei=DvyBSL7IOZ3uQo-KpLYN&usg=AFQjCNExG7VOz91yswKZfouV8puBHufbKQ&sig2=gL2G5p7ndcDLosNQmPsh4w
Jul 19, 2008 | Canon SmartBase MP360 All-In-One InkJet...
HP officejet d135 delayed printing
Both the printer and the computer are machines and it solely depends upon the speed of the computer as to in how much time thye data is transmitted to the prinetr to print. Check the speed of the processor, RAM,USB port(if connected with usb cable), length of the usb cable /ethernet cable, distance of the router from the computer and the printer, size of the dcument/image.
Dec 24, 2007 | HP OfficeJet D135 All-In-One InkJet...
Print delay of second print job
Printer delay can mean a few issues. You may be up to date on your windows, but sometimes this can actually be the issue. I would try updating the actual drivers at the canon website for your printer, and check your drivers are functioning properly first by going to start, control panel, main and per, printers, hardware, drivers. Check for error messages. Sometimes you can repair to fix errors if any. Also run antispyware and virus controls to eliminate these too. I had some malicious spyware that wiped my friends driver for her canon pixma clean off her pc!!! Check all printer settings too in case it is accidentally set to pause after first job.
Aug 17, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
178 people viewed this question
old marine
old marine
