Question about Compaq Presario 700 470024-192 Notebook
UPGRADING MEMORY I tried to upgrade the memory from 128. I installed a 256 chip but afterwards the computer would completely freeze. Once I removed the 256 and reinstalled the 128 uograde everything was fine again. Any suggestions? Thanks anunziata@nyc.rr.com
  • 4,102 Answers
Hi if you goto www.crucial.com their is a link on their that scans your computer and tells you exactly what is compatible and the maximum mem you can upgrade to ok so have a look and if you have any trouble finding the link then let me know ok.
I use this link as i build computers to sell so upgrading them is important for my business so knowing the exact compatible parts and maximum is vital so give it a try then you will no where your going wrong ok
Posted on Apr 15, 2008
Can I increase the ram in my think pad?
Hello
Memory Upgrade for IBM ThinkPad R32 2658-xxx Laptop, the IBM ThinkPad R32 2658-xxx Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 128 or 256 MB (removable) of Memory. You can upgrade your IBM ThinkPad R32 2658-xxx Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 128 or 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
good luck and do rate the solution if helps.
Dec 22, 2010 | IBM ThinkPad R32 2658 Notebook
My system is recognizing only half of the new module's memory
Do you have the right memory for your Dell?
Memory Upgrade for Dell Dimension 1100 Computer, the Dell Dimension 1100 Computer takes the PC2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Dell Dimension 1100 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Dell Dimension 1100 Computer.
Nov 20, 2010 | Dell Dimension 1100 PC Desktop
How to install upgrade sdram 128 pc133 for gateway 500
PC 133 Max ram for your model is 512MB - two 256 Memory sticks. Open the case, remove the menory in there (one clips on the side of each module) take note of the way the module comes out - replace with your new ones - reboot and that should be that.
May 10, 2010 | Gateway Essential 500 PC Desktop
I want my Laptop Dell Latitude C800 physical memory upgraded to 128 mb to 256 mb I myself already installed 256 mb Ram but it still showing 128 mb of memory...can I get help in this regard ?
I assume you installed another 128Mb of RAM to give you a total of 256Mb.
It is most likely the 2nd RAM module is not compatible with the other RAM module. Try using the same make.
OR
Purchase and install a single RAM module 256Mb or 512Mb these are not expensive.
Dec 20, 2009 | Dell PowerEdge 2600 Server
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
My Dell C600 won't recognize the 2 new 256 mb sticks of RAM
i think you need a same brand of 256 for it to work? and when you buy something for your computer make sure that the one you both is the same brand or code with your 128 for example you have 128 ddr2 sdram so you can only upgrade it with 256 ddr sdran or 512mb,1gb,2gb ddr sdram.
May 01, 2009 | Dell Latitude C600 Notebook
PC freezing up after memory upgrade
You can use a utility called CPU-Z to find the timing of the memory installed in the PC. Then check your memory documentation (I could find no specs at the Samsung site) to make sure they match in the BIOS. I would remove one stick and see if the problem is better, and also try another brand (Kingston, Corsair, other major brand) to see if any of them work.
Dec 31, 2008 | E-Machines (T3104) PC Desktop
Pc freezes when new memory installed
You problem is the motherboard.On your PCs mother board the 128MB that came with the motherboard might be the highest memory the chipset on your motherboard can accommodate. The chipset is built in and you cannot change or upgrade it. You can speed up the PC with how many memo sticks you added, if the chipset can handle. So it look like if you want a fast PC you need to get a new motherboard chipset with higher memory clock frequency.
Here's the pic of the chipset on the motherboard(square type)
Nov 24, 2008 | Compaq Presario 5000 PC Desktop
Memory upgrade
Yes you can get 4 sticks of 256MB of RAM or get 2 sticks of 512MB that will work fine on your computer....
Jun 02, 2008 | Generic Memory OD-IEA-100 ETHERNET UPGRADE...
Upgrading Memory from 256 to 1GB
You shouldn't have to remove it, but if the system won't boot after try reversing the slot, and if that doesn't work take out the 256.
Feb 03, 2008 | Dell Dimension 2400 PC Desktop
Compaq Presario 700 470024-192 Notebook Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
