Question about Lexmark X2550 All-In-One Printer
USB installation problem
Using installation CD, the program does not recognise the USB connection and will not continue installation, although Windows detects the hardware as soon as the USB is connected.
  • 1 more comment
  • BigZ_UK Apr 20, 2008
    I have the same problem, but the Lexmark 2550 does not appear on the list of printers installed. When I first plugged the printer in, I accidentally hit the 'automatically detect' button instead of 'cancel' as instructed to do in the installation instructions. Now I get automatic detection, followed quickly by "A problem occurred during hardware installation. Your new hardware might not work properly". I get no opportunity to cancel the detection and still find that the installation routine will not proceed past the "connect your printer" screen.
  • Anonymous Apr 26, 2008
    el cd del la impresora no m elo hacepta
  • Anonymous Dec 08, 2008
    do not have the driver disc
  • 655 Answers
This problem comes somtime when you connect the printer prior to dirver installation.
  1. Rmove your printer driver from Start-> Printers and Faxes
  2. Right click on printer icon select Delete
  3. Re-boot system, before re-boot remove all USB connections.
  4. Start Installation from Setup CD
  5. Don't attach printer to system till Installation finished or Setup says to connect the printer.
Posted on Apr 15, 2008
How to reset canon ip2700
WindowsThe printer driver you no longer use can be deleted.When deleting the printer driver, first exit all programs that are running. The procedure to delete the unnecessary printer driver is as follows:
  • When There is an Uninstaller
1. Start the uninstaller - If you are using Windows 7, Windows Vista, select the Start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller.- If you are using Windows XP, select the start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller. - If you are using Windows 2000, select the Start menu -> Programs -> "Your model name" -> Printer Driver Uninstaller.
Restart the Computer and perform the following:Windows
  • If you connect the printer via USB cable before installing the software:
For Windows 7:(1) Remove the USB cable connected to your computer.(2) Proceed to 1.
For Windows Vista/Windows XP/Windows 2000:The above dialog box may appear.(1) Remove the USB cable connected to your computer.If the dialog box closes, proceed to 1.(2) Click Cancel.(3) Proceed to 1.
  • Easy-WebPrint EX:
If you are using Internet Explorer 7 or later, you can use the Web print software Easy-WebPrint EX. An internet connection is required for installation.
1. g0069739.pngPress the ON button (A) to TURN OFF THE PRINTER.Operating noise may continue for up to 25 seconds until the printer turns off.
2. g0069740.pngTurn on the computer, then insert the Setup CD-ROM into the CD-ROM drive.If you are using Windows, the setup program starts automatically.
Mar 31, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Setup did not find any hard disk drives installed in your computer. Make sure any hard disk drives are powered on and properly connected to your computer, and that any disk-related hardware configuration...
you didn't post the make and model of the system, but on most modern systems, this error occurs when the Hard Drive Controller for the system doesn't have a native driver on the Windows install CD. So you need to load the driver during the install. In XP this is done via a Floppy Diskette (XP setup will not recognise a USB Drive) Vista you can install from just about any drive (USB Flash drive generally easiest)
Mar 19, 2010 | Computers & Internet
My pc doesnt recognise my phone
If your pc want to recognise your phone, you need to install motorola pc suite in your system. That will be available in the CD that you got with mobile. If you are not having you can download from internet freely from motorola web site. After installing connect your phone to pc through usb cable and open pc suite phone will get recognise.
Hope you will succeed....
Nov 26, 2009 | Motorola Mobility KRZR K1 Cellular Phone
My computer doen't recognised new hardware
kindly check that ur comp is fully loded and the usb driver is properly installed
Oct 30, 2009 | Nikon D3000 Digital Camera
Usb device not recognised
Is this the first time you connect your printer on that computer? This can be the USB port does not support a 2.0, or your data cable/printer cable is damage.
Hope this helps
Aug 29, 2009 | HP LaserJet 1020 Printer
Removing HDD
Microsoft will not activate windows if installed on another machine and moved.
Mar 27, 2009 | Acer TravelMate 2501LMi Notebook
PC does not recognise Camcorder when connect via USB Cable
my pc does not recognise my camcorder gr-d63 when connected
Dec 28, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Wireless mouse doesn't work
This problem was happening on my system but i managed to fix it easily! What has happened is your itouch software has become corrupt so it will only recognise your keyboard thus the usb connection. You will need to download/install off disc onto your computer again but do NOT go to uninstall program manager on windows as it will not appear there because even though you can access the itouch configuration panel, the database is corrupt and the administrative system will not recognise this. Just download/install via disc and it will just install with no alerts unlike most programs which will recognise the program is already installed onto the system. Once the setup is 92% it will freeze for a second then the found new hardware window will appear on screen go through that process and your mouse is back to normal and your keyboard will work via itouch software.
(Please note that this will only work on windows)
Nov 26, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Belking wireless adapter install
when you are advised to connect the usb adapter, it will recognise it, then the usb host controller is installed to recognise the adapter,but it should continue to instal the driver and then recognise it as Belkin 54g, if not, then you need to keep the cd rom in and then force it to install the driver from your cd drive, but it may not be compatable with ME unles you have a windows 2000 driver.
When the installation is complete you should in any case have the belkin software icon on your desktop to set up the adapter, if not then the software has not installed fully.
It will also be listed in add/remove programmes if it's fully installed.
Sep 22, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Lexmark X2550 All-In-One Printer Logo
357 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
