Computers & Internet Logo
A
Anonymous Posted on Jun 24, 2010
I press the power button and a half moon shape lights up for about 5 seconds the turns off I can not start the system
Anonymous
Level 3:
President:
  • Master 2,600 Answers
  • Posted on Jun 24, 2010
Anonymous
Master
Level 3:
President:
Answers
2600
Questions
0
Helped
1018062
Points
8362
In your power options in the control panel you will see settings for what the power button does. Your's is set to put the computer into sleep mode when you press the power button. Take the battery out and remove the ac adapter. Press the power button for approx. 15 seconds. Now put the battery back in and put in the ac adapter. Reboot the system and open the control panel. Go to power options. Choose the settings for the power button from the drop down menu and choose shut computer off. Also, look for the item in the left column that states what to do when closing the lid and change that to "nothing" from the drop down list. That should take care of ya.
How do I get the part shaped like a half moon to release the blade from the juicer:
Fit the stubby metal bits on the half-moon into the holes on the top of the blade. Hold the half-moon firmly and exert pressure to turn it to the right. The blade should unlock.
tip
Chevrolet service light 1991-01
Camaro
1998-01
To reset the "OIL CHANGE" light, press and hold the "TRIP/OIL RESET" button on the instrument panel for 12 seconds. When the light flashes and then goes out, the system is reset.
Corvette
1997-01
To reset the monitor after an oil change, turn the ignition on. Press the "TRIP" button so that the "OIL LIFE" percentage is displayed. Press "RESET" and hold it for two seconds. The word "RESET" should appear on the monitor, then "OIL LIFE 90%".
Impala,
Monte Carlo
2000-01
Turn the ignition to ON without starting the engine. Fully press and release the accelerator three times within five seconds. If the CHG OIL SOON lights two times, the system is resetting. Turn the key to OFF, then start the vehicle. If the CHG OIL SOON light comes back on, the system has not been reset, repeat the procedure. Follow this procedure to reset the GM Oil Life System using the DE 100 Series Radio. Turn the ignition to ACC or ON and the radio off. Press and hold the DISP button on the radio for at least five seconds until SETTINGS is displayed. Press the SEEK up or down arrow to scroll through the main menu. Scroll until OIL LIFE appears on the display. Press the PREV or NEXT button to enter the submenu. RESET will be displayed. Press the DISP button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second. Once the message has been reset, scroll until EXIT appears on the display. Press the DISP button to exit programming. A chime will be heard to exit programming. A chime will be heard to verify the exit.
Impala,
Caprice
1994
To reset the "CHANGE OIL" light, turn the ignition switch to the run position with the engine off. Access the reset button on the end of the instrument panel by the fuse block. Press the switch and hold it for at least 5 seconds.
Lumina,
Monte Carlo,
Impala,
Caprice
1996-00,
1996-99,
1995-96,
1995-96
To reset "CHANGE OIL" light, turn the ignition switch to the run position without starting the engine. Fully depress and release the accelerator pedal 3 times within 5 seconds. The light will flash and go out.
Corvette
1990-96
After an oil change, or when "CHANGE OIL" appears on the Trip Monitor, with the ignition on and engine off, press the "ENG MET" button (located on trip monitor) once. Press the "ENG MET" button again within 5 seconds. Within 5 seconds, press and hold the "RANGE" button (1990-1994) or "GAUGES" button (1995). The light will flash. When it stops flashing and goes out, the system is reset.
Chevrolet Suburban,
GMC Yukon XL,
Chevrolet Silverado,
GMC Trucks Sierra
2000-01,
1999-00
Turn the ignition key to the RUN position. Fully push and release the accelerator pedal 3 times within 5 seconds. If the CHANGE OIL SOON light flashes 2 times, the system is reset. However, if the light comes on and stays on for 5 seconds, the system did not reset. Repeat the procedure if the system does not reset.
Silverado, Sierra Trucks
1991-93
To reset the "CHANGE ENGINE OIL" message, turn the ignition key to the run position. Press and release the accelerator pedal three times within 5 seconds. If the light flashes for 5 seconds, the system is reset. Repeat procedure as needed.
Screen is black after pressing moon button
the moon button sends it to sleep. when you do that, windows nearly always fails to restart.
press and hold the power button for 15 seconds then try re starting it.
2helpful
How do i remove an ink cartridge from my pixma ip1900
Open the printer cover while powered on. After a few seconds the cartridges will be positioned on the left side where they can be easily reached. Lightly press down on the cartridge where you see a half moon shaped ridge. Take out the cartridge Insert new cartridge press cartridge upwards until it snaps into place. You're good to go!
System keeps telling me i have a paper jam
Does the paper exit the paper tray?
If not, the half-moon shaped feed rollers may be slippery. Turn the copier on its back side to see the rollers.
Usually they are facing upwards and the rubber side is unreachable. Turn the copier back to its original position.
1. Press the copy button. When the copier starts feeding paper take the power cord off-QUICKLY. If you are quick enough the rollers remain at down position and you can clean them with some kind of rubber cleaning liquid or solvent. Perhaps alcohol, but it tends to dry out the rubber surface.
1helpful
How do I get my monitor back on if I accidently press the key in the top left corner (with the half-moon shape on it). What is that key for?
That's the sleep button
(half-moon -> night-time -> sleep).
It puts the PC into standby mode. Pressing the power button should bring it back to life.
6helpful
What does the half moon lit up mean, No screen.
The half moon usually means the computer is in SLEEP MODE. Normally, pressing the spacebar will wake the computer up but I have noticed that sometimes, the computer can get "stuck" in sleep mode. If that is the case, you can hold the power button down (until the power turns off and the moon disappears). Wait a few seconds then hit the power button again to turn the laptop back on.
3helpful
Eliminate half moon from dial of a Timex Ironman Triathlon watch
You need to hold down the Indiglo button for 4 seconds. The half moon means that night mode is activated, and it will tuirn itself off in 8 hours (which I'm sure you know by know, seeing how it's been 5 years).
http://www.sportswatchinformant.com/timex-ironman-watch-night-mode-feature/
Power LED Flashing Yellow on Qosmio laptop F15
This flashing LED means only one thing, and it is quite harmless:
Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
Look for a symbol on keyboard for "sleeping" (like a half moon with zzzz) and press that key WITH whatever color coded key matches the symbol color (usually "FN" key). If there is no suchkey, press the space bar and hold it down a few seconds.
Then wait. Can take 60 seconds to "wake up" on slower processors.
If this does not work, press AND hold the POWER button for 10 seconds. Then wait 60 seconds and press power key again, briefly, to start laptop normally.
Pressing and holding the power button 6-10 seconds forces a complete system shutdown.
If this happens often, something may be wrong with APM or ACPI settings/driver. You can go to start menu/settings/control panels/power management and adjust settings (or disable sleep/suspend and hibernation if all else fails to resolve situation)
good luck.
Can't wake up Micron Laptop
can u try what i gudie before
Grand Canyon Tech
Grand Canyon Tech
