Question about GE DPSB613EDWW Electric Dryer
Letters IH on estimated time remaining display
Only in the More Dry mode, when dryer is turned on, the letters IH appear in the time remaining display. The letters IH alternate flashing with the time remaining based on the sensor system estimate of drying time.
Can't find the error code (or information code) IH anywhere in the manual.
Can you help?
  • Anonymous Nov 17, 2008
    I have the same problem can someone help me please
    Problem Solver:
  • 7 Answers
1H = 1 Hour
Posted on Dec 22, 2008
Kenmore Dryer 700S Check Vent is on and sometimes the letters AF appear in the iMessage remaining Box. The Vent has been checked and vacuumed, but light remains on
that code mean low air flow u clean vent hose did you check an make sure that there no lint build up the vent coming out of the back dryer were bent hose connect to back of dryer are if this a house are a apartment vent hose could be to long cause .
May 28, 2017 | Kenmore Dryers
Tip
Dryer Dry Time Appears to Jump or Stall During Auto Dry Cycles
The operation of dryers during the Auto Dry Cycles is based on the moisture content of the clothes as they cycle over the moisture sensor. At the start of the cycle, the default estimated time is displayed depending on the cycle selected. The moisture sensor feeds information to the control based on the "wetness' of the clothes during the first 5 minutes of the cycle. The control then calculates and display a new estimated time making the time appear to "jump".
Recalculation happens again based on the reduction in the "wetness" of the clothes when the Estimated Time Remaining is between 15 to 5 minutes. The control will extend the cycle and display the Estimated Time Remaining unchanged if it "sees" no significant reduction in the wetness level of the clothes. The dryer will run longer than initially projected and give the appearance that the displayed time has "stalled".
Clean the sensor bars for any films or dirt build up to make sure it sends accurate information to the control. Level the dryer front to back and side to side to ensure the clothing will tumble properly and making good and proper contact with the moisture sensor bars. Check the dryer vent duct for any restriction to ensure a good air flow as the operation of the Auto Dry Cycles is based primarily on the air flow condition.
It is highly recommended to clean the lint filter before every load and make sure the dryer is grounded at the wall plug.
on May 17, 2010 | Whirlpool WED9200SQ Electric Dryer
WHAT DOES CODE AD MEAN ON THE DRYER
If your dryer is set to "auto dry" the display will show AD initially and then may show a number which is the estimated time for the clothes to dry in auto dry mode. The display may also show CD (Cool Down) and DN (Done) during the cycle.
Feb 27, 2015 | Washing Machines
Estimated time remaining readout shows AF instead of the time left. It is a Kenmore 700 series dryer
AF stands for Algorithm Failure, which means that there is something preventing the dryer from calculating the remaining time. Try cleaning out the dryer drum and lint screen completely, then run the dryer with just a dry towel.
Feb 20, 2015 | Kenmore Dryers
Turned on Dryer today; problem; Estimated time remaining window shows CL (no time) Non of the time buttons selected show time in window. Dryer runs forever; gets hot and drys clothes. Pause button does...
The Child Lock feature is activated and it can be deactivated by pressing and holding the DRY LEVEL button for 3 seconds or until the CL display is cleared.
Indicate the exact model number of the dryer if the control panel doesn't look like the one shown above or if no button with the small "PRESS & HOLD 3 SEC TO SET CHILD LOCK" (DRY LEVEL) marking is found.
Mar 06, 2011 | LG DLE2514 Electric Dryer
How do I set my Woods N1506 timer?
According to another fixya answer posted December 4 2009:
SETTING NOMA N1506 TIMER
Plug in timer - The letter C will Flash
TO SET CURRENT TIME:
Press Time Button - It will advance to 1 a.m.
Continue pressing until right time to the nearest hour.
(NOTE: A dot at the bottom right corner of the display indicates P.M. hours).
TO SET ON AND OFF TIMES FOR TIMER OPERATIONS:
Press Mode button - Letter P will flash inviting you to set the program
Press Time button repeatedly until required staring time appears in the window. (starting time is now displayed).
Press Mode button again - the letter E now flashes.
Press time button repeatedly until required ending time appears in the window. (Note: a dot at the bottom right corner of the display indicates P.M.hours).
Press Mode button and the display returns to the current time.
Programming is now complete. You may now plug in whatever needs to be turned on. The device will turn on and off automatically every day at the times you have just selected.
TO REVIEW THE PROGRAM
Press time button - Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
TO CHANGE YOUR PROGRAM
Unplug the timer, which will discontinue the current program. After 10 seconds, plug it in again and proceed to set current time. Then continue with the programming steps as above.
FOR MANUAL OVERRIDE
Pressing the Mode button at any time will turn on the devices plugged into the timer. The display will indicate the letter O. The devices will remain on until the ending time of the daily program. To return the timer to the automatic mode prior to that hour, press the Mode button again. The display will return to show the current time.
AFTER A POWER INTERRUPTION/FAILURE
The timer will return to displaying a flashing C and the devices plugged into it will be off.
Nov 23, 2010 | Woods Outdoor Lighting Timer
What does the code LOC mean?
HI. This is a simple lockout feature that will allow you to prevent accidental starts or stops when children are present. It can be initiated by pressing the Options and Select buttons at the same time for ten seconds. This will initiate the lockout feature and the letters "LOC" will appear on your display. To remove the control lock out, simply, press the Options and Select buttons together once again at the same time and hold them for 10 seconds. This will release the lock out and the letters "LOC" will disappear.
Jul 28, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
I need instructions for using my N1506 timer.
Plug in timer – The letter C will Flash
Press Time Button – It will advance to 1 a.m.
Press Mode button – Letter P will flash inviting you to set the program
Press Mode button again – the letter E now flashes.
Press time button – Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
FOR MANUAL OVERRIDE
Dec 04, 2009 | Woods Hardware & Accessories
Problems with the display
this means that the dryer is in an auto dry cycle.
Sep 02, 2009 | Frigidaire GLEQ2152ES Electric Dryer
When trying to text incorrect letters appear
There should be an option somewhere when you are in the message menu on how to switch from the text mode that tries to finish your words for you to the text mode where you have to push the button however many times to get the the single letter you want. Although if you are in the auto finish mode you can simply ignore what it's suggesting and continue spelling out the word yourself if you want. example: hit 9 6 8 one time each to spell the word "you"..buy if your trying to be able to short hand text like "thk u" your gonna have to look around in your text mode settings.
Jan 02, 2009 | Nokia 6126 Cellular Phone
GE DPSB613EDWW Electric Dryer Logo
731 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
