Question about Polaroid DRM-2001G DVD Recorder/HDD Recorder
Polaroid DVR Recorder 160GB
This unit was working fine until recently the unit loses power during timer recording. At first I would simply unplug it and plug it back in and it would work now the unit does not work. What is going on?
  • oflemone Nov 28, 2008
    Mine did same thing, and originally fine after (long unplug) reset. After a week that no longer worked and machine would not boot up at all. If the machine can't be saved can the "hard drive" data be saved? Did not know they were no longer on the market. Spoke with Polaroid and they said model now available with 1 year warranty. Anybody know any more about this?
    Problem Solver:
  • 4 Answers
Just wanted to say thanks.  My son has one of these and it just quit.  Even though he got the extended warrantee, the store will only give a refund, they will not repair it because they have been pulled from the market.
I foud a blown capacitor, but its the 68 microfarad, 400 volt cap at the input.  There are 2 of the 2200 mfd caps on the power supply but both look good.  I ordered one yesterday so we will see next week when it gets here.
Thanks again for the tip on where to start.
Posted on Nov 22, 2008
Mine did similar thing, and originally fine after (long unplug) reset. Habitually bad power where i live, so originally thought it was from momentary losses, then 1 month after the (short 90-day) warranty expired, it would not reset or come back to life. Mine had blown capacitor, $2.79 at local electronics shop and few minutes for me to remove and resolder and reconnect cables. Capacitors should have flat tops, one of mine was clealry bulged, with small drop of dried electrolyte from inside capacitor. Look at the 2200 mfd near the incoming power cord. Replaced 10V with 16V, as unsure whether it was just originally undersized for power fluctuations in my neighborhood. Has been working w/o problems since.
Posted on Nov 16, 2008
Sounds like the power supply or the fan has quit.
Posted on Jun 05, 2008
Reboots then shuts down again
To unlock the Channel Master CM7000PAL DVR:
1. Unplug the recorder from the wall outlet and DISCONNECT THE ANTENNA. Now plug it back into the wall power outlet.(This will keep the recorder from freezing and rebooting)
2. let it go thru it's normal bootup, tv guide search, etc.
3. When you are able to, hit MENU and then go up to TIMERS. Delete all of the record timers. Unplug it, reconnect the antenna, and plug it back in.
4. After a now a proper bootup, re-program you timers and you will be good to go.
5. And the best thing is, all of your pre-recorded shows will still be there on the hard drive.
I have 3 of these 7000pals and 2 have done this same thing, one of them did it twice. It seems like after years of adding and deleting timers, the DVR's software gets "confused". I've noticed twice it happened "on the hour" just as a program timer started while I was watching a program through the DVR. ZAP...Locked up! The power button would not even work to turn it off.
I would suggest that you do a yearly "TIMER CLEAN" to avoid this trouble in the future.
Oct 07, 2013 | Channel Master CM7000PAL HD DVR
Tip
Force Eject
If a disc gets stuck in the recorder, there a few steps to try before the problem becomes service-related:
1. Power the unit off (so it shows the clock), then simply press the Open/Close button. The unit should power on and attempt to eject the disc.
2. If the above doesn't work - power it off again, then press and hold the STOP and CH UP button on the recorder itself together and hold them down until the unit powers up. This is called a force eject. If this doesn't work (usually if it's not going to work the recorder will simply come on momentarily then loop back into "bye" and go back to the clock), there is one last method to try.
3. Unplug the unit for 30 seconds. Press and hold the same buttons as above as you plug it in. After it performs the self-check "ooooo" across the screen it should do the force eject. If not, the unit requires service to be repaired and possibly the drive replaced.
on Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
My CM7000PAL unit only displays "Channel Master CM-7000PAL..... Loading. Please wait..." then turns off and then repeats the same message. I don't know how to fix this issue. Has anyone found a solution?
3. When you are able to, hit MENU and then go up to TIMERS. Delete all of the record timers. Unplug it, re-connect the antenna, and plug it back in.
I have 3 of these 7000pals and 2 have done this same thing, one of them did it twice. I would suggest that you do a yearly "TIMER CLEAN" to avoid this trouble in the future.
Aug 06, 2013 | Channel Master CM7000PAL HD DVR
CM7000 DVR keeps turning off and resetting when I try to enter My Recordings.
I have 3 of these 7000pals and 2 have done a similar thing, one of them did it twice. After the loading channel Master screen hangs for a time, they would restart. Then the same cycle would keep repeating. It seems like after years of adding and deleting timers, the DVR's software gets "confused". I've noticed twice it happened on the hour just as a program timer started while I was watching a program through the DVR. ZAP...Locked up! The power button would not even work to turn it off.
The steps below fixed all three instances of this failure.
Feb 09, 2013 | Channel Master CM7000PAL
Channel master cm7000pal
Jun 29, 2012 | Channel Master CM7000PAL HD DVR
No audio on polaroid DRM-2001G
just unplug the power cable for few seconds
Oct 21, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
DVR records blocks for 4-6 hours
If you have no manual timers with extended timers then replace the unit. That will eliminate the issue. Thanks for using Fix Ya.
Jul 03, 2009 | DISH Network DVR-625 DTV Receiver /...
DVR making bad DVDs
Three suggestions:
1) take it apart and clean the laser and the spindle 'hub' that the DVD rests on
OR
2) get a 'cleaner' disk that will 'whisk' any dust from the laser diode.
OR as a final suggestion
3) replace the DVD recorder with another. Plain old EIDE parallel interface units fit fine.
This is a very friendly machine in that it will accept PC compatible hard disks and DVDR drives.
tom
Feb 04, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Unlock Pioneer DVR-531H
check ebay - i got a disc for my 530h on there which unlocked it perfectly
Mar 30, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Polaroid Will NOT edit out Commercials!
You need to post edit the recording;
First unprotect then do a split before the commercial
than split after, then recombine the parts without the ad.
Cumbersome, but it works
Feb 12, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Polaroid DRM-2001G DVD Recorder/HDD Recorder Logo
982 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
