Question about Dell Inspiron E1505 Notebook
Vertical red line on LCD computer screen
When I twist the screen the line goes away, so is the whole screen shot or what? I've opened up the laptop, but nothing looks awry, although I'm not sure what I'm looking for. If it does need to be replaced, do you know if I need an inverter? I've checked ebay, and I'm not really sure which one I need. Are screens easy enough to replace--easy, as say, replacing the keyboard?
Thanks for whatever answers you can provide.
  • bridgetml Sep 28, 2008
    i have this prob too.. there is a red vertical line on my lcd screen which has been there for years. I noticed that it is exactly inline with the start menu, perhaps indicating that it has something to do with that menu opening alot? i don't know, but i do know that it does not actually affect the comp in anyway and it can stay there for years without any problems.
    Genius:
  • 1,027 Answers
When the problem is lines/pixalization or whole areas Black or discolored it is generally the LCD T.A.B.(Tape-Automated Bonding) technology is no longer transferring data. So to make a long story short your LCD is going. But it could last for years before any further problems arise. If it is that annoying replace it.
Posted on May 09, 2008
Red dots samsung plasma
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 04, 2016 | Samsung Televison & Video
Vertical red line through screen
This is a problem within the screen, probably the connection from the internal ribbon connector to the display. Unfortunatly the only way to repair this is to have the screen replaced.
Dec 26, 2009 | LG 42LC2D 42 in. LCD HDTV
White line on screen ??
Being a whole vertical row of pixels, I'm afraid it does sound like dead pixels on the LCD.
Before splashing out on a new LCD it would be worth re-seating the connection to the screen. The cable goes up through the hinge so wIth the constant opening and closing the cable can get moved or pinched. I have seen that in the past. Normally that would effect the whole display but it's worth a look at.
Have you had a mac techie look at it? They would check for that before charging you for a new LCD.
You can save some money by picking up spares on ebay. Just depends on if you are confident enough to fit it yourself. As it is not that easy!
Sorry I cannot be of more help.
Sep 14, 2008 | Apple MacBook Mac Notebook
Problem with the screen of a Dell Inspiron 1521
Hi
In your caseHi
normally with vertical stripes it can happen due to
1.a bad LCD (small little chip inside LCD and can't manual repair)
2.a loose connection cable
so here what I do is first I try to tap at the back of the LCD and see that the problem goes away or not.If yes then a loose connection.
if no what I would do here ,coz I have a spare LCD I just exchange to test it...if the problem goes away then a BAD LCD.
Incase of verticle line due to bad LCD you can't repair it trust me.All the small IC chips are blended with board and can't really be repair.More quesiton feel free to post here.
goodluck,takecare.
Jul 18, 2008 | Computers & Internet
Vertical lines in my laptop screen
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
May 04, 2008 | Toshiba Satellite P30 P35 Series Notebook
1 vertical line going down the notebook LCD
Some of the many connections to the TFT screen panel matrix itself have have either been damaged or have decayed. These tiny connections are bonded along the edges of panel and are not viably serviceable. The most common causes are impact, stress (twisting) and condensation/moisture ingress. A replacement screen panel is needed.
Dec 16, 2007 | Compaq Presario 2100T Notebook
Monitor problem
Sounds like a bad lcd.... any time you get vertical or horizontal lines, usually, the lcd needs to be replaced.
If you flex the screen a little, does it change? Don't use alot of force, just grab the laptop lid from both side and tweak it a little to see if the lines change or go away.
What make and model is this?
Oct 28, 2007 | Compaq Presario Notebook
Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Oct 09, 2007 | Samsung SyncMaster 193P 19" LCD Monitor
Dell Inspiron E1505 Notebook Logo
2,392 people viewed this question
Alun Cox
