CAN I RUN TWO COMPUTORS OFF OF THE THOMPSON RCA MODEM ONE FROM USB AND ONE FROM ETHERNET CABLE IF SO I CAN NOT GET MY COMPUTER TO DOWNLAOD THE USB PORT FOR THOMPSON I HAVE WINDOWS VISTA
  • 589 Answers
No, you cannot use both ports, you will need to use a router.
Posted on Apr 15, 2008
How do I get a RCA modem to run in Ubuntu Linux? The modem works in XP, just fine.
There are no drivers to operate the modem as a USB device. Using a crossover cable (one should have come with the modem), you should be able to connect to it via the Ethernet ports on your computer and the modem.
Sep 01, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have the rca dcm425c modem wired to my mac in my office. I want to use google logitech tv in my other room with my big screen tv. I was told all I needed to add was a router that I would hook up to my...
USB is NOT RJ45 connectors. They are very differant as in water and bar of steel.
RCA DCM425 Digital Cable Modem eBay
Read backside cable connections. "ETHERNET" connect to router "Internet" connection. Plug ALL devices into "Ethernet" dump USB cable and store away. USB may shut down Ethernet connection while connected.
May 24, 2017 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have one modem, one router and four computers. I would like to wire one of my computers to the modem for ethernet internet access and a router to the same modem for wifi. Can I do this? All Mac...
yes just need a wireless router this regular have 3 or 4 ethernet conectors for computers for network cable , conect your modem to your new wireless router
Nov 15, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
I have a RCA Thomson DHG 535-2 without the disk for the installation and the ethernet wont help everything is hooked up etherent/cable to tv power yes... and that's about ti all im really missing is the...
Thomson Cable modem has an ethernet connection...
The ethernet connection goes to your computer via a standard Cat5e patch cable. There is no USB that I know of...
Cablevision wire goes to the modem. It should be the first device on the cablevision wire. If you need a splitter, it needs to be a GOOD one, connected DIRECTLY to the incoming Cablevision wire as it enters the house. Use good copper wire.
Order of events:
Connect the cablevision wire to the Modem.
Connect the Ethernet cable to the computer and the modem.
Power on the cable modem.
Right click the network Icon near the clock and click 'repair' (Or reboot the computer)
Apply for and get an account for cable Internet from your Cable company.
After a few days, cable Internet should work.
Apr 16, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
I have a rca dcm315 cable modem a I can connect to the internet through a usb cable but not a ethernet cable. All I'm tring to do is hook up 2 computers to the internet and I just can't seem to get the...
When switching from USB to Ethernet (Or opposite) you have to unplug it, then hook up the Ethernet cable and plug it back in.
Please gave a vote (Rate our solution), it will give me some satisfaction to know that am helping some one so I will keep on helping.
Thank you.
Apr 01, 2010 | RCA Cable Modem DCM315R (11603540)
I lost the disk for the RCA DCM425 digital cable modem the cable company gave me. how can i get the modem to work on my new computer?
Hello Friend,
If you didn't change anything in modem side, that means the modem is still connected to internet. in this case you can connect the modem to your computer via the Ethernet cable. with this cable you will not need to install anything on your computer, just plug the Ethernet cable to the RJ45 port and start browsing internet.
The only case when you will need the drivers is when you want to connect the modem to your PC via USB cable.
Here is a link where you can find everything about your modem: quick guide, user manual, usb drivers ...
Best Regards,
Oct 30, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Ethernet vs. usb
FYI for those people trying to use a ethernet and usb cable from a cable modem - it may work for a while but it won't work forever - your ISP will only allow one IP address out of the modem unless you pay for additional addresses (then you need a switch). Each device you have on the modem is fighting for that IP and eventually it will just quit working (if it works at all).
If you want more than one computer on your network (on the Internet or sharing printers/files, etc) then you need a router or a gateway (cable modem/router combo which I DON'T recommend).
Feb 09, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Mac and Thompson router
I've run into cable modems that don't like to use ethernet sometimes. In cases like this, I have to do a soft reset of the modem and things usually work again.
To do a soft reset, do the following:
  1. pull the power cord from the modem
  2. count to 5
  3. hold down the power button on the modem
  4. plug back in the power
  5. count to 30 while holding the power button (the modem should be blinking a lot)
  6. release the power button and see what happens.
Jan 14, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Setting up linksys adsl2 modem
The ADSL, Ethernet, and USB ports are located at the back of a Linksys modem. These ports are where the phone cable and computer will be connected. The ADSL Line should be connected to the ADSL port and the computer either be connected to Ethernet or the USB port., If u r using a ethernet cable no need to run the setup cd just connect the ethernet cable and contact ur isp..
do not worry about ur sagem modem, let it be inside.. just connect ethernet cables alone..
To setup a Linksys ADSL Modem with usb cable you need to perform two steps:
  1. Connecting the Devices Together
  2. Installing the USB Driver
Step 1:
Connect the phone cable to the wall jack with ADSL service and then connect the other end to the ADSL port of the modem.
Step 2:
Make sure the power adapter is plugged to an available power outlet.
Step 3:
Connect the USB to the USB port on the back of the modem and then connect the other end top the USB port of the computer.
Step 4:
Power on the modem. After connecting the device together, install the USB driver. For instructions, follow the steps below.
Step 1:
Power on the computer.
Step 2:
When the Hardware Update Wizard window appears. Click Install the software automatically (Recommended).
NOTE: Windows XP has pre-installed drivers for the ADSL2MUE and will automatically install the USB driver for the modem.
Step 3:
Click Finish.
Nov 06, 2007 | Computers & Internet
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
