Question about RCA P52937 52" Rear Projection Television
RCA P52937SG I can watch TV for about 5 minutes then the power goes completely out then comes back on, it does this about 3 to 4 times then when it comes back on the picture looks concave then it is like that for about 5 minutes and goes through a series of shutting off again and the picture comes back in like normal.... This TV was made in Jan. 2003 Is this an easy and cost efficient fix or should I just get a new TV?
  • jjethwani1 Mar 03, 2009
    The same thing happened to my tv but now it completely concaved/bowed type. I can seems to find the right words to describe it.
    My tv information:
    Model: p52937sg
    chasis: PTK195M4B
    i would realy appreciate if somebody could post the solution to this issue.
    thank you
    Champion:
  • 213 Answers
Ch over the power supply for the conv this is the stk730-020 that run your conv
Posted on Apr 23, 2008
  • Robert Smith Jun 12, 2008
    power supply for convergence is missing when this happen
    stk730-010 or 020 look for bad solder.
Rca 46" tv shutting off then coming back on
Probably the power supply is failing.
Sep 02, 2017 | RCA Televison & Video
, power cuts off ,
the power cable is broke, but not completely thats why come in and out ...
Dec 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W20 gets power but won't turn on
Hi, thank you for visit fix ya.
Common problem on thi tv.
Capacitors on power supply bad.
Replace this:
2200uf 16V, 220uf 16V. Upgrade to 35V.
Located on power supply- deflection board.
(picture)a57b905.png Thank you
Jul 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have rca d52w20 rear projection hdtv moniter-does not come on
i just changed the 3 capacitors cp150 2200 16v and cp114 35v and cp120 35v. the set seems to working good now. not to hard to do if you know how to solder. take the back off the tv and they are on the board that is on the bottom left.
Jan 13, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV turns off and on constantly.
this is the heat detection cicuit that detects when there is to much heat in the set , maybe cleaning it of dust, lint , ect.. will help
Nov 25, 2008 | RCA HD52W59 HDTV Projection Television
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
RCA P52937SG
Time to replace.
Mar 10, 2017 | Televison & Video
When powered up-TV continually changes channels---RCA P52937SG MFG 2003
Verify that you don't have a stuck channel up button on the panel. Next check the solder connections on the IR receiver (3 pins). Also check the +5 supply for excessive ripple. Any of these can cause odd behavior. Let me know how you make out.
Dan
May 02, 2008 | RCA P52937 52" Rear Projection Television
Rca p52937sg
Try unpluging it for 15 min.and try it ,if it don't work it might have a leak in your button,it is a simple and cheap repair.I suggest to call your local repair shop.
Dec 23, 2007 | RCA P52937 52" Rear Projection Television
RCA P52937 52" Rear Projection Television Logo
153 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
