Question about SanDisk Sansa e250 MP3 Player
Error 101 my sansa works fine for a while then it will freeze saying error 101 and i have to wait for the batery to run out for it to turn off. what is error 101 and how do i fix it???
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
My sand disk sansa mp4 keeps on freezing on the music play all the time and the computer cannot read it
How to Reset a Sansa Clip
The Sansa Clip is a high-quality MP3 player. It holds hundreds of songs and is built for portability. The "clip" allows you to attach it to your clothing or belt while you are working out or on the go. Even the best MP3 players can encounter some problems, and the Sansa Clip is no exception. If your Sansa Clip freezes up and does not respond, you may have to try resetting or reformatting it.
Turn Sansa Clip on. Press the "Menu" (home) button.
Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
Scroll down to "Reset All" and select. You'll be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow Steps 4 and 5.
In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm that you wish to format. Select "Yes."
Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
Resetting a Frozen Sansa Clip
Push the power button up and hold it for 20 seconds. Release it, then turn it on again.
Go to the Sansa website and download the "Sansa Firmware Updater."
Select "Run" when the updater installs. (Installation will take less than two minutes.)
Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
Connect the Sansa Clip. Remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Tips & Warnings
You should download the Sansa Firmware Updater to your computer even if you aren't having a problem with your Sansa. This will ensure that your device software remains up-to-date and free of technical glitches.
Reformatting the Sansa Clip will erase all songs and data on the device. Resetting will simply change your player's settings.
Have a nice day....
Feb 19, 2011 | SanDisk Sansa e260 MP3 Player
It got hanged..it can be turned and the buttons are not functioning
Tips & Warnings
Feb 19, 2011 | SanDisk Sansa Clip MP3 Player
My player got hanged.and its not functioning? what probably the cause and how can i deal with it? it cannot be turned off..the menus are not functioning
Hi,you need to rest your mp3 player...
Instructions
Complete Reset
Tips & Warnings
Instructions
Complete Reset
Tips & Warnings
Sansa View freezes when music is accessed (I've tried everything)
there mite be a corupted music file that is stopping your system from running properly like a coppy protected file or a virus encrypted file. check all your music that you load to be sure its not copy protected. jsut hover over the music file and wait for the info page to pop up on it it should say if its protected or not if it dosnt say anything then its not protected. as for finding the virus encrypted files thats a little harder just load one song at a time and see if it plays on your mp3
Jan 07, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Sansa c150
Wait till it runs out of power then charge it. It should charge up normally.
Jul 07, 2009 | SanDisk Sansa c150 MP3 Player
Sansa e280 "frozen" won't turn off or respond to buttons pushed
I had the same freeze problem and after doing everything I could think of I read the downloaded user manual and found the answer was to hold down the menu button for 15 seconds. It acts as a power off button and cancels out the last operation thereby unfreezing the offending action.
Feb 17, 2008 | SanDisk Sansa E280 MP3 Player
Wont turn on
Make sure you dont have the device locked. There is a switch on the top of the unit
Jul 26, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e270 refresh database
I have had a similar issue with my Sansa E270 player in the last couple of years. Sometimes when loading files, the transfer would lock up. When the power was cycled on the unit, it would freeze on the "Refreshing Database" screen. To fix this involved the following steps...Of course it involves formatting the folders containing the stored music.
1) Ensure the USB cable is connected between the computer and the player.
2) Turn the player off by pressing and holding the power button for at least 10 seconds.
3) Slide the top slider switch to the "Hold" position.
4) Press and hold in the record switch (on the side), while pressing and releasing the power switch to turn it back on
5) The display should say...."USB mode V2.0 in MSD"...or something like that.
6) The computer will detect the device as a 16Mbyte Sansa drive. Using Windows Explorer (right-click start button/explore), open the drive.
7) The Sansa drive should contain a .TXT file. In the same folder as the TXT file, create another folder named - sansa.fmt
8) Once the sansa.fmt folder has been created, unplug the USB cable and the player should automatically format.
9) Once formatted, communication is again possible.
Sep 15, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
24 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
