Question about Dell 924 All-in-One InkJet Printer
Dell 924 All-In-One printer
I've had this printer for a few years and have had know trouble with printing of photos and documents , but now I'm wanting to use card (thickness of card 210gsm) to print onto.
Now the last thing I want to happen is to get my rollers out of postion - will this card be OK to use?
  • Knowhow Apr 15, 2008
    Thank you - proton77
    I will give it a try with one sheet of A4
  • Dell Master
  • 1,183 Answers
Below are the various sizes and types of paper supported by your printer. Make sure you donnot load the tray beyond the maximum limit , otherwise the rollers may not pull the paper correctly
• Letter*
• Legal
• B5
• A4
• A5
• 3x6
• 4x6
• L
• 2L
• 5x7
• Hagaki
• 10x15 cm
• 13x18 cm
25 greeting cards,
index cards,
postcards, or photo
cards
• The print side of the cards faces up.
• The cards are centered on the paper support, in between the left and right
paper guides.
• The paper guide rests against the left edge of the cards.
• You select Normal or Photo print quality.
25 sheets of photo
or glossy paper
• The glossy side of the paper faces up.
• The paper is centered on the paper support, in between the left and right
paper guides.
• The paper is loaded vertically against the right side of the paper support.
10 iron-on transfers • You follow the loading instructions on the packaging.
• The blank side of the transfer faces up.
• The transfer is centered on the paper support, in between the left and right
paper guides.
NOTE: For best results, iron-on transfers should be fed one sheet at a time.
50 transparencies • The rough side of the transparencies faces up.
• The transparencies are centered on the paper support, in between the left and
right paper guides.
NOTE: You can load a single transparency into the paper support without
removing plain paper.
Posted on Apr 15, 2008
Missing lines of print
hello
You either have to change the ink cartridge or try to clean the ink cartridge nozzles as described in the user manual;
http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf
On page 54 it states the following:
To clean the ink cartridge nozzles:
1 Load plain paper. For more information, see "Loading Paper" on page 19.
2 In Windows XP, click Start-Control Panel-Printers and Other Hardware-Printers and
Faxes.
In Windows 2000, click Start-Settings-Printers.
3 Right-click the Dell Photo AIO Printer 924 icon.
4 Click Printing Preferences.
The Printing Preferences dialog box opens.
5 Click the Maintenance tab.
6 Click Clean Print Cartridges.
7 If the print quality has not improved, click Print Again.
8 Print your document again to verify the improved print quality.
9 If you are not satisfied with the print quality, wipe the ink cartridge nozzles, and then print
your document again.
hope this helps.
Feb 17, 2012 | Dell 924 All-in-One InkJet Printer
It starts to feed and the rollers keep going and the paper stops and does not print
Start of layer. Dell 924 All In One Inkjet Printer. Click To Close ..... However it does a good job with photo printing on photo paper, .... I had contacted Dell about the problem I was having and I felt they were not going to do .... I bought a all in one dell printer, and it will not feed the paper, correctly. ...
catalog.ebay.com/Dell-924-All-One-Inkjet-Printer-/50399257/r.html
Jul 02, 2010 | Dell 924 All-in-One InkJet Printer
Ink for Dell Photo924 Printer
Here is a site that has refurbished, guaranteed ink for your printer:
http://www.4inkjets.com/Dell-Ink,Photo-all-in-one,924,Ink-Cartridge,2344,printer.html
Refurbished Alternatives for Dell 924 Ink Cartridges and Printing Supplies Our Alternative Remanufactured Cartridges to replace the Dell OEM cartridges for use in the Dell 924 have a one year 100% quality satisfaction guarantee. These cartridges are not refurbished Dell OEM Cartridges. They are Non-OEM products that have been modified and refurbished by a remanufacturer that is not endorsed or associated with Dell and are guaranteed by 4inkjets.com to work with your Dell 924 Printer. They are a low priced alternative to Dell OEM Cartridges. Our refurbished alternative cartridges to the OEM Inkjet Cartridges are manufactured to the highest performance and quality standards and will deliver optimal prints when used in your Dell 924. Since we import our products directly from the remanufacturers we can pass the savings on to you. copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 28, 2008 | Dell 924 All-in-One InkJet Printer
Wrong ink color Dell 924 printer
run a nozzle clean, perform the following steps:
  1. Verify the All-In-One Printer 924 is powered on and connected to a computer.
  2. Verify that the paper support (input tray) has clean, plain white paper loaded.
  3. Press the Menu button.
  4. Press the Down button until Mode: Maintenance appears on the LCD screen.
  5. Press the Menu button.
    The Dell 924 Maintenance Menu appears on the LCD screen.
  6. Press the Down button until Clean Cartridges appears on the LCD screen.
  7. Press the Start button.
    The AIO 924 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
Thanks, Joe
Nov 25, 2008 | Dell 924 All-in-One InkJet Printer
Dell photo 924 all in one printer paper promblem
Unplug the power adapter from the printer and then remove the papers from the printer , open the printer cover and look for any obstructions , lift the printer and shake it firmly, turn the printer upside down and gently tab on it , roll the paper tray rollers manually , put back the power adapter and then try printing a document with only one paper in the paper tray if it still gives the same error then its an issue with the printer and if the printer is under warranty then get the printer replaced .. or purchase a new printer instead of getting it repaired .. dell is offering a new printer 926 for $49 with 1 year warranty.
Do lemme know if that helps.
Bye.
Jan 19, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 Printing Problem
GG88 your need to lubricate carrier bar inside printer rub your finger along the length of the bar if if feels dry apply two to three drops of 3in 1 oil to the bar with power off after lubricating the bar turn back on and happy printing
this is routine maintenace once a year
Nov 19, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
196 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
