Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Symbol PPT 2800
By Rachel007 - usenet poster
I've run into a problem that is pretty serious, and I wanted to know if
anyone else is running into this.  I haven't been able to tap into an event
for the system menu close button ('X').  I've found that even the Microsoft
programs that come with the device are having the same problem as I am.
When the button is clicked, the whole application shuts down and stays in
memory.
If this is a problem with Symbol's device, they need to know about it, or I
need to know of a work-around.
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 07, 2005
Not Rated)
Brad
Rank: Apprentice
Rating: 0%, 0 votes
"Mike Dimmick" <m @dimmick.demon.co.uk> wrote in
Thank you.
Hmmm.
Yes, I do.  At one point I was able to run the emulator, but not use the
scanner.  I noticed the sample applications account for whether a scanner is
attached to the device or not.  I am trying to do the same thing so I can
look at what I'm doing on my desktop.
Very impressive.  Thank you for the tips.
Was this helpful?
Yes
No
Solution #2
Not Rated)
Bomber
Rank: Apprentice
Rating: 0%, 0 votes
Julian,
That explains it then. Although, as others have pointed out, Microsoft thinks
smart minimize is a good thing and for many apps it probably is, I'm happy to
see that on the Compact Framework we'll have the option to use smart minimize or
the old PocketPC OK which closes the app.
Ginny
Was this helpful?
Yes
No
Solution #3
Not Rated)
maartenw
Rank: Apprentice
Rating: 0%, 0 votes
I forgot to mention, I'm using Embedded Visual C++ 3.0
a_z @hotmail.com (Julian Aestropos) wrote in
Was this helpful?
Yes
No
Solution #4
Not Rated)
Riddle
Rank: Apprentice
Rating: 0%, 0 votes
Symbol do use custom platforms, and custom platform GUIDs.  But it wouldn't
be the first time if they'd managed to get the platform GUID in the SDK
different from that set on the device.
Fix this by using Remote Registry Editor to look at the HKLM\Windows CE
Tools key on the device, and changing Platform to match the subkey you find
in HKEY_LOCAL_MACHINE\SOFTWARE\Mi­crosoft\Windows CE Tools\Platform
Manager\{F384D888-F9AA-11D1-BB­9E-00A0C9C9CCEE} with a '(Default)' value of
"PPT2800_2002" on your desktop.
Long-standing bug in eMbedded Visual C++.  If a different CPU architecture
is mentioned, you DO have the wrong device connected (e.g. 'The SHx SH3 CPU
does not support configuration ARM...').
Unsurprising.  You're trying to write a scanning application and link to the
scanning DLL's import library - why would the emulator have the scanning DLL
or its import library?  There's no scanner.  If you need to keep the app
portable, either write a 'stub' DLL for the emulator or link dynamically to
the scanning library with LoadLibrary()/GetProcAddress()­.
You realise that you're using the Pocket PC 2000 emulator there, right?
Just to show that it's possible, I'll point you at my company's demo (which
I wrote, with a great deal of advice from my colleagues):
http://www.5d.co.uk/downloads. htm and look for 'Proof of Delivery Demo
(Pocket PC)'.  The ARM version should run on both a 2800 and a Compaq iPAQ -
the same executable.  This was done by dynamically importing the Symbol
scanning library.
Mike Dimmick
Was this helpful?
Yes
No
Solution #5
Not Rated)
Perkins
Rank: Apprentice
Rating: 0%, 0 votes
Symbol PPT 2800_2002.  Its a PocketPC2002.
"Ginny Caughey" <ginny.caug @wasteworks.com> wrote in
Was this helpful?
Yes
No
Solution #6
Not Rated)
Pasty
Rank: Apprentice
Rating: 0%, 0 votes
Julain,
I had the same experience with 1) but agree that's no problem, and it's
mentioned on the Symbol site with a workaround.
I haven't tried remote debugging since I sold my wireless unit so I haven't run
into the 2nd one, and I didn't hit the 3rd one yet either.
Ginny
Was this helpful?
Yes
No
Solution #7
Not Rated)
LiZzIe
Rank: Apprentice
Rating: 0%, 0 votes
"John Littlefield" <John_Littlefield.removet @nospam.hotmail.com> wrote in
message
Oh for gods' sake - don't any of you lot READ the documentation?
It's supposed to do that.  Microsoft's aim with Pocket PC is to produce a
PDA.  For fast responses, they want to keep all apps in memory until there's
not enough memory to do something, which is the whole reason for the
WM_HIBERNATE behaviour.  Smart Minimize was introduced to give the user the
impression that they are closing the application, but in fact it stays
running, so that next time they 'run' the application it comes back a) very
quickly and b) where they were last time.  The aim was to try to provide a
better experience than Palm, where only one program actively runs at a
time - nothing happens in the background, and each program must store and
reload its state, even if the user just wants to change the system time or
some such.
You can argue whether this is a good thing or not, but nevertheless - if you
want to write for Pocket PC and Pocket PC 2002, you should abide by the
guidelines.  If you don't, expect your users to get very confused.
If you really don't want your app to minimise when the user presses the
Smart Minimize button, don't show it; you can remove it by adding the
WS_NONAVDONEBUTTON style to your top-level windows.  But don't close -
that's not what is being requested.
You could also argue the point of Symbol producing what is essentially a
vertical market device based on a PDA platform, but personally (despite what
I may have said before) I prefer the 2800/8100 to the PDT 7200, which is a
custom CE 3.0 device, and has a completely non-standard shell.
Mike Dimmick
Was this helpful?
Yes
No
Solution #8
Not Rated)
paulrmc
Rank: Apprentice
Rating: 0%, 0 votes
Are you running PocketPC or PocketPC2002? We've got Symbol 2800s running
PocketPC in the field and nobody reported this problem to me yet, but it sounds
like the behavior of the "smart minimize" button on 2002.
Ginny
Was this helpful?
Yes
No
Solution #9
Not Rated)
Perkins
Rank: Apprentice
Rating: 0%, 0 votes
Assuming that you have the 2002 version of the PPT2800, Set ShowOK = True
for the form(s) and App.end in the OKClick event. I'm curious - have you had
issues with the PPT2800 SDK?
Rob Agnew
Was this helpful?
Yes
No
Solution #10
Not Rated)
pawa
Rank: Apprentice
Rating: 0%, 0 votes
Oh definitely...
1) When building the Arm configuration, I get a message, "The targeted
platform PPT2800_2002 does not match the connected platform.
Continue?"  I always click yes and the app runs fine.
2)When I try to debug remotely, I get the message, "The CPU does not
support configuration ARM!  Executable will not run on device.
Continue?"  Needless to say, the message holds true, I can't debug the
application.
3)I've reached a point with the application where I can't build the
Win32 (WCE x86em) Debug or Release active configuration.  I get a
"LINK : fatal error LNK1104: cannot open file 'ScnAPI32.lib'" error.
Other than that, I think its ready for general release, what do you
think?  Just kidding.  I'm sure I'll have these issues cleared up by
the time I'm ready to do some real testing with the device.  But, any
suggestions would be helpful at this stage.
Was this helpful?
Yes
No
Solution #11
Not Rated)
Bouncy
Rank: Apprentice
Rating: 0%, 0 votes
The behavior your describing is actually "as designed" for
some reason MSFT does not unload the application when you
click the (x) box in the top right corner. The way to
shutdown a app is from the pop-up keyboard Ctl-q. This
works on all the pre installed MSFT apps. This key
sequence has to be hard coded into apps to it may not work
for all thrid party add-on apps.
Was this helpful?
Yes
No
Related Problems
I've run into a problem that is pretty serious, and I wanted...
I can't find drivers for vista. Where can i find them??
I have an MP3 player that when you sync it using Windows...
Hi, I was wondering if you were able to find me a site that...
i connect mp3 to pc and nothing happens it wont sync with...
Can you Help with these PDA problems?
can't install any application..gets...
Solve
can't install any application..gets an error its not a valid pocket pc application
turns on then turns of after...
Solve
My vivitar DVR 560G, for know reason at all just stopped working.The green led light will come on... (More)
htc model no dopad d810.cdma + gsm
Solve
htc model no dopad d810.cdma + gsm cdma is not working in india. in this model
i need a stylus for p565
Solve
i am using a dongle on the three...
Solve
Describe The connection to the server has failed. Account: 'pop.ntlworld.com', Server:... (More)
Sponsored Links
Describe your PDA problem:
Top PDA Experts
Rank: Guru Guru
Solutions: 702
Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician
Ask Me
Find more PDA Experts
Top Computers & Laptop Repair
(601) 918-0222
I will connect to your Computer and repair the...
(330) 502-6853
Instead of lugging your computer into a shop and...
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
