Garden Logo
A
Anonymous Posted on Jun 24, 2010
How do I charge a storz xenon 25 light source battery pack
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 27, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
61
Points
0
You need the charger and it takes 16 hrs on a cold battery.
The charger I have is German made. This is what it says:
Sonnenschein
Automatishes Ladegerat Ultimatic
Type 20130532
Typ120 97795 10
Power 30 VA
12V 1 A
Freq 50-60 Hz
These parts are not supported by the companyy anymore.
Motomaster Eliminator Booster/Jump Pack 750 - Lights cycle, won't boost battery
These machines always suffer with neglect and failing internal batteries. Try charging it up.
Now people use capacitive smart boosters that have no batteries, just a capacitor. The voltage in the battery is stored up in the unit over the space of about 5 minutes and then boosted back to the battery when you turn the key.
It is supposed to have a Lithium battery and they aren't supposed to drain, but my guess is that the control circuit monitors the battery and depletes it very slowly. When was it last charged? I trickle charge my boat batteries for 24 hours once a month. The same should apply for the booster.
https://www.google.com/search?q=Motomaster+Eliminator+Booster%2FJump+Pack+750
2answers
Karl storz xenon 175 light source. Replaced the bulb with heatsink but now the light source doesn't light up.
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
My aceraspire4330 wont power on
you can try the power system check by doing the following:
To verify the symptom of the problem, power on the computer using each of the following power sources:
1. Remove the battery pack.
2. Connect the power adapter and check that power is supplied.
3. Disconnect the power adapter and install the charged battery pack; then check that power is supplied by
the battery pack.
If you suspect a power problem, see the appropriate power supply check in the following list:
"Check the Power Adapter"
"Check the Battery Pack"
Unplug the power adapter cable from the computer and measure the output voltage at the plug of the power
adapter cable. See the following figure
1. If the voltage is not correct, replace the power adapter.
2. If the voltage is within the range, do the following:
* Replace the System board.
* If the voltage is not correct, go to the next step.
NOTE: An audible noise from the power adapter does not always indicate a defect.
3. If the power-on indicator does not light up, check the power cord of the power adapter for correct
continuity and installation.
4. If the operational charge does not work, see "Check the Battery Pack"
Pin 1: +19 to +20.5V (Centre pin)
Pin 2: 0V, Ground (Shielding / Surround)
To check the battery pack, do the following:
From Software:
1. Check out the Power Management in control Panel
2. In Power Meter, confirm that if the parameters shown in the screen for Current Power Source and Total Battery Power Remaining are correct.
3. Repeat the steps 1 and 2, for both battery and adapter.
4. This helps you identify first the problem is on recharging or discharging.
From Hardware:
1. Power off the computer.
2. Remove the battery pack and measure the voltage between battery terminals 1(+) and 6(ground).
(Terminal 1 is closest to the edge, Terminal 6 is closest to centre)
3. If the voltage is still less than 7.5 Vdc after recharging, replace the battery.
To check the battery charge operation, use a discharged battery pack or a battery pack that has less than 50% of the total power remaining when installed in the computer. If the battery status indicator does not light up, remove the battery pack and let it return to room temperature.
Re-install the battery pack.
If the charge indicator still does not light up, replace the battery pack. If the charge indicator still does not light up, replace the DC/DC charger board.
1helpful
Battery will not charge. replaced battery worked untill discharged, works off ac ok but light to show battery charging on computer (charger led sold and green, checked in control panel/power options/...
Go to your laptop's manufacturer's website and download the latest chipset drivers for your laptop. They will tell your laptop how to manage the battery.
How to reset the lamp counter on light source storz 20132020?
hold "o/i" + "M" for about 5 sec
then press "o/i" + "+"&"-" for about 5 sec
press and hold "O/I" + "M" to return
something like that
1helpful
My Lg Xenon is not charging properly. It says full battery after i charge it but then when i talk to someone on the phone after about 20 mins it starts beeping saying it has low battery and eventually...
I had a similar problem with a brand new LG Xenon. The battery charger said it was charging but the phone didn't charge. When the battery life on the phone died the phone would not turn on with the charger. I plugged it into my USB port on my laptop and the phone fully charged for real. I got 4 days before I had to recharge it again. Try USB cable to a PC to charge phone. Charger is probably bad. I am getting a replacement and will see if that works.
1helpful
2answers
Won't turn on. Battery is plugged in and lit. n
Try removing your battery pack. Then connect the power adaptor (even without the battery) and connect is directly to the power outlet. If it powers up, then the battery pack might be defective or totally drained.
If the battery is just totally drained, simply place the battery to the laptop. Do not turn the laptop on. Plug the power adaptor to the laptop and plug it to the power source. If you see that the charging LED is blinking in your laptop, then just leave it charging up to 5 to 8 hours.
Never use a laptop on battery mode while it is plugged in to a power source. This is the number 1 reason why laptop batteries don't last longer.
Top Garden Experts
Jay Finke
Jay Finke
john h
