Question about Philips DVDR 3355 DVD Recorder
Code for remote control of philips DVDR 3360D Hard disk / DVD Recorder
  • 04ocmd Feb 18, 2009
    i have the same philips dvd recorder and trying to get it to assign to a comcast remote? any idea on the code for that?
    Problem Solver:
  • 10 Answers
Also need to know what is the make and model of the universal remote you are using. Codes vary from one to the next.
If by chance your remote is Philips, the code for Philips DVDR's is one of the following:
0599, 0699, 1211
I have a Philips URC US2-PH5DSS and I use the code 0599 to control my Philips 3355 DVDR.
Posted on Jan 21, 2009
Hi, bought dvd ntsc format from US but can't play at our player. Are you able to assist ? Player type - Philips HTS3011/98
your dvd has regional code..only play dvd from where your purchase it.
you can do some hack.
try this
To convert this player for multi-region playback
This hack should work on all Philips DVD players with any firmware version, and other similar models by manufacturers such as Grundig, Marantz and Yamaha
Please note that if you experience problems with this hack you can obtain firmware version 7.03 and later by visiting the PhilipsSyndicate to obtain files that you can burn to a CD-R and flash your unit to the new version.
1a.
The following uses the machines own remote control:
We have heard reports that hacking some players using the units own remote control incurs a 25 change limit after which it will lock the machine in the last set region
We have heard other reports that hacking some players such as the DVDR-880 using the units own remote control can result in an inoperable unit, we recommend you use the OneForAll remote only and consult our Region Hacks forum for more information
  • Press the Play button on the player
    NB: You may need to press this button on the remote control instead
  • Press the 1 button on the remote control
  • Press the 5 button on the remote control
  • Press the 9 button on the remote control
Although the above may appear to work on many units, showing the correct display as indicated in Step 2, the hack may still not work. In which case you WILL need to use Step 1b instead! 1b.
If the above does not work, you will have to send the infra-red code RC6 (aka Codeset 4, Key 235 in nerd-speak) to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital with the following instructions:
  • Configure your remote using the setup code 0 5 3 9
  • Press the Magic button
  • Enter the code 0 8 5, or if your unit requires a five digit code, enter 0 0 0 8 5
If you own a Palm Pilot, you may also use Pacific Neo-Tek's OmniRemote software to generate the RC6 code using a downloadable .pdb file.
  • Download the .pdb file into your Palm Pilot
  • Press the OmniRemote key marked as 955 Multizone
If you do not own either of the above units, it is possible to construct a cheap DIY solution by following instructions at the following website.
NB: Sending these codes to some players, such as the Philips DVDR-980, requires you to select a DVD player remote on the unit as the default IR device, as opposed to the DVD recorder remote it is factory set to. Please consult your player documentation to find out how to do this.
2. The onscreen display should show 11 spaces like this: '-----------'
NB: The actual display may differ slightly depending on the model of your player, may be shown on the unit itself, or may even not be visible on some models at all.
3. Using the number keys on your DVD player's remote control, enter the code 222 222 005 255. Note that this is 12 digits and the last digit will not show on the on-screen display.
NB: For players such as the Philips DVDR-980, DVDR-985 and DVDR-1000 units, you may need to use the code 121 212 005 255 instead. For players such as the Philips DVDR-880 you may need to use the code 121 212 005 00x instead, where x is the desired region, however this also works on other units including the DVDR-985 for setting a specific region. 4. Press the Play button on your DVD player's remote control 5. The onscreen display should now show the words No Disc 6. Power off your DVD player, wait 10 seconds and then power back on
Aug 24, 2011 | Televison & Video
I lost my remote for Philips DVDR player/recorder DVDR 3505. What remote can I get to replace it that will do all the functions as the original.
I have the same DVD recorder and I have tried many different universal remotes and none have worked. I've found on forums that others have the same issue. Below is a link to purchase the manufacturer's remote for about $20 + shipping.
http://www.dvdremotecontrols.com/Mfrs/Philips/PhilipsDVD/996510000807.htm
Jul 11, 2011 | Televison & Video
My remote for the Philips DVDR 3455 stopped working. What can I do?
hello. Begin by replacing the batteries in your remote. If that does not make a difference go to any walmart or radio shack and purchase a universal remote control.
Jan 09, 2010 | Philips DVDR3455/37 DVD Recorder/HDD...
Play back not available
you need to finalize the disk in the original recorder to play in other dvd players, you would know this if ou read the manual
Nov 23, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Philips dvdr880
The DVDR880 displays "IS TV ON?" when it is in factory mode. You need to switch the TV to the DVDR input, as the on-screen instructions will tell you how to proceed.
Download the manual here:
https://www.p4c.philips.com/files/d/dvdr880_051/dvdr880_051_dfu_eng.pdf
Jun 28, 2008 | Philips DVDR80 DVD Recorder
DvD Player
My remote cannot function with the recorder. Battery is OK
Their is a number 2 digit on the display.
Assistant please
Mar 06, 2008 | Philips DVDR 3355 DVD Recorder
Dvd player
i need remote codes for philips 734 dvd player
Feb 02, 2008 | Philips DVDR 3355 DVD Recorder
Remote Codes for Philips Universal
These are dependent on your brand of Universal remote control. You should call the manufacturer of the remote control device or check their web site for an updated list.
Nov 04, 2007 | Philips DVDR3390/37 DVD Recorder
Rolling picture on Philips DVDR 520H
If you are using an American TV, then it's because your DVD player is set to PAL. Set the DVD player to NTSC and all should be good. peace. p.d.
Dec 31, 2006 | Philips DVDR520H DVD Player/HDD
Philips DVDR 3355 DVD Recorder Logo
1,533 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
