My HP 840C has suddenly stopped working. The light doesn't come on; I have checked the power in OK.
  • 790 Answers
Hello ,
Click here for the complete diagnosis of ur printer ...
Posted on Apr 15, 2008
  • 19,396 Answers
Disconnect from power and connect back, after this reinstall drivers
  • Ginko
    Ginko Apr 15, 2008
    If you are definitively sure it is not a software and driver problem. Check the voltage out from power adapter, if it is fine can be a defective power slot on the printer check the power slot, if your printer has a fuse it is located on power unit, near to adapter slot, change the fuse. eventually check the contacts from power input to board for continuity. If it is not this check for continuity components on the board (resist. and capacitor, starting from the ones near to power input.
    Ensurte first is not just the power adapter or power cable. Eventually call nearest repair service if you cannot locate the problem.
Service manual
The ink well in the printer looks like it
has packed up this happend to me
had to get a new printer
Apr 14, 2014 | Apple HP DeskJet 840c InkJet Printer
Printer hp deskjet 840c blinking green and red light why
Depends which red blinking light. I assume the red light is the resume light. The green light is the power light. If the Power and the Resume light are blinking alternately, then you have a paper jam somewhere in the printer. remove the paper jam and you should be fine.
Mar 18, 2011 | HP DeskJet 840c InkJet Printer
Blurred printing on my HP 840c?
have you checked your cartridges well. if they are ok, do some alignment and head cleaning. all should work out after
Mar 15, 2011 | HP DeskJet 810c InkJet Printer
I bought a new 23 tri-color cartridge for my old hp 840C deskjet printer. the ink light keeps blinking. when I put in the old cartridge which is nearly empty, the light stops blinking and it prints a page
Are you using original cartridges by HP? If you are using the 'copy' manufacturers, they don't always work.
If HP, check you've removed all packaging, especially around the nozzel and circuit contacts. Look for sticky tape to be removed.
Jan 08, 2011 | Office Equipment & Supplies
It wont print
ur hp 840c inkjet has solution app in the disc run ur disc and find out why light flashing
Jul 18, 2009 | HP DeskJet 840c InkJet Printer
Hp 840c no red printing
Dip the head area of cartridge in hot water by 2 to 3 seconds two or three times and use tissue to check the color, if all three color comes out to tisssue paper, then it works else you have to replace the cartridge.
Ahmad Bilal
Feb 21, 2009 | HP DeskJet 840c InkJet Printer
Blinking lights on my hp deskjet 840c printer
There should be some error .So you know how to remove the catridges just remove it n re insert it properly.If there are any paper jams try removing it also.and by the way if you haven't installed the drivers for HP deskjet this problem may arise.So make sure you ahve don this.Also this can be happened if the printer have some hardware problems.So none of this solutions are working its better to consult it with an expert.
Dec 18, 2008 | HP DeskJet 840c InkJet Printer
jasbo
jasbo
