Question about HP Photosmart C7280 Laser Printer
I have a hp photosmart c7200 all-in-printer and have a desktop which it is setup to. I also have a laptop which I'm tring to setup up wirelessly but having trobule. Any suggestions.
  • HP Master
  • 1,679 Answers
Have you run the Wireless setup wizard from Printer ? If No, Press Setup button on printer front panel - Scroll till Wireless/Network settings - Choose Wireless setup Wizard and follow the directions.
After you have setup printer on network - Run the Printer s/w disk and Choose Add a Device and Choose Wired/Wireless network and continue with the Installation screen.
Posted on Jun 24, 2010
SOURCE:
Hp photosmart 7200 and hp laptop are not communicating. wierless signal strengh is excellent. cancelled , documents cancelled and error message appears.
Click on the link to resolve printing issue on wireless network -> Link
Click on the link to find out if the HP Printer is on wireless network on not -> Link
To Setup the printer on wireless network, follow the steps below
1. Press the SETUP Button printer front panel
2. Scroll to Network - Press OK
3. Scroll to Wireless Setup Wizard - Press Ok
The printer will start searching for wireless router.
Choose the SSID ( Network ) and enter SSID ( network key if setup ) and Press OK
You should get a message as Printer Wireless Setup complete.
Run the HP Printer Software Disk and Choose Add a printer and Choose Wireless Installation and follow the instructions on the screen to complete the setup
You are ready to Print and Scan
Oct 12, 2010 | HP Photosmart C4580 All-in-One InkJet...
I am trying to connect my laptop to my hp printer
It's the password you used to setup security in your wireless router.
Feb 02, 2010 | HP Officejet Pro L7680 All-In-One Printer
How to get the laptop to connect to the HP Photosmart C7200 All-in-one series for scanning. Printing works from the laptop but I can't get it to scan into the laptop.
Can connect through USB or Wireless
Need to download the 64 bit OS driver from hp.com
First uninstall the complete Software from the computer
Unplug the USB cable;
Then put the CD in the computer ;
Goto My computer- Right click on Black HP logo - Click on Explore - Open
UTIL (Folder)- Open CCC (Folder)- Double Click on UNINSTALLATION
L3 file;
If you don't have the Cd Uninstall the software from Add and remove
programs
Restart the computer ;
Click on the below given link it will help you download the software :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=320478
5&lc=en&cc=us&dlc=en&lang=en&cc=us
Select your OS;
Select the Full feature Driver;
Click on Download ;
Save to your desktop;
On the printer :-
Press the setup Button (button with the monkey range)
Goto Network Press Ok
Goto Run Wireless Setup Wizard
Run it (make sure you should have the WPA/WEP key ) ready with you
Select the Network and get it connected to the network
On the computer:
Run the application that you have downloaded and install the software
Try to scan from "Hp Solution Center"
it should work
Oct 23, 2009 | HP Photosmart C4580 All-in-One InkJet...
Hp c7200 can't connect to wireless network
Try this :
Press the setup button on the printer;
Goto network setup
Run the wireless setup wizard
It will ask for the WEP or WPA key (Wireless security key)
If you don't have it contact the router company other can check from the EWS page ; put the default gateway(ip address ) in the address bar fo IE and check for the wireless settings; Even if you dont get it check the Below given Link for The network diagnostic utility ; Download it on your desktop and run it ; it will give the WEP/WPA key
Put it in the printer select Done
It will get connected to the network;
Check the Link: (for wireless installation)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01084503&cc=us&lc=en&dlc=en&product=3204785
Regards Soumajit
Sep 15, 2009 | HP Office Equipment & Supplies
HP photosmart C5580 wireless printing problem
You laptop will not be able to connect to the printer using the bluetooth technology. But the good news is that you can use the printer thru your home network by having the desktop that the printer is connected to be part of the same home network that your laptop is part of and then share your printer on our desktop and then select it as a printer to use on your laptop.
This link has instructions for all of your home network instructions.
http://www.microsoft.com/windowsxp/using/networking/setup/default.mspx
Aug 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
How can I connect my wireless laptop to print wirelessly?
run the wireless setup wizard on the printer from the front panel menus of the printer...this would assign an IP address to the printer from the router...then use the s/w cd that came along with the printer and get the drivers and s/w installed on your computer....if you want a wireless connection it would give you approprite options
Jun 21, 2009 | HP Photosmart C7280 Printer
Can not scan to my computer
Scanning thru a wireless connection is not supported on these printers. Printing does not require that much data to be sent back to the computer, scanning of course does. Printers require a bi-directional signal path to allow scanning such as USB and parallel ports. Sorry to be the barer of bad news.
Buddy
Corporate Computer
Over 21 years supporting/repairing PCs and printers
Jun 18, 2009 | HP Photosmart C7280 Laser Printer
Prints extra blank page for every one page of printed material
Ok, I too have HP Photosmart 7280 and it was spit'g out a blank page after each print page.
I went into the Control Panel/Printers - Right click on the HP Photosmart 7200 series icon and choose delete. Don't worry...just delete it.
Right above (Vista) click on Add a Printer - it's going to ask you if you want to add a local printer which is connected via USB connection or if you are set up wireless then choose Network
It will find your printer click on the printer hit next - then this is the most important step
It will ask you to find the manufacturer it shows Hewlett-Packard and underneath it shows HP - Do not click on HP - you'll have the same problem with that driver - choose Hewlett-Packard and find this driver HP Photosmart C7200 series Version 61.71.244.0 [3/23/07]
Hopefully they are all digitally signed with this information.
Click on that driver and click next - then click on replace the current driver and click next.
Print a test page and problem should be solved. Hope it helped!
Aug 01, 2008 | HP Photosmart C7280 Laser Printer
HP Photosmart C7280 Laser Printer Logo
525 people viewed this question
Clive
Clive
Thomas F. Schneider
