Hitachi CP-S225 projector - spec for screws
I need replacement rear foot adjustment screw for my Hitachi, but got quoted £18 which seems excessive. I also need 3 screws to attach a UNICOL ceiling mount to it.
Could somebody tell me what to buy if I go to a harware store for the 3 ceiling mount screws - and any idea where to get the rear foot screw for a sensible price, or perhaps you could suggest an improvisation?
  • 563 Answers
Hi Brian
The $18 footpiece you will unfortunatelly have to pay if you want the right thing.
As for the screws to mount the bracket onto the Projector , simply look right beside the hole at the bottom. Normally the size screws that you require is printed in the plastic.
Posted on Apr 15, 2008
Light bulb replacement
Fourth result.
"User manual" link on that page.
Page 48 of that document.
Turn off projector and remove power, undo screw on cover, take cover off, undo screws on bulb housing, remove bulb, put new bulb in, do screws up, replace cover, do up its screw, reconnect power and turn projector back on. Go into menu, advanced, option, lamp time, and push the up button to reset hours.
I literally just read that out of the manual.
Jan 30, 2014 | Hitachi CP-X253 Projector
Hi, our Hitachi CP-S225 will not work with our new laptop EliteBook 8440p. Our IT support has said it is because we need a driver. Can you please help?
What did they say the driver was needed for. Aren't you just using the vga output of the PC to feed the video signal to the projector. No driver is needed for this
Jan 25, 2011 | Hitachi CP-S225 Multimedia Projector
Fan running but the lamp is not on, I have
Hello :
Please check on of these solutions :
1:Remove the lamp from the projector. Ensure that it has no cracks, discoloration or "smoky" appearance.
2:Try removing and reseating the lamp, or to try another lamp.
3:Reset your lamp timer. Most projectors have no way of knowing if you physically have replaced your lamp. They rely on the user resetting the lamp timer
4:Pull the lamp back out of the unit, give is a brisk shake and reseat the lamp. Occasionally there is some buildup on the lamp contacts or filament during manufacturing.
5:Are the input and output vents blocked or obstructed in any way?
6:Are the filters dirty or clogged? Most manufacturers will recommend filter cleaning on a monthly basis depending on usage
7:Remove any extension cords, power strips and/or surge suppressors. Many current model projectors will not even try to ignite the lamp if they detect drops or fluctuation in voltage supplied to the unit. This is a safety feature to reduce stress on the lamp.
Apr 12, 2010 | Hitachi CP-S225 Multimedia Projector
I replaced the old lamp with new very carfuly and exact same way but now im getting a red light on in power and lamp and no light from lamp,is there a in fuse or something? what could be wrong?
Often a lamp reset procedure is required as well as changing the lamp over. not sure for the hitachi's (check Manual) over models often requires holding poweer button while plugging into power to reset the counter.
Dec 17, 2009 | Hitachi (DT00401) Projector Lamp for...
Need to clean air filter
clean the filter of your unit by pulling it fromt he unit...then after cleaning it...reset the filter counter fromt he menu settings and turn off your unit for about 5 min and there you go turn on your unit
Oct 28, 2009 | Hitachi (DT00401) Projector Lamp for...
To replace a bulb in the Hitachi CP-S235 LCD Projector, do I just unscrew the two screws under the plate underneath the machine? Are there any precautions I should take, like not handling the bulb? I have...
Yes to replace the lamp you need to remove the 2 screws. You can touch the lamp but I try not to. After the lamp is in you need to reset the hr timer for the lamp. to do this you need to look in manual on page 34.
If you do not have the manual you can get it here at link below.
Good luck
Oct 05, 2009 | Hitachi CP-S235 Multimedia Projector
Projection has yellow tint
From your description, it sounds like a problem with the blue color. Green LCD=purple onscreen, Red=cyan(baby blue) onscreen, Blue LCD=yellow onscreen. It could be a lot of dust on the blue lcd panel, or worse, might be a burned polarizer filter behind the lcd panel due to excessive heat. If you can focus on the yellow and its tons of yellow specs, its dust. A burned filter however, must be replaced. A technician trained in projectors will have to do it. The filter material is glued to a thin glass panel and is replaced as a single filter. It's a very involved repair.
Sep 04, 2009 | Hitachi CP-X251 LCD Projector
Hitachi CP-S225
Hi Ian
Your Projector is in need of a new Mainboard.
Must warn you that it could be a costly exercise
Dec 06, 2007 | Hitachi CP-S225 Multimedia Projector
376 people viewed this question
