Do you need to insulate a motherboard from the case
    Problem Solver:
  • 15 Answers
No but you have to put jumpers under to stop the board shorting on the metal case!
Posted on Apr 15, 2008
Dead
First thing to check is the power supply. If you were having to push the power switch several times to get it to turn on before this, it is almost certain to be the power supply. If it is a new build, then try removing the motherboard from the case and rest it on a towel or some good insulator and try powering it on with just the cpu, heatsink and ram.
Oct 31, 2012 | VIA Computers & Internet
Just put a new computer together, digital readout on motherboart reads E8 and rebooting over and over
I would check for short(s) around the mounting holes where the motherboard mounts to the case. I think that if you was to pull everything out of the case, it would run fine. Try using the ring insulators that are usually shipped with a new motherboard or case.
If that doesn't fix your problem, try checking the system memory (RAM). There have been reports of users having problems with DDR3 memory.
Hope this helps you out.
Jan 18, 2010 | Asrock P55 Deluxe (4711140875910)...
Case power for front of case to short for new ASUS M3N78-VM Motherboard, need a solution on how to cure
If the wires for the power button in the case are too short then cut them at the middle and lengthen them with more wires. Just make sure you join them solidly and the insulation is thorough.
Nov 25, 2009 | Acer Aspire (AST180-US340B) PC Desktop
No beep,No Display on my monitor,only CPU heatsink fan is moving
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
Apr 07, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
System failed cpu test
I think the problem is the mounting screw of the motherboard to the casing is grounded. You need to put some plastic insulator to the metal screw to avoid the grounded in the board.
Apr 23, 2008 | ASUS K8V-SE Deluxe Motherboard
Computer Build Problem
Try taking out the mobo and ps out of its casing, lay it on a table, hook things together and power it up. I had some problems before caused by mounting studs or try insulating all stubs from the mobo. hope this will help.
Apr 09, 2008 | Intel Motherboard
CHASSIS INTRUDED
You BIOS settings have been reset and you need to set it up again. Chassis intrusion needs to be turned off. You can download the user setup manual here: http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5S800-VM/e2419_p5s800-vm.pdf BIOS setup is in Chapter 2. There are alot of settings and it goes into detail on how to set them. This is truly an Awesome motherboard! I wish mine was like this. Follow the setup carefully and you can't go wrong.
Jul 07, 2007 | ASUS P5S800-VM Motherboard
Syntax k7sv266ad
I had this exact problem with a newly bought motherboard and it turned on but the screen was black, also I noticed once it turned on it wouldn't turn off, (Am wondering if this is happening to you) the motherboard was fine as it is in the other room now working away, so dont get rid of it just yet. Most new motherboards require additional power to the processor from the power supply, through a four pin power cable, which should be availble with the newer power supply units having (number of pins for you motherbpard power supply) + 4 (which is the 4 pin J-connector) printed on the packaging. If this is connected and you are still having problems which for me was the case, then you will have to try a different approach. Cutting the chase, the problem I had that produced similar effects of screen being black when the motherboard was powered on, was to do with my case. It was one of those flimsy aluminium foil types. I came to this conclusion by taking my motherboard out of the case and hooking it up to the cases power supply on an insulated surface such as a cork mat. It then worked fine again. So I bought a good qulaity case with a new power supply just to be sure, hooked everything up and hey presto it was fixed. It turned out that enough power couldn't get to the board as the case was shorting its supply. Hope this helps.
Jan 29, 2007 | Syntax SV266AD Motherboard
Help no power
This is a typically problem when you don't have the motherboard proerly seated. Some part of the board must be touching the metal contacts when you screw down the board to the case which causes a short. Try to reseat the motherboard and also make sure you're using washers in between where you screw down the motherboard to the case. That should fix your issue (Unless there's something wrong with the motherboard all-together).
Oct 05, 2006 | A-Top Alien Gaming ATX Case
Elitegroup 848P-A7 Motherboard - Will not boot
I had this exact problem with a newly bought motherboard and it turned on fan turned but the screen was black, also I noticed once it turned on it wouldn't turn off, (Am wondering if this is the case with you) the motherboard was fine as it is in the other room now working away, so dont get rid of yours just yet. Most new motherboards require additional power to the processor from the power supply, through a four pin power cable, which should be availble with the newer power supply units having (number of pins for you motherbpard power supply) + 4 (which is the 4 pin J-connector) printed on the packaging. If this is connected and you are still having problems which for me was the case, then you will have to try a different approach. Cutting to the chase, the problem I had that produced similar effects of screen being black when the motherboard was powered on, was to do with my case. It was one of those flimsy aluminium foil types. I came to this conclusion by taking my motherboard out of the case and hooking it up to the cases power supply on an insulated surface such as a cork mat. It then was working fine. So I bought a good qulaity case with a new power supply just to be sure, hooked everything up and hey presto it was fixed. It turned out that enough power couldn't get to the board as the cheap case was shorting its supply. Hope this is of some help.
Nov 13, 2005 | EliteGroup ECS 848P-A7 (1.0) LGA775 800FSB...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
