Question about Hunter 30124 Air Conditioner
Portable air conditioner - with HUMIDIFYING option
My daughter lives in a very dry area of Canada and wants a portable air conditioner to cool the room - with a HUMIDIFYING function. Most that I have seen had a DE-humidifier. Can you advise please
  • 3 Answers
I've actually had a great deal of customers of mine that were interested in a cooling unit that offered a humidifying option. Most of the standard models out on today's market offer the exact opposite. I work for ABS Air Conditioning in Clearwater, Florida. Up until recently, we had not offered such models but due to overwhelming requests we decided to introduce several models to our line, and I must add, with great success. I've built up some personal experience with such units as well as my staff. If you're interested in learning more about the practicality and operation of humidifying units I'd be more than happy to share with you what I know. I can be reached at 727-608-1251
Posted on May 05, 2010
My portable. Air conditioner. Isn't cooling
Could be a number of things, Is the compressor running? If so, are the filters clean? ( Both the outlet and the inlet filters.) One at the front where the air comes out and one at the back where the air goes in.
Sep 07, 2013 | Portable Air Conditioners Portable Cooling...
Tip
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
I have a Commercial Cool AC floor unit that just blew apart the exhast fan. Is it hard to replace and where could I find the part?
To find a Haier parts dealer in your area gfo to the following link: http://www.partlinx.com/haier.asp
If you want to have it repaired in the US or Canada call 1-877-337-3639.
Hope this helps and thanks for choosing FixYa.
Sep 05, 2011 | Haier CPRB09XC7 Portable Air Conditioner
Danby DPAC8399 Portable Air Conditioner no Cool air
You possibly might have a bad switch or have a dirty ac unit.Try 1st turning off the unit and cleaning the inside ...
May 27, 2010 | Danby DPAC8020 Air Conditioner
Bad lower fan unit
send it to me ups ill fix it cheeep if its just the fan
Apr 14, 2010 | Amcor PLM-14000E Portable Air Conditioner
Leaking water
Very common problem with these systems. This depends on humidity in the air. Some systems have a setting that you can turn off the dehumidifier. The downside to this is it doesn't cool quite as well as humididty absords heat. The drain pan in your system is probably overflowing. You have a couple options, you could "hard drain" it to outdoors, empty the drainpan regulary, or change the air settings (this may not solve completely if you live in a humid area).
Aug 30, 2009 | Haier HPM09XC5 Portable Air Conditioner
Demby portable Capacity: 11,000 BTU air conditioner
This unit is sized to approx a 35 square metres area at a normal 2.4 metre ceiling height. All I would recomend without actually seeing the problem is to check this measurement and close all windows and doors. The unit is most likely undersized, but check the air temp coming off the unit. It should be about 10 degrees.
Aug 15, 2009 | Heating & Cooling
THERE'S NOT A PROBLEM I NEED YOUR OPINION
This EdgeStar 10,000 BTU portable air conditioner heats and cools for year round comfort and is recommended for room sizes up to 350 square feet. This slim and light superstar uses the latest technology to squeeze the most powerful cooling from the smallest possible package this 10,000 BTU portable air conditioner has a footprint of just over a square foot and is under 28andquot high! This portable air conditioner is the most powerful portable air conditioner in its class and size range and can bring down mid size rooms faster than competitor's models.
Dec 27, 2008 | EdgeStar Portable Air Conditioner Heater
Portable Room Air conditioner will not cool
You need to call for for a qualified technician oil residue is a sign that your unit have leaking, your unit is out of refrigerant.
Nov 12, 2007 | GE APN10AA Portable Air Conditioner
Hunter 30124 Air Conditioner Logo
101 people viewed this question
Top Hunter Heating & Cooling Experts
Jay Finke
Jay Finke
Mack Baxter
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
